04-16-2015, 05:44 AM | #18176 | |
Member#: 241216
Vehicle:2000 Outback 2013 SWP BRZ |
This is for numerous possibilities, like: dirty MAF, broken vacuum lines, catalytic converter failing, bad plugs, low quality fuel, EGR valve, bad air filter, etc It's very hard to track down a 420 code. You can start throwing money at it to get rid of the check engine light, orrr do what the rest of us do with an older Subaru: let the light be since it doesn't effect fuel economy or performance. Just scan the car like once a month to make sure more don't turn on and drove the car carefree.
04-16-2015, 01:15 PM | #18177 |
Member#: 418541
Vehicle:2005 Outback3.0R VDC Gold |
I checked the MAF this morning as I used to have to clean it off on my Land Rover a ton, and one side was pretty grungy so I sprayed it with CRC cleaner and put it back in, disconnected the battery to reset the ecu as recommended by a legacy guy, and drove it to work. So far so good no more codes or lights in 20 miles. Hoping this holds until I can get back to GH. I do a lot of highway driving so I kind of like cruise control for that haha so part of me wants to figure it out.
I always run 91, and 94 when its avail at certain stations in Ontario so I don't think its the fuel quality but who knows. While I was at my MAF I checked the filter and it looked pretty decent, whats your thoughts on K&N? or any other suggestions for air filters? Also how hard is it to change plugs on an H6, I have heard its a pain maybe its time I give those a change as I'm coming up to 120k miles. |
04-16-2015, 01:47 PM | #18178 |
Member#: 203783
Vehicle:2005 LGT |
Just stick with a paper filter, the K&N ones will crud up your MAF if you oil them too much, and the only reason they flow more is because they filter less. so more sand and crap will make it into your motor.
Ive never done h6 plugs but i imagine its just as annoying as h4 plugs, you can do it in a few hours in a garage with basic sockets and a swivel. Its worht changing if they have never been changed in 120k |
04-16-2015, 04:01 PM | #18179 | |
Member#: 241216
In fact, if your vehicle is designed for 87 and you're running a higher octane fuel you're not doing yourself or your car any favors. The higher the octane, the harder it is to ignite, so you may be getting an incomplete burn. It would likely also be harder to get it to start up since it would need a little extra heat to kick off the first ignition. As to air filters, I agree with Eric. Just run an OE type replacement from a reputable company. I like WIX, but whatever you like is fine, too. |
04-16-2015, 10:47 PM | #18180 | |
Member#: 418541
I never really got to do any of the fun stuff growing up. Driving a Land Rover was just slow and steady and expensive to fix when it wasn't steady. So I appreciate all of the help from everyone! I will stick with a stock air filter, I have always heard mixed things about the K&N's. So far so good with the clean MAF. Today I got so bored at work I went through all 74 pages of service records for the car dating back to 2005 when brand new, and typed them out in a word doc in chronological order and mileage in/out (this car has been treated well thats for sure) so I no longer have to keep that stack of papers in my glove box. I have never had an empty glove box before this is exciting. In Canada they seem to have quite a rigorous dealer maintenance schedule. Way better than the one our 2010 XT has been getting from the dealer in Michigan thats for sure. Also every 10k miles at Subaru dealers in Canada they fully TerraClean them. In Ontario all cars/trucks 1985 and up must have a full two part inspection by the government every 24 months(or when you change ownership), ranging from tire wear to lightbulbs and wipers, to cracked hoses and bushings, and don't even think about having a stone chip let alone a crack in your windshield they also scan it to make sure there aren't stored codes. If it doesn't pass the first inspection you must replace all parts in order to qualify for the second stage of inspection which is emissions testing. Its pretty crazy up here thats for sure. Maybe even worse than California. Cars up here aren't allowed to go to **it legally haha Travis I need some suggestions on rim colors, I seem to be struggling to find a color that would look okay on a gold Outback. Other than the obvious black of course. |
04-17-2015, 06:41 AM | #18181 |
Member#: 395882
Vehicle:2016 WRX DGM |
04-17-2015, 06:50 AM | #18182 |
Member#: 332321
Vehicle:1998 2.5rs wrb |
That would looking quite interesting. Do you have any objections to the black?
04-17-2015, 08:12 AM | #18183 |
Member#: 203783
Vehicle:2005 LGT |
Is your car gold or is it the deep bronze metallic?
