Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 10-11-2013, 12:30 PM   #1
silverbullet830
Member#: 155658
2010 WRX Sedan
So last weekend I installed a Motive Autowerks 3 port EBCS, and I've been over boosting ever since. I've double checked all connections and its hooked up right. 1 to intake, 2 to actuator, 3 to boost. Even with WGDC zeroed out it still hits the fuel cut just over 20psi (boost target) at around 4000 rpm. Am I missing something? I can post a log when I get home if needed. Really not sure on this one what it could be. Bad valve maybe?
edit:
Car is a 10' wrx with Nameless catless DP and muffler deletes, Cobb ap, forge splitter valve. No other engine mods and was running fine before the ebcs.
silverbullet830 is offline   Reply With Quote
Old 10-11-2013, 07:48 PM   #2
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Maybe this will help. Includes some diagrams.
http://www.cobbtuning.com/Technical-...es-s/70674.htm
Old 10-11-2013, 08:16 PM   #3
bjohnson_55
Member#: 216580
bjohnson_55 is offline   Reply With Quote
Old 10-11-2013, 10:03 PM   #4
JonnyV2889
Member#: 197384
2006 WRX Ltd
Originally Posted by bjohnson_55 View Post
Engine management?
JonnyV2889 is offline   Reply With Quote
Old 10-12-2013, 06:23 AM   #5
Tripintaz
Member#: 245218
2013 STI Limited
LoL let me guess. You did not tune for this did you?
Old 10-12-2013, 08:54 AM   #6
silverbullet830
Member#: 155658
2010 WRX Sedan
Uh yeah. The part where I said "even with wgdc zeroed out". Cut them by 50% and then kept removing more and more, 10-20% at a time when it still over boosted. When it started getting pretty low I tested it by zeroing out the whole wgdc low and high maps above 2400 rpm, and there was still no change.
Old 10-12-2013, 10:29 AM   #7
JonnyV2889
Member#: 197384
2006 WRX Ltd
Sounds like it's either:
A. Hooked up incorrectly
B. You zeroed the wrong maps
C. The device is defective.
You can test the valve by hooking it up to 12v. It should click/actuate. Not much to go wrong with them, its just a coil.
Old 10-12-2013, 12:58 PM   #8
silverbullet830
Member#: 155658
2010 WRX Sedan
well there's only 2 (high/low) wgdc maps that aren't compensation maps so I think I got that right. I had been experimenting with my tune previously. I'll take the valve off here in a bit and test it and go from there I guess. Make sure its flowing the right way and all. Thanks for the input!
Old 10-12-2013, 05:10 PM   #9
silverbullet830
Member#: 155658
2010 WRX Sedan
so I found a cut in the brand new vacuum hose coming from the pressure side of the turbo. The boost pressure wasn't reaching the valve. On another note I tried a few maps I had made along the way, and ended up with the Stage 2 OTS map being the best running one. I really didn't have to anything to it, logs look pretty good.
