06-09-2009, 12:15 PM | #26 |
Member#: 81631
06-09-2009, 01:00 PM | #27 | |
Member#: 4498
Vehicle:WRX H6-3.0 Turbo www.surgelinetuning.com |
The 2.5L runs (all of them) were without Torco. Jeff |
06-09-2009, 01:01 PM | #28 |
Member#: 199879
Vehicle:2009 Forester FXT |
Hi Jeff
i have a td05-18g right now on my 2.5 4eat, not worth it to sell my turbo for the hta68 ? |
06-09-2009, 01:05 PM | #29 |
Member#: 63767
Vehicle:2009 OXT 5-spd 2011 STi hatch |
Ah, Unabomber does not think that my data-logging of raw intake temps is very useful without A/F. I guess I might not be informed enough about what the intake temp reading vs. what the car does with this reading vs. the actual air charge temp. means in the grand scheme of things. I just know what I logged from my thread mentioned above and as Jeff pointed out this was something that can be corrected on the dyno but maybe not on the street? I just know that on the street, without the fog cover off, the intake seems to be really hot.
More testing to come. Maybe if I ask really nicely I can get Tim and Jeff to tune with different intakes since they are easy to swap out and do some "real" data logging on the street to see if there is carry over. I would like the AEM to work. The general fit and finish of the product rocks. Last edited by tazswing; 06-09-2009 at 01:55 PM. |
06-09-2009, 01:13 PM | #30 |
Member#: 102808
Vehicle:1995 Built EJ207 6sp 30r ***break in*** |
06-09-2009, 01:20 PM | #31 | |
Member#: 44422
SWIC
Vehicle:2009 G8 GT Cammed, sprayed, stalled |
Did you tune the engine load/ RPM/ MAP table? This is very different than the older years and has up to 20% correction at 2600-3200 RPM, slight vacuum range. I have been playing with this table in my 08 with RomRaider and have made the hesitation better, but it is still there. I have stock injectors and intake BTW. |
06-09-2009, 02:22 PM | #32 |
Member#: 127704
TXIC
Vehicle:2015 Boosted Stang MAP tuned |
Like to see that result.... thats my possible route, Im on E85 now with the VF but have ran a 20G also previously on the corn, be an 'interesting ' combo I feel
06-09-2009, 04:39 PM | #33 |
Member#: 14116
06-09-2009, 04:56 PM | #34 | |
Member#: 81631
06-09-2009, 08:52 PM | #35 |
Member#: 30077
TXIC
Vehicle:2004 WrongWayParked WRB WRX Wagon HTA68 |
If the 2.0L is the Blue Wagon then this my car and its running a ssac fmic.
Its very responsive on the street and very deceptive on how much power it has. The power is so linear that you dont realize how fast the car is going and even at the top end it still wants to go on. |
06-10-2009, 10:54 AM | #36 | ||
Member#: 63767
06-11-2009, 12:02 AM | #37 |
Member#: 28291
RMIC
Vehicle:2015 WRX |
jeff, i was wondering if you could comment on the sudden change in slope of the HTA's boost at around 3250rpm. From 2000-3250rpm, it looks like the boost is building at nearly the same rate as the 18g, and then at 3250 it takes on that weird plataeu shape for ~750rpm. i don't see the same thing happening on the 2.5l. do you think this might have been a boost leak or maybe something funky with WGDC / WG spring pressure?
06-11-2009, 05:59 PM | #38 |
Member#: 30077
TXIC
Interested in that myself.
06-16-2009, 11:07 AM | #39 |
Member#: 63767
Well, it is done. Revised 92oct. tune and an E85 map as well. All will be posted with dyno graphs if I know Tim and Jeff and also this is not my thread!!
