02-10-2005, 11:47 PM | #1 |
Papi Chulo
Moderator Member#: 53794
RMIC
Vehicle:... 2017 BMW M2 2017 F-150 |
how to remove the badge sticky stuff?
I just recently did a sti trunk swap and we removed the sti badge but most of the adhesive is still on the trunk. could i just use gogone to get the adhesive off. has anyone had this problem, im sure someone has, what did you do to get it off?
02-10-2005, 11:50 PM | #2 |
Member#: 39827
Vehicle:'03 WRX Stg. 2+ |
i just kept the hairdryer on it...let it heat up, used a rag and rubbed the crap out of it until it came off.
02-11-2005, 12:20 AM | #3 |
Member#: 75071
Vehicle:23 Solterra,ModelY Old: 05 08 11 WRX, 18 STI |
Goo Gone!
02-11-2005, 12:22 AM | #4 |
Member#: 59643
Vehicle:2003 Impreza Wagon Midnight Black Pearl |
3M bug and tar remover... it is clear coat safe! find it at your local auto parts store.... (it is a areosol can with a blue lid)
02-11-2005, 12:23 AM | #5 |
Member#: 19311
Vehicle:2002 Lexus IS300 Black 5MT |
goo gone, put it on, let it sit for 5 minutes, and the stuff will just wipe off. I didn't even use a hairdryer and my trunk looks perfect
02-11-2005, 12:51 AM | #6 |
Member#: 22157
Vehicle:'02 WRX '04 350Z Cause We Are The Aquateen |
Hair dryer, Goo Gone, wax. In that order. Simply put.
02-11-2005, 01:20 AM | #7 |
Member#: 66443
SCIC
Vehicle:2011 Toy-OTAAAA four-runner! |
Yea, be sure to wax, I heard dirt just starts showing up in that one specific spot cuz of no wax.
02-11-2005, 01:39 AM | #8 | |
Member#: 27790
E. Canada
for really sticky stuff or to get under the emblem when you first start, consider using your Blockbuster card - fully laminated, softer than a regular credit card, easier than using your fingernails, won't scratch the paint |
02-11-2005, 08:39 AM | #9 |
Member#: 24945
W. Canada
Vehicle:1994 Burnt In Fire White Metal |
I used WD40 and a paper towel after I had removed all I could with the aforementioned Blockbuster card and hair dryer. Peeled the stickies off without a problem. Waxing right away is an extremely important step, though.
02-11-2005, 12:16 PM | #10 |
Member#: 64190
South East
Vehicle:2005 WRX STi Crystal Grey/Silver |
Heh, I just got the surface wet and scrubed it off with a terry towel.
02-11-2005, 12:21 PM | #11 |
Member#: 34162
Vehicle:2005 WRX wgn, 01 RS White, White |
I used googone.
02-11-2005, 12:31 PM | #12 |
Member#: 74992
Vehicle:04 STI ASPEN WHITE |
Is it better to use a heat gun over a blow dyer to get the badges off? or are they pretty much the same?
02-11-2005, 02:50 PM | #13 | |
Member#: 80532
TXIC
Vehicle:2014 BRZ DGM |
pretty much the same, heat guns can get really hot and melt the paint. Debadging subaru's shouldn't be much of a problem on a hot summer day, or just a blow dryer and some goo gone. |
02-11-2005, 02:54 PM | #14 |
Member#: 74992
Its cold here in PA right now I was gonna do it tonite in my garage?
02-11-2005, 03:04 PM | #15 |
Member#: 21543
Vehicle:2018 1LE White |
eraser wheel, goo gone or any other type of residue remover is wasting your time..
by and eraser wheel and stick it to the end of your drill, then wax.. takes 5 minutes tops |
02-11-2005, 06:41 PM | #16 | |
Member#: 19311
02-11-2005, 08:00 PM | #17 |
Member#: 32574
South East
Vehicle:2012 Nissan GTR BE Vibrant Red |
3M adhesive remover followed by Meguairs scratch-X.
Good Luck |
02-12-2005, 03:27 AM | #18 |
Member#: 43259
W. Canada
Vehicle:1999 2.0RS RBP |
I sprayed on some WD40, let it settle for a few minutes and scraped everything off with a credit card.
02-14-2005, 12:48 PM | #19 |
Member#: 73432
Vehicle:2008 Ford Mustang GT Performance White |
^^^yeah man,WD40 and then clean it and carnuba it....
02-14-2005, 02:36 PM | #20 | |
Member#: 14531
SCIC
Vehicle:02' Stage4 wrb WRX 06' Mazdaspeed6, 85' AE86 |
02-14-2005, 04:52 PM | #21 |
Member#: 76909
denatured alcohol... works great, but strips your wax
02-15-2005, 03:11 PM | #22 |
Member#: 79870
Vehicle:02 WRX Black |
I used a flathead and some steel wool.... worked perfectly
02-15-2005, 03:16 PM | #23 |
Member#: 19130
South East
Vehicle:'01 TTE Miata www.awesom-oracing.com |
maybe an angle grinder would help too! |
02-15-2005, 05:30 PM | #24 | |
Member#: 53992
BAIC
Vehicle:SOLD CGM 2005 2.5RS 35 PSI -- in my tires |
02-15-2005, 06:02 PM | #25 |
Member#: 78539
Vehicle:2005 Subaru STi K&N Typhoon HKS CarbonTi |
i just used a hair drier, then got the glue off with my hand then used water and a tiny bit of wd-40 for the hard to get part and water and its good as new w/o the dealership sticker
how to remove the glue/sticky stuffs off ur paint? ><.. | silverey3 | Interior & Exterior Modification | 10 | 08-16-2007 11:24 AM |
How to remove the front STI badge? | krisco | Interior & Exterior Modification | 3 | 01-01-2007 11:40 PM |
How to remove front badge/emblem? | def_jam | Interior & Exterior Modification | 9 | 06-15-2006 10:26 PM |
how to remove the front badge? | 516_WRX | Interior & Exterior Modification | 8 | 04-11-2002 02:56 PM |
How to remove front badge on Legacy? | gtwagon941 | Legacy Forum | 5 | 03-28-2002 11:24 AM |
