07-23-2004, 07:18 AM | #1 |
Member#: 2181
SCIC
Vehicle:2003 Forester XS |
EJ18 to EJ25 swaps with 4EAT?
Has anyone put a EJ25 into a 4EAT trannied EJ18? I wonder what the stall point will be if I bolt the EJ25 onto the small 1.8 torque converter? I'm sure the stall point will be higher, but by how much?
07-23-2004, 10:52 AM | #2 | |
Member#: 58353
TXIC
Vehicle:99 Mercedes-Benz E430 |
_Rick |
07-23-2004, 02:04 PM | #3 |
Member#: 2181
SCIC
No. The final stall speed will be affected by the torque output of the motor, the overall gear ratio, and the weight of the vehicle. That's why the ads always say something like '500rpm higher than stock', rather than give an actual number.
07-23-2004, 04:59 PM | #4 |
Member#: 58353
TXIC
well...there ya go. I learned something today
07-23-2004, 11:41 PM | #5 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
Since the 2.5 will be making more torque, the stall speed will actually be lower. That is, if past experience with superchargers holds true.
Jay Storm |
07-24-2004, 01:42 AM | #6 | |
Member#: 2181
SCIC
I was thinking back to when I had a vehicle with a 2.8l V6 and raised the stall speed by fitting a converter from a 2.0l 4-cyl version. That raised the stall speed about 4 or 500rpm. |
07-25-2004, 03:48 PM | #7 |
Member#: 5218
I guess the only way to tell is to just go ahead with it.
Jay Storm |
07-25-2004, 10:28 PM | #8 |
Member#: 2181
SCIC
Found this quote on Protorque's site: Torque Converter Fact & Function First, you need to understand the functions of a torque converter. One of the jobs of the converter is to act as a fluid coupling from the motor to the transmission. Another, and a very important function, is torque multiplication. What remains is stall speed, a very misunderstood term. Stall speed is directly related to the amount of torque your engine produces (the greater torque, the higher the stall speed). For example, a converter with a 2800 to 3200 rpm rating might provide approx. 3200 rpm of stall speed behind the big block making 500-plus lbs of torque and in a small block with less torque it's possible to only have a stall speed of 2800. Without knowing how much torque your engine produces, you cannot know how much stall speed a converter is capable of. Linky |
08-29-2005, 01:01 PM | #9 |
Member#: 2181
SCIC
Well, after a lot of procrastination, I finally swapped the engine.
A 1.8 converter behind a 2.5 does not appreciably raise the stall point, no more than 100~200rpm. I get a less creep at idle, but that's about it. The smaller converter definately has less moment of inertia, so there's less flywheel effect. |
08-29-2005, 01:32 PM | #10 |
Visiting NASIOC Timeout
Member#: 9093
Vehicle:1995 RHD STi RA Ver2 swap starr |
hmm. neats. u are the second guy i know with a EJ25 + 18 auto. whats your setup like?
08-30-2005, 12:40 AM | #11 |
Member#: 2181
SCIC
Was a MY'00 phase II EJ18 with 4EAT, now it's an '05 or (more likely) '06 EJ25 from a JDM Outback 2.5i with my original 4EAT, converter et al. AWD.
I'm using everything from the original engine except the shortblock with heads, timing belt, belt tensioner and fuel injectors. ECU is stock with an emanage. On the chassis side I have the '01 RS wheels, RE928s, '02 WRX front and rear brakes, AGX struts and ver.5 springs. |
10-18-2006, 06:01 PM | #12 |
Member#: 108790
SCIC
Vehicle:2002 WRX 2.2 Wagon PSM |
Hi, I am putting '05 EJ205 w/auto ECU in '00 RS auto. Did you need anything special to do swap? Thanks.
Ej18 to ej25 parts swap | ralliboi | Normally Aspirated Powertrain | 2 | 04-28-2008 07:09 AM |
Ej18 to ej25 swap, idle issue | Qaveboy | Subaru Conversions | 0 | 05-30-2006 02:18 AM |
EJ18 -> EJ25 swap, leftover parts. | 83Rabbit | Mid Atlantic Impreza Club -- MAIC | 4 | 10-03-2005 03:21 PM |
EJ18 to EJ25 NA swap q's? | left footed whooten | Subaru Conversions | 3 | 09-30-2005 03:11 AM |
EJ18 to EJ25 (DOHC '98) swap wiring / vacume Quest. | supermoose | Subaru Conversions | 1 | 05-25-2003 01:42 AM |
