10-26-2004, 02:54 AM | #1 |
Member#: 37059
Vehicle:03 WRX World Rally Blue |
glare problem after jdm headlight mod (rhd to lhd)
I did the mod where you grind off the mask to level it off so there's no rising cutoff. However after I installed the headlights back onto my car, there is a heap of light above the actual cutoff beam. I'm wondering if this has anything to do with the shiny metal exposed on the masking plate after you grind it off. I used a sharpie marker to fill in the shiny parts. Is that the problem here?
10-26-2004, 09:55 AM | #2 |
Member#: 22157
Vehicle:'02 WRX '04 350Z Cause We Are The Aquateen |
That could be. I sprayed the area I ground down with flat black, hi-temp paint and I don't remember any glare (I have the lights off of the car for right now). Stanton, the guy who wrote the post for this procedure on Scoobymods, mentioned a glare as well, though, so who knows?
Good luck. |
Problems after JDM v8 intake manifold install | dan avoN7 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 06-19-2005 09:31 PM |
Problem after clearing headlights | spooledwrx | Electrical & Lighting | 5 | 06-10-2005 06:25 PM |
JDM Headlight mod | Brian Broz | Electrical & Lighting | 1 | 04-19-2003 04:51 PM |
JDM headlight mod | aspera | Interior & Exterior Modification | 10 | 11-07-2002 09:54 PM |
replacement glue for after the headlight mod | jimhoyd | Interior & Exterior Modification | 5 | 04-23-2002 07:17 PM |
