12-15-2004, 09:01 AM | #1 |
Member#: 27679
Vehicle:2002 Impreza WRX Aspen White |
Hey guys, need help diagnosing a problem
Last night as I went to leave work, i turned on my heater and I noticed this faint fuel smell coming from the vents. At first i thought it was just the car in front of me so I didn't think anything of it. Later that night I drove to volleyball and my friend was saying, do you smell fuel? I'm like yeahhhhh..shiett...So when i got home, i tried to see if there was a leak anywhere (didn't appear so) and I noticed a strong fuel smell coming from the left side of the car near the intercooler. Have any of you guys had this problem or know what it could be?
12-15-2004, 09:03 AM | #2 |
Member#: 1501
NESIC
Vehicle:2009 WRX wagon Dark grey |
It's the infamous "fuel smell from cabin when it gets cold" issue. It's common. AFAIK, it is not been recalled. But, a bunhc of us have filed complaints with the NHTSA (orwhatever it is) so that it gets recalled. I will dig up an older thread in a moment.
But, in the meantime, no need to worry about it. |
12-15-2004, 09:05 AM | #3 |
Member#: 27679
haha, thanks redobs. It might annoy the crap out of my gf to the point where she'll make me get a new car. in the mean time, i'll try not to get too high from breathing in the fuel smell.
12-15-2004, 09:05 AM | #4 |
Member#: 23717
NESIC
Vehicle:2005 Big red |
Sounds like the fuel line TSB. The early WRX's had a problem with a fuel line under the intake manifold. It only happens in the very cold weather. If it continues I would take it in to a dealer and ask them about it.
TMS |
12-15-2004, 09:41 AM | #5 |
Member#: 67536
NESIC
Vehicle:00 AW GM6 And a bunch of parts |
I notice it right when the heat comes on, for a second.
At least it's not a Corvair, which I've been told used the exhaust pipe to pull heat into the cabin. |
12-15-2004, 10:16 AM | #6 |
Member#: 29699
NESIC
Vehicle:2005 Legacy GT Wagon Red |
I had this problem last year.... It was not an easy fix... My car sat at the dealer ship for 3 weeks waiting for the parts the needed to fix it. I complained to SOA that I was not able to use my car and was paying for it, and they paied a months payment $450 in my case, and also supplied my with a rental for the full three weeks... So just a heads up that it is a pain unless the dealer has the parts onhand... which they should after the number of peple that had to have this fix last year...
12-15-2004, 10:43 AM | #7 |
Member#: 1800
NESIC
I've been researching this a lot lately as my blue WRX smells awful. To summarize:
No recall, just a TSB. The NHTSA investigation is closed, the issue is not considered a safety issue. This is covered under 3/36k warranty, but not powertrain. Some were able to get SOA to foot the bill, but like the clutch shudder issue, they seem to have stopped doing this. The fix is to replace one rubber hose and one metal one under the intake manifold with alightly different lengths. Parts are pretty cheap, but it's a fair amount of labor. Some have luck tightening some of the hose clamps, but most are not accessible without removing the manifold. I think I'm going to suck it up and fix it. It stinks and isn't going to go away. Dealers want around $400-600 to do the job. Paul |
12-15-2004, 10:44 AM | #8 | |
Member#: 1800
NESIC
12-15-2004, 11:14 AM | #9 |
Member#: 8174
Vehicle:2002 WRX Sedan Black |
I got this fixed free when I complained about it enough. I did have to bring in a copy of the TSB, though, so if your dealer's never heard of it, do a search or something.
Oh, and they had to order the parts from like Zimbabwe or something, so it took forever to do. The fix was like, "Before this pipe was 3" long and this tube was 8" long. Now, the tube is 5", and the pipe is 6"'. Once they had the parts it was pretty fast. |
12-15-2004, 11:53 AM | #10 |
Member#: 27679
ahhh this sucks. My warranty just ran out as i have 40K on my car now. I think if i try to complain enough maybe they'll do it for free at Norwood....they have a pretty good service department over there.
12-15-2004, 02:29 PM | #11 |
Member#: 29699
NESIC
My dealler did it with no questions asked and I was off warranty, they had heard about it and gotten a heads up from SOA, they took care of the fix and SOA paid a months car payment for me... Cal SOA they will do there best to make you happy...
12-15-2004, 03:36 PM | #12 |
Member#: 23717
NESIC
Not suprising that they are fixxing this past the powertrain waranty.
I haven't looked in a while but if you check the manual. All emission related equipment is covered to 70k or 100k miles I think. The entire fuel system should be covered by that. Anything having to do with fuel or fuel vapor would be covered. TMS |
12-15-2004, 04:11 PM | #13 |
Member#: 1800
NESIC
That seems reasonable, but SOA is not seeing things that way in most cases. If anyone has luck with that in MA, let me know where.
12-15-2004, 04:24 PM | #14 |
Member#: 74268
NESIC
fuel system = emmission related??
Well I guess if it's "emitting" gaseous vapors |
12-15-2004, 04:30 PM | #15 |
Member#: 1800
NESIC
Gasoline fumes are a regulated emission from vehicles. The system needs to be sealed. Most states perform a fuel system pressure test as part of the emissions process (I didn;t see the tech do this to my car in MA).
12-15-2004, 04:38 PM | #16 |
Member#: 74268
NESIC
Well he said "all emissions related equipment is covered..." which technically would not include fuel system parts since they are not part of the emissions system. So while it qualifies as an emissions issue because gas is leaking, the problem does not lie in the emissions related equipment and therefore would not be covered by the warranty.
I'm not saying I don't think it should be covered because goddam... the car is LEAKING GAS ... but considering how shady dealerships can be on warranty issues I'd think that they could cover themselves with that argument.... assuming that is how it's worded. |
12-15-2004, 04:57 PM | #17 |
Member#: 23717
NESIC
OK I went out and checked
I am wrong. And right at the same time. 3/36 coveres the entire fuel system The one I was thinking of is the 8/80, but it only covers the Cats, and ECM. TMS |
12-15-2004, 04:59 PM | #18 |
Member#: 41713
NESIC
Vehicle:. sprayfinishing supplies.com |
volleyball is for pussies!
I say check your blinker fluid.... |
12-15-2004, 05:02 PM | #19 | |
Member#: 23717
NESIC
TMS |
12-15-2004, 05:48 PM | #20 | |
Member#: 27679
Need help diagnosing a problem | silversubie02WRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 09-07-2009 11:59 AM |
Need help diagnosing a problem. Log inside/ | nayr924 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 12-11-2007 11:53 AM |
Need help diagnosing a problem | joebobanaught | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 04-25-2005 05:09 PM |
Hey guys, need help with something... | JGard | New England Impreza Club Forum -- NESIC | 10 | 05-08-2001 12:57 AM |
HEY GUYS NEED HELP.. | PASTA POWER | South East Region Forum | 4 | 03-31-2001 12:13 AM |
