02-06-2008, 10:11 AM | #151 | |
Member#: 154444
Vehicle:2008 08 STi, Typhoon 06 STi, 847-960-8676 |
you beat me to it, I was just about to mention that the 32 bit ECU does have a clutch pedal switch that goes to the ECU.
02-06-2008, 10:15 AM | #152 |
Member#: 31016
Vehicle:2016 Focus RS (blue) 2005 WRX Wagon (white) |
When will an enginuity (aka RomRaider) XML fix be released so us linux users can have a go at this?
02-06-2008, 10:53 AM | #153 |
Member#: 122365
Vehicle:2015 WRX STI Limited Ice Silver |
A pro you missed for ignition cut based LC is for nitrous users. They'll blow their engine right quick with a fuel based cut.
I agree though, 32bit LC should be done first before anything else. |
02-06-2008, 11:10 AM | #154 |
Member#: 154444
if you run a clutch pedal enabled relay then your safe, that way when the clutch is pushed in the nitrous is disabled
02-06-2008, 11:24 AM | #155 | |
Member#: 62941
Vehicle:2004 #LesboRacer #TunedbyBarge |
I'll let you know how it goes. |
02-06-2008, 11:50 AM | #156 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag 9.8@150 |
Donation sent, and you don't even have it for my car yet. Keep up the good work.
02-06-2008, 12:13 PM | #157 |
Member#: 129905
AKIC
Vehicle:2005 WRB WRX 2003 F-350SD, 7.3PSD |
I've got a 05 USDM, I downloaded the patch.. but my rom files are only 160k.. whats the deal?
02-06-2008, 12:35 PM | #158 |
Member#: 154444
02-06-2008, 12:46 PM | #159 |
Member#: 157532
Vehicle:2002 MY03 EJ207 E85 Dom 1.5XTR Twinscroll! |
02-06-2008, 12:49 PM | #160 |
Member#: 129905
AKIC
02-06-2008, 01:27 PM | #161 |
Member#: 15822
Vehicle:1999 WRB GM6 2.34 LR destroker |
File>File convert functions>convert 160 to 192
you don't need to do that anyway, ecu takes both these formats |
02-06-2008, 01:35 PM | #162 |
Member#: 154444
yep its that easy you don't even have to open the ROM file you just fo the the convert function and then click on the file you want to convert...the patch only works as they said for the larger file size 192k so even though the ECU will take both the patch will only work on the 192k file as stated in the how-to
02-06-2008, 01:58 PM | #163 | |
Member#: 35076
TXIC
Vehicle:2004 507whp Wagon Silver |
Tiny - Thanks for the 04 WRX patch! Can't wait for th 03 and upcoming 32-bit patches! |
02-06-2008, 03:01 PM | #164 |
Member#: 115819
Vehicle:2006 vf39 R0mRa1DeR Darknessess Wagon |
Xswrex, will these patches be compatible with the groundwork laid for enginuity/romraider RAMTune? I've read through all the threads on it, and it seems like LC is to be integrated.
As in, are you running the same offsets for the values and code as the 16bit test releases? Last edited by ExpO; 02-06-2008 at 03:07 PM. |
02-06-2008, 03:05 PM | #165 | |
Member#: 108089
Vehicle:2003 WRX NF Performance |
did your speed threshold show up at 158mph and rpm delta as 12800rpm? |
02-06-2008, 03:15 PM | #166 | |
Member#: 87255
Vehicle:2002 Impreza WRX given up emptying PMs... |
I have not seen any ramtune enabled rom, although i have asked for it from the enginuity team in the past in order to test and further develop. sorry i dont get what you mean by this...which test releases? |
02-06-2008, 03:18 PM | #167 |
Member#: 87255
02-06-2008, 03:40 PM | #168 |
Member#: 114528
Vehicle:2002 Space Shuttle Discovery |
I know this is sorta off topic, but have you guys heard of gizzmo electronics? (http://www.gizzmoelectronics.com/Pro...Interface.html) They have launch control via ignition cut, and has the ability to do flat foot shifting.
Now according to gizzmo it's compatible with all subarus. So 16bit, and 32bit ecu are able to run this. My question is, since a 16bit ecu doesn't have that ability to monitor the clutch switch, is there a way to rig something up that would allow the ability to monitor it? If this was covered already please excuse my no0b-ness |
02-06-2008, 04:26 PM | #169 |
Member#: 35076
TXIC
Donation sent as well!
Nuke - All of my roms show up at 0/0 for the defaults. |
02-06-2008, 04:44 PM | #170 |
Member#: 108089
I meant, the unpatched ones.
02-06-2008, 05:08 PM | #171 |
Member#: 121116
W. Canada
Vehicle:2004 WRX v7 w/VF30 |
Tested and working on A4TF520F ('04 USDM WRX). Thanks xswrex!
Donation made! Jeff |
02-06-2008, 05:33 PM | #172 |
Member#: 156973
International
Vehicle:2002 ADM WRX STi STi Black/Blue |
I just had a thought (I know they are sometimes a little silly and outside the box )
I was looking through Enginuity and noticed a heap of other switches that are monitored - what if I was to use one of these monitored switches in place of the clutch switch? ie. rewire the clutch switch to use one of the "not important" monitored switches. |
02-06-2008, 05:45 PM | #173 |
Member#: 154084
looks good !
02-06-2008, 06:10 PM | #174 | ||
Member#: 122365
02-06-2008, 06:12 PM | #175 |
Member#: 35076
TXIC
Similar Threads | ||||
Launch Control on 2004 WRX | Doomsti | AccessPort | 18 | 11-16-2012 03:16 PM |
Launch Control on 32bit ECU | Nuke209 | Open Source Reflashes | 126 | 05-17-2008 10:49 AM |
Help with wiring in launch control on an 05 WRX. | Sir Wagon | UTEC | 2 | 03-07-2008 04:45 PM |
Failed NY state Inspection because of Launch Control on UTEC? | vipernj | Engine Management & Tuning | 2 | 01-24-2006 06:10 PM |
utec remote switch launch control on 4eat | topgrinder | Engine Management & Tuning | 1 | 03-27-2003 08:34 PM |
