02-25-2009, 02:24 PM | #1 |
Member#: 176845
Vehicle:2004 Subaru Sti Blue |
Help with NGK Iridium Spark plugs one step colder # 6 for my 04 STi?
I am going to do a 30,000 mile tune up for my 04 STi, was told to buy NGK Iridium one step colder Spark plugs # 6. But when i try to look for them online i find 2 different plugs, the BKR6EIX NGK Iridium IX and the BKR6EIX-11 NGK Iridium IX SPARK PLUGS. I am not sure which is the right one to get, or if they are the right number 6 spark plug for my car. If anyone knows more about this please help me out. Thanx
02-25-2009, 02:25 PM | #2 |
Member#: 111641
Vehicle:2020 CWP STi RIP - 06' WRX w/ 6spd |
What are your mods? Chances are you have no reason to be going 1 step colder.
02-25-2009, 02:27 PM | #3 |
Member#: 176845
* HKS Hi-Power TI Carbon Catback Exhaust
* Invidia Down-pipe * Cusco Headers * Blitz Intake * Greddy Blow off Valve * Utec Turbo XS ECU * Lightweight Pulleys |
02-25-2009, 02:29 PM | #4 |
Member#: 108547
SWIC
Vehicle:2017 Tundra 1794 Lifted, Armored, Muddy AF |
Stock plugs are fine with those mods my friend!
02-25-2009, 02:29 PM | #5 |
Member#: 200955
Vehicle:2005 A slow STi |
With those mods you have you're fine with OEM spark plugs. If you're just doing a 30K check-up then you don't need step colder plugs, just replace with another set of new OEM's.
Check this thread also, it helps: http://forums.nasioc.com/forums/showthread.php?t=518633 |
02-25-2009, 03:02 PM | #6 |
Member#: 176845
ok thanx , but between BKR6EIX NGK Iridium IX and the BKR6EIX-11 NGK Iridium IX, which should i get?
02-25-2009, 03:07 PM | #7 |
Member#: 125600
South East
Vehicle:2005 STi perrin stg2 World Rally Blue |
have you looked at the condition of the plugs? i pulled mine at 50k and they looked almost new, so i didn't replace them...just a thought
02-25-2009, 03:09 PM | #8 |
Member#: 108547
SWIC
You will be sacrificing some power, increasing emissions, decreasing plug life, etc running one step colder when they are not needed. If you really feel that you must have one step colder, a good vendor to snag them from is linked below and eliminates needing the part number. Also check out this sticky.
Sticky: http://forums.nasioc.com/forums/showthread.php?t=518633 Vendor: http://fastwrx.com/denirsparplu.html |
02-25-2009, 06:39 PM | #9 | ||
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
DO NOT USE THESE!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11 1!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1 THESE SPARKPLUGS ARE FOR THE 2.0T OR 2.5NA ENGINE IN THAT ORDER AND SHOULD NEVER BE USED IN ANY USDM 2.5T SUBARU ENGINE!!!!!!!!! USE THE STOCK HEATRANGE PLUGS....THEY ARE JUST FINE FOR 90% OF ALL APPLICATIONS http://www.ngk.com/more_info.asp?AAIA=1432600&pid=17367 Last edited by Uncle Scotty; 02-26-2009 at 01:21 AM. |
02-26-2009, 11:42 AM | #10 |
Member#: 176845
Thank you for the feed back, i guess il just get the oem plugs.
New NGK Iridium spark plugs one stop colder BKR7EIX, new Actron compression tester | fastwrx25 | Engine/Power/Exhaust | 4 | 06-26-2008 09:37 AM |
Brand New NGK Iridium spark plugs one step colder | DaFastOne | Engine/Power/Exhaust | 1 | 06-06-2007 01:25 PM |
NGK Iridium IX, is one step colder ok?? | Visco212 | Service & Maintenance | 4 | 09-26-2005 12:06 PM |
NGK Iridium IX, is one step colder ok?? | Visco212 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 09-22-2005 10:17 AM |
FS: New Denso Iridium spark plugs 1 step colder and used Samco intercooler hoses | scoobyhugh | Tri-State Area Forum | 3 | 02-02-2004 07:34 AM |
