11-18-2005, 12:09 PM | #1 |
Member#: 96186
First Computer Build HELP!
Alright guys, I'm a Web & Graphics designer, I'm looking to do a new build and mix & match with the parts I already have.
Here is what I was going to purchase from new egg Case MB Processor Hard Drive Memory PSU ( the one with the case is **** ) Video Card Printer Anything else I didn't list I already own, Let me know what you think about this set up guys
11-18-2005, 12:10 PM | #2 |
Member#: 39142
Vehicle:Memb er#: 39142 Join Date: Jun 2003 |
I would go with a Lian Li PC65, and an Antec power supply. Those are two things you don't want to go cheap on. Why not go 10k rpm WD Raptor?
11-18-2005, 12:16 PM | #3 | |
Member#: 37875
Vehicle:-- POS Silver |
But, get rid of that powersupply. The case is just ehh. Whatever you do, don't cheap out on the powersupply. Antec powersupply should be a good choice. Also, please, do not get kingston value memory. If you're going to be doing some graphic designing or gaming, get better ram. Also, the 6600 is on its way out. I'd put some more money in and get a better vid card. |
11-18-2005, 12:16 PM | #4 |
Member#: 96186
can you please refer with links to newegg?
11-18-2005, 12:16 PM | #5 |
Member#: 19546
Vehicle:2009 Honda Fit |
Raptors aren't worth the small size and slight increase in speed, I would get a much bigger hard drive though.
11-18-2005, 12:17 PM | #6 | |
Member#: 96186
11-18-2005, 12:20 PM | #7 |
Member#: 5410
Vehicle:2012 BMW 550i xdrive Gray |
I would go Enermax PSU, 425Watt Noisetaker
keep the case if you want but i would think about the Praetorian 108.99 X2 3800 CPU and any Nforce 4 ultra board. With some good quality memory (higher speed but low latency) If you want to keep with Intel then wait just 8 days till Newegg stock the new 975x intel chipset boards. Also get an aftermarket cpu cooler (hyper48 or the zalaman 120mm huge copper fan). And get some 700Mhz DDR2 memory |
11-18-2005, 12:30 PM | #8 |
Member#: 5410
AMD route.
Motherboard (life time warranty) http://www.newegg.com/Product/Produc...82E16813189001 $109.99 CPU X2 3800 http://www.newegg.com/Product/Produc...82E16819103562 $322.00 Memory OCZ EL Platinum Revision 2 1GB http://www.newegg.com/Product/Produc...82E16820146890 $150 Case coolermaster http://www.newegg.com/Product/Produc...82E16811119035 $108.50 PSU Enermax 420W http://www.newegg.com/Product/Produc...82E16817103459 $65 Video card 7800GT http://www.newegg.com/Product/Produc...82E16814130247 $319 Hard drive 74gb Raptor http://www.newegg.com/Product/Produc...82E16822144160 $161 |
11-18-2005, 02:49 PM | #9 |
Member#: 96186
so why would you suggest AMD over Intel?
11-18-2005, 02:50 PM | #10 | |
Member#: 39142
11-18-2005, 02:50 PM | #11 |
Member#: 5410
Erm because its faster at crunching numbers.
11-18-2005, 02:54 PM | #12 |
Member#: 96186
the ones you reffered me, are those the top of the line currently?
11-18-2005, 03:00 PM | #13 |
Member#: 5410
No the video card is not.
The cpu is the entry level AMD duel core. The rest of the stuff is top notch. |
11-18-2005, 03:02 PM | #14 |
Member#: 5410
http://www.newegg.com/Product/Produc...82E16814127182 $449 7800GTX 24pipeline where as the GT is 20 pipelines (maybe 5-10% slower)
11-18-2005, 03:02 PM | #15 |
Member#: 96186
okay, what are some of the next steps to upgrade the cpu? sorry I'm a amd noob
11-18-2005, 03:03 PM | #16 | |
Member#: 39142
11-18-2005, 03:06 PM | #17 |
Member#: 5410
if you bought the stuff I posted you just buy a faster chip and drop it in.
AMD are releasing a new socket next year M2 that takes DDR2 but this is like the middle of the year. They will phase production of the 939 socket out at that time also. |
11-18-2005, 03:54 PM | #18 |
Member#: 96186
man im confused and now i cannot decide..
11-18-2005, 04:03 PM | #19 |
Member#: 8645
I dont really like Intel motherboards, Id go with MSI, EPOX, ASUS
Get better quality RAM If you just do graphic design the video card doesnt matter much. That one looks good. Dont bother with the 7800... I also like the ATI's image quality better. Maybe a X700? |
11-18-2005, 04:04 PM | #20 |
Member#: 5410
go with AMD.
I have a Duel core intel because AMD doesnt work for all my familys needs But AMD is awesome if you need numbers crunching. |
11-18-2005, 04:07 PM | #21 |
Member#: 33246
NESIC
- Janq |
11-18-2005, 04:10 PM | #22 |
Member#: 96186
okay so wheels, The set up you recommended, I'd be okay multi-tasking without to much lag and have a fast loading system?
11-18-2005, 04:10 PM | #23 |
Member#: 70925
Vehicle:2017 Q50 AWD 07 350Z 1990 Skyline GT-R 99 CR-V |
EPoX ftw, but id def get the x700 over the 66GT, because ^^ is right, in general my ATI cards look better than the nvid cards ive had. id recommend a sapphire, asus or gigabyte brand card (in order of asus, sapphire, gigabyte), stay away from powercolor imo....
11-18-2005, 04:18 PM | #24 |
Member#: 14611
AMD all the way... there are no good reason to go Intel.
Don't go with 1GB (2x512)... get 2 GBs to begin with. The way you are doing it would limit your expandability in the future. Concerning the printer - while I do much prefer Epson - if you are doing any type of paper proofs, you might want to go with one of the Espon 7-color printers. Not sure if the one you posted uses a 'regular' 3color+K or if it is one of the newer ones that has like 7-color inks. |
11-18-2005, 04:37 PM | #25 |
Member#: 96186
Hazdaz, what do you think about the system Wheels recommended?
I need realtime computer building help! | Capt Crunch | Off-Topic | 23 | 06-08-2009 10:17 PM |
My first Computer Build | Jsunn | Off-Topic | 23 | 07-24-2007 04:10 PM |
Starting my first computer build | java04rexracr | Off-Topic | 34 | 05-31-2007 10:09 AM |
Need some computer building help. | Guru Imakuni | Off-Topic | 15 | 05-08-2005 03:40 AM |
Computer Building Help/Insight | D'sScooby | Off-Topic | 27 | 02-12-2005 06:07 PM |