04-17-2015, 10:55 AM | #18184 |
Member#: 418541
Its the "Champagne Opal Gold Metallic" Heres the color of mine, I am leaning towards black rims. I was considering getting some more stickers and maybe matching the rims to that? Down the road I want to get it tinted also. I miss my limo tint that I had on my Landy.
https://flic.kr/p/rTpVAL Not sure why the picture won't load as a preview on here. Last edited by Tristan2452; 04-17-2015 at 11:19 AM. |
04-17-2015, 03:21 PM | #18185 |
Member#: 270699
Vehicle:2005 WRX Wagon OBP |
Sounds like no one else is going to MSU this weekend then?
04-17-2015, 04:12 PM | #18186 |
Member#: 332321
Yeah I think that the black would fit pretty well on that.
04-19-2015, 09:53 AM | #18187 |
Member#: 203783
Vehicle:2005 LGT |
tacos tomorrow!?
04-19-2015, 10:03 AM | #18188 |
Member#: 347657
Vehicle:2010 impreza 2.5i Obsidian black |
I think next week not this one. Travis is heading to Mexico and I am heading to PA tomorrow so I'll be down for next week
04-19-2015, 01:47 PM | #18189 |
Member#: 203783
Vehicle:2005 LGT |
i'm in mexico next week lol
04-19-2015, 09:50 PM | #18190 |
Member#: 319017
Vehicle:15 Prius 2JZ miata Death Trap |
Not this week for me either it's operation work a billion hours still so I can fix my car.
Sent from my iPhone using NASIOC |
04-20-2015, 09:24 AM | #18191 |
Member#: 270699
I won't be able to do Monday's starting next week, softball starts up.
Finally ordered a Curt hitch yay! |
04-20-2015, 03:17 PM | #18192 |
Member#: 156634
Vehicle:2000 Fozzy S White / Grey Met |
Who is at the Gingerman for TopHat Racing Spring expo? I only see 3 Subies here....
Sent from my XT1254 using NASIOC mobile app |
04-21-2015, 11:16 AM | #18193 |
Member#: 149262
Vehicle:03WR rallycarFXTleg PrimerGrey |
Who's got a hookup at Matco Tools. Need some Impact Wrenches for Service.
04-21-2015, 03:11 PM | #18194 |
Member#: 418541
Been putting it off for a couple of weeks, but I need to do a trans drain/flush ASAP on my 5EAT. I am going to pick up 13 Quarts of the SUBARU HP-ATF tomorrow in Canada at $8.34/Qt before I head off on my trip to CMU Thursday then I'll be GH bound Sunday.
I looked at the filter and it seems fine with visible no damage. I have been reading and studying a lot on how to do this and following the info found on the "DIY 5EAT ATF Flush" thread on the LGT forum. Looks pretty simple. Would anyone be down to help or supervise this next week or weekend? I have never done this before so I figured if anyone had experience and was free that would be great. I could come to you, or if you came to me on a Tuesday, it is $1 Taco Tuesday at Arturos in GH and they have the best Tacos in town and I'd buy. Or I would buy tacos any other day if you came. Figured that would sweeten the deal haha I figure its cheaper to buy the fluid and tacos than pay the $250 for a flush |
04-26-2015, 07:24 PM | #18195 |
Member#: 166290
Vehicle:04 EJ207 GT30R 6MT SRR Widebody Wagon |
Perrin for tacos tmrw anyone?
04-26-2015, 08:40 PM | #18196 |
Member#: 203783
Vehicle:2005 LGT |
just had tacos today, but im in saltillo so...
04-26-2015, 11:59 PM | #18197 |
Member#: 156634
Who was on E-beltline / 4 mile / Plainfield today mashing ? Sounds like Open DP and ALS. I could hear that thing inside Lowes!
04-27-2015, 05:35 AM | #18198 |
Member#: 241216
04-27-2015, 10:47 AM | #18199 |
Member#: 166290
04-27-2015, 11:03 AM | #18200 |
Member#: 156634
ISO 02-05 WRX Pedal set.
Please let me know if you have one. |
Anyone here from the Grand Rapids, Holland, or Muskegon MI areas? | Scooby do | Mid West Subaru Owners Club Forum -- MWSOC | 19 | 05-25-2012 02:09 PM |
Good alignment shops in the Grand Rapids/Muskegon areas? | Paradenu | Mid West Subaru Owners Club Forum -- MWSOC | 3 | 12-08-2006 01:20 PM |
Anyone close to Grand Rapids going to the Ojibwe ProRally? | penjaja | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 08-13-2002 01:55 AM |
Grand Rapids | metroplanner | Mid West Subaru Owners Club Forum -- MWSOC | 0 | 06-15-2001 05:00 AM |
Grand Rapids MI Autocross | Scooby do | General Forum Archive | 0 | 09-27-2000 03:26 PM |
