Tire & Wheel Forum sponsored by The Tire Rack |
11-02-2005, 05:35 PM | #1 |
Member#: 51674
Vehicle:2005 Subaru WRX STi WRB/GOLD |
Question about tire rotation on 05 STi with stock re070's... *help*
Hey guys, i have 5,600k miles on my stock tires, and i havnt rotated them yet, they are significantly worn (9 autox events, and 2 trackdays) i skipped rotating them 2 times because of the rear tires being cupped from the trackdays. But anyway i think im desperate now to get these things rotated. Take a look at these pictures and tell me if i should rotate them, and if so in what pattern.
either this pattern: OR Here are my tires... sorry about lack of photo quality, but maybe you can help me out. Thanks! front left front left #2 pic (the fronts are identicle, except my front left had some tire flake off from the trackdays, circled in red) rear left rear right
11-02-2005, 06:29 PM | #2 |
Member#: 41762
International
Vehicle:04 STi in ur Floriduh |
I just do front to rear, rear to front, but on the same side. (with directional tires)
070s you could do either of the 2 picts you posted, or just go front to rear. |
11-02-2005, 06:50 PM | #3 |
Member#: 11279
Vehicle:2o11 wrx dgm 2oo8 tribeca swp |
Rotation pattern doesn't make much difference when you are chewing them up that fast. I would just put the one with the most tread on the front left. 2nd most front right, 3rd most rear left. Re-evaluate before your next event if you know you will have a higher percentage of left vs right turns.
11-02-2005, 09:24 PM | #4 |
Member#: 96154
Vehicle:98 2.5RS Red |
Rotation patter from figure B
hehehe:-) |
11-03-2005, 07:19 PM | #5 |
Member#: 1444
I usually did figure C with my RE070. The tires are asymetric, so it doesn't matter which side they are on. However, since you delayed so long, I would put the tires with the most tread on the front.
11-08-2005, 08:29 PM | #6 |
Member#: 96540
Vehicle:2006 STI Crystal Metallic |
you probly need to run a little more tire pressure when autox. time for new tires
Needed Help: Will 215/50/17 Snow tires fit on 05+ STi BBS ? | Linkseal | Vancouver Impreza Club Forum -- VIC | 5 | 12-03-2007 11:53 PM |
Quick Question about Tire Size On Stock Rim | aren040 | Tire & Wheel | 9 | 05-04-2006 10:33 PM |
Dumb question about tire rotation? | banman | Tire & Wheel | 1 | 11-12-2005 03:47 PM |
?? About Advan Rg On 05 Sti | cusco4life | Tire & Wheel | 6 | 03-24-2005 04:08 AM |
question about tire rotation | FloridaWRX | Brakes, Steering & Suspension | 5 | 08-18-2001 07:41 PM |