I want to "publicly" thank Tim for the tune last night. I got out of there after 9pm and Tim still had to close. We had fun seeing what this turbo can do on stock internals with 80 degree shop temps. The intercooler stayed just that throughout the tune so that is good news. My new T-shirt will read: IloveE85. Cheers! |
06-16-2009, 12:20 PM | #40 | |
Member#: 67608
-Adrian |
06-16-2009, 12:35 PM | #41 | |
Member#: 4803
Tim |
06-16-2009, 03:40 PM | #42 |
Member#: 63767
Ok, think I got the graphs correct now.
Ok, here we go: Mod list: DW850, WB255pump, Perrin two-cat DP, Borla CB, AEM CAI, FP HTA68 turbo, colder plugs, Motul 10W-40, around 80 degree shop temp, foglight cover removed, no heat shield on the AEM. 2008 STI, stock internals hence the boost not over 22psi. First is the tune with and without the catback. Nothing else was changed mechanically speaking between these two tunes. This is the Borla system. This is 92 Octane full boost (S#) vs. E85 full boost (S#): This is 92 Octane full boost (S#) vs. E85 low boost (S). Very cool since you can essentially make the same power with E85 with much less boost: Here we have both maps for the E85 tune presented (S# and S): Last edited by tazswing; 06-16-2009 at 04:43 PM. |
06-16-2009, 03:42 PM | #43 |
Member#: 63767
Here we have lower boost setting for both fuel types (S:92 and S:E85):
The car remains highly drivable with the E85 tune. I can just putts around town in S# E85 and the car is, well, civil. This platform also delivers that power is a very predictable and drivable way when you get on it as well. Fun little chirps from the tires Anzen615s, too. I cannot comment on driving the 92 octane map yet since we rolled from one fuel type to the other without removing the car from the dyno. I will let Tim and/or Jeff comment on the technical side of things (what was found with +/- timing and boost tuning tuning, etc). Last edited by tazswing; 06-16-2009 at 04:28 PM. |
06-16-2009, 03:52 PM | #44 |
Member#: 99442
International
Vehicle:2006 SGM STI I'm on CORN YO! |
I am assuming that the HTA turbo has a 2.4" inlet? Is it possible to get a 3" inlet with this turbo? I have been kicking around the 20g idea for a while now and haven't made teh plung yet. The HTA beign as cheap as it is makes me think twice. I was going to go with either the TD05-7cm^2 EWG or the TD06-8cm^2 both coming with a 3"inlet. Now I am so confused....
06-16-2009, 04:01 PM | #45 | |
Member#: 63767
06-16-2009, 04:05 PM | #46 |
Member#: 155489
Vehicle:07 STi |
I can't see the graphs...?
06-16-2009, 04:08 PM | #47 |
Member#: 63767
06-16-2009, 04:53 PM | #48 |
Member#: 63767
Graphs are all up. Also, anyone local just hit me up with a PM and we can try and meet up for a ride if you want to feel the car first hand.
06-16-2009, 05:04 PM | #49 |
Member#: 99442
International
06-16-2009, 05:08 PM | #50 | |
Member#: 102808
FP doesn't offer this in a 3". so your answer is no. all you can do now is compare and compare, keep on comparing, and choose whatever you can get the "better" price on etc. |
Similar Threads | ||||
Non-Subaru Cobb Tuning/Surgeline Tuning EVO X | Cobb Tuning | Member's Car Gallery | 12 | 03-08-2009 06:17 PM |
06/11/08 AK RACEWAY PARK PRE-REGISTRATION FOR SS X-3 (Free class and test & tune incl | missiceblast | Alaskan Impreza Club Forum -- AKIC | 20 | 06-23-2008 10:26 PM |
Tim Bailey of SurgeLine Tuning in Santa Clarita YimiSport Tuning | Cobb Tuning | SCIC Vendor Classifieds | 140 | 01-30-2008 02:36 PM |
Solo Nationals Warmup and Test-n-Tune - Sept. 7 at SGMP (Ga.) | wrx2.0 555 | Motorsports | 11 | 09-04-2007 06:02 AM |
Video is up! DB meet and Test & Tune Vid | xenonk | Mid Atlantic Impreza Club -- MAIC | 4 | 03-31-2004 08:59 AM |
