08-10-2009, 05:39 PM | #26 | |
Member#: 69261
BAIC
So if you want to make "a" bigger, I would start by making "m" smaller. Get that weight out. Now work on "F" by getting stickier and bigger rubber. For most people gettier sticker tires is easier, and getting weight out is hard. So they get sticky rubber and now find themselves capable of creating more force than the brake system can handle(can't lock up), so upgrading the brakes becomes a requirement. Weight is free, start there. Chris Lock
08-10-2009, 05:43 PM | #27 |
Member#: 159796
SCIC
Vehicle:2006 WRX |
it was only a matter of time before someone came in here talking like a physics professor.
anyway, he said an R32 brakes better than his car, and the R32 isn't lighter than a WRX. I'm pretty positive he just *thinks* his car doesn't brake as good as others in the same class, when in reality he's just used to his car's characteristics. BTW, its not a fair comparison to compare to other cars with a better brake system either. If you are able to lock up your brakes easily, then get better tires and get a better suspension with less travel. Springs by itself are pretty worthless IMO, that is about the best you can do as far as "feel like it brakes good" goes. If you want to step into a better territory, upgrade your brakes to a better system. If your brake fluid is old, flush it out and put in fresh fluid... this is also important, I would recommend to flush out super blue every 1 year. Last edited by vinxH; 08-10-2009 at 05:49 PM. |
08-10-2009, 06:14 PM | #28 |
Member#: 46500
Vehicle:So many I can't remember anymore. |
i will completely agree tho, my stock 03 wrx scared me to death the first emergency stop i had to make (cut off by minivan jumping into turn lane at redlight). i honestly thought i was gonna hit them. after installing 4/2pots, ss lines, and good fluid, it felt worlds better...
the oem 4pots use a smaller pad in the front helping to give better initial bite/feel. |
08-10-2009, 09:03 PM | #29 |
Member#: 69261
BAIC
08-10-2009, 09:13 PM | #30 |
Member#: 122980
South East
Vehicle:2010 F150, 2013 CX-5 92 Miata 15 TTF/PTF/E3 |
08-10-2009, 10:18 PM | #31 |
Member#: 62182
NWIC
Vehicle:2005 STI White |
Hrm. So you could be under-damped. I'm not sure how you'd test that, but I know on my miata with old tired Konis and stiff FM springs, the brakes feel like crap, because the front end doesn't properly settle and let the tires do their thing. With the same tires and brake pads, it never felt like that when I was on Tein Flex. I could use way more brake without ABS engagement.
One mistake drivers make (I'm sure I'd still make it if I autocrossed), is to jam the pedal too hard, until they feel ABS or lockup, and then leave the pressure there. You really need "squeeze" the brakes. Smooth out the initial engagement, let the weight transfer, and keep adding more pedal pressure as the weight transfers. To test the pad temp theories, the test is pretty simple. Just take the car out on the street and see if the brakes get better as they get hotter. You can experiment with pedal technique, too. -Mike |
08-11-2009, 07:21 AM | #32 |
Member#: 145277
Brakes
Now that is interesting........... Can you tell us how to fix it? I have tried many things to make the travel smaller. I used to drive VW and Audi and they have a very hard pedal, like stepping on a stone. I upgraded my car (WRX 2007) with 6 piston setup from HiSpec, SS lines front and rear, Pagid pads and the brakecylinder brace but still no change. Yes it does brake but the travel doesn't give me the feel i am in control of braking. On Youtube there is this movie of a testrun with the STI S204. You can see the driver hit the brakes and only press the pedal like 1-2 inches. Mini is more like 3 inches before i actually feel some heavy stopping power. The 204 is as far as i know equipped with the same brakes as a normal STI. But the question is.....is the WRX equipped the same as the STI (besides calipers and discs) Is the brake booster and brake cylinder the same? I really hate the feel of it now. Want to do a major turbo upgrade etc. but not before i know for sure i cant upgrade or change anything on my brakes to increase the "pedal feel" Any information would be welcome. regards Wijnand |
08-11-2009, 07:37 AM | #33 |
Member#: 122980
South East
Its easy. If youre not a n00b, and you understand what youre about to do:
There are two large nuts behind the pedal (forget the sizes), but you can adjust these to take out the slack. If youre adventurous, you can also remove the factory specified free play, but it can (and will) cause your brakes to drag. I had mine set up this way (as little slack as possible with light to no dragging), and as soon as you touch the pedal, it works. |
08-11-2009, 11:40 AM | #34 |
Member#: 1800
NESIC
This is where I'd look if the pads are up to temp and the tires are good. My crappy MY02 WRX with stock brakes, XP10's and Victoracers has incredible stopping feel for a few laps before things get overheated. I found ss lines really did help with feel, but on the street it doesn't feel as connected as many other cars I've owned. Change the MC if that really bothers you.
08-11-2009, 08:46 PM | #35 | |
Member#: 62182
NWIC
-Mike |
08-11-2009, 09:01 PM | #36 | |
Member#: 122980
South East
08-11-2009, 09:02 PM | #37 |
Member#: 98961
Vehicle:2003 WRX Black |
I just adjusted mine to make H&T work best. I have no issues with my brakes. Brembo's and some race pads (Carbo's normally but, soon DTC-60's). Mine will stop the car, every time from whatever speed I'm going limited only by my tires. The feel isn't the greatest but, it doesn't affect my ability to modulate the brakes.
You know, camber will hurt braking. Since I have nearly 6 degree's of castor, I find I need less front camber. I don't actually feel the difference in braking but, it's supposed to make a difference. |
08-11-2009, 11:16 PM | #38 |
Member#: 104922
Vehicle:2016 WRX |
The June 2008 GRM had a pretty good article on "Brake Myths exposed".
School me on PlayOn, Netflix, Hulu, etc. on PS3 | -=C=- | Off-Topic | 14 | 03-02-2010 05:38 PM |
School Me On Brake Master Cylinders. | bushflyr | Brakes, Steering & Suspension | 12 | 10-26-2009 12:31 PM |
school me on taxes on money made from real estate.. | lotusdrift | Off-Topic | 32 | 04-20-2007 04:59 PM |
School me on RS cat pipes | Albert | Normally Aspirated Powertrain | 6 | 12-30-2002 04:14 AM |
Nano: School me on the S-AFC | WRXnFX | Alaskan Impreza Club Forum -- AKIC | 34 | 05-24-2002 02:53 PM |
