Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 09-18-2015, 11:31 PM   #7026
PARANOID56
Member#: 22035
2014 Brocoma DCab
71 FJ40, 13 DRZ400SM
oh look another huge 160lb box. my ups man loves me. new th350 4x4 tranny as i all the quotes i got to rebuild mine and convert it to 4x4 was only a 100 buck cheaper then buying new
(does the below pic work?)
PARANOID56 is offline   Reply With Quote
Old 09-18-2015, 11:54 PM   #7027
Damon
Member#: 2902
Originally Posted by Sideshowbob View Post
bronco buster?
Damon is offline   Reply With Quote
Old 09-20-2015, 04:45 PM   #7028
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
Nice shot of the CJ in it's natural habitat:
Neek is offline   Reply With Quote
Old 09-21-2015, 06:33 PM   #7029
pdxsilverwrx
Member#: 54935
I ended up going with the 4:56 gears. I picked my Jeep up Thursday from the shop. I did not know about gear break in. I had to keep it under 60 and stop every 20 miles to let the differential cool down. It took me forever to get home. At first I was wishing I had done the 4:10 gears. The rpms seemed kind of high on the freeway . I took the Jeep up to the woods on Saturday. Nothing to crazy but I tried a couple of obstacles. I love the way Jeep drives off road now. The Truetracs work great and engine seems to be in the fat part of the torque curve when I need power.
pdxsilverwrx is offline   Reply With Quote
Old 09-21-2015, 08:51 PM   #7030
Notch 8
Member#: 355254
If you haven't changed the gear oil in the diffs yet, do it. It should be done after a few hundred miles. It's also a good idea to drive in reverse for a few miles before changing the gear oil. If you're super particular, pull the diff covers off and check the gear pattern. As someone who's installed numerous gear sets, I personally wouldn't trust many people to set up my gears. Lubelockers.Get them.
Notch 8 is offline   Reply With Quote
Old 09-21-2015, 08:56 PM   #7031
Notch 8
Member#: 355254
Added to the above, I meant I wouldn't trust many people to set up my gears without checking their work to make sure it was done properly.
Old 09-21-2015, 10:10 PM   #7032
pdxsilverwrx
Member#: 54935
The gear manufacturer, Yukon, says to wait until they have 500 miles on them. That will take me awhile. I don't even drive 5 miles a day.
Old 09-28-2015, 11:58 AM   #7033
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Originally Posted by Damon View Post
bronco buster?
Hmmm I think it was Test Tube? Not sure because our "leader" was a bit clueless plus the trail marking is all over the place.
Bronco Buster was closed, major recovery with a powerless rig.
Sideshowbob is offline   Reply With Quote
Old 09-28-2015, 12:19 PM   #7034
Slow5oh
Member#: 70698
wait until I go
up a hill...
The trail signs get stolen a lot according to the guy at the front last time I was there. They need to figure out something because I won't be going back until they fix the problem. It's super ****ing annoying not being able to find or stay on a trail.
I'll be home on Friday and can finally start sharing pictures from my trip. It's too damn hard to do from my phone.
Slow5oh is offline   Reply With Quote
Old 09-28-2015, 02:01 PM   #7035
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Not sure why they don't just label trees the actual trails so you know what you are on. It is super annoying.
Old 09-29-2015, 11:07 PM   #7036
PARANOID56
Member#: 22035
2014 Brocoma DCab
so decided to shorten the long side of my dana 60. it was stupid wide and the spring perches were to wide and would make me need to make 6" frame extensions on each side to make it work. So cutting off 5" off one side and will get a custom axle shaft made
noting like cutting the C off. some thick ass axle tubes.
then beat the inner part out so i can slip it over the axle.
Old 09-29-2015, 11:18 PM   #7037
turntable
Member#: 103622
damn that's thick. what did you use to cut it?
turntable is offline   Reply With Quote
Old 09-29-2015, 11:24 PM   #7038
PARANOID56
Member#: 22035
2014 Brocoma DCab
off the axle i used my portaband, then to make that inner slice a sawzaw. then i decked the rear surface flat to git rid of the weld with my mill. all in all about an hour or so of work.
now trying to figure out R&P rations for the axles.
Old 09-30-2015, 12:14 AM   #7039
White out
Member#: 46277
H1 Viper
LP640 FGT
White out is offline   Reply With Quote
Old 09-30-2015, 09:45 AM   #7040
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Cool H1!
Nice. Wow that is a ridiculous axle tube!
Old 10-02-2015, 11:07 PM   #7041
PARANOID56
Member#: 22035
2014 Brocoma DCab
and 99% finished, just all heavy tacked into place, and will fully weld it after i know its right. was a lot easier then i thought it would be.
Old 10-04-2015, 11:53 PM   #7042
PARANOID56
Member#: 22035
2014 Brocoma DCab
and done.
rear hanger.
Old 10-16-2015, 01:29 PM   #7043
shikataganai
Member#: 92634
Spotted driving north on I-25 last night:
Jeep Cherokee 2 door, matte black paint, terrible, dim aftermarket tail lights. That part isn't interesting. What is is that it appeared to be on full length 1 ton axles or the like, with what had to be at least 37"s if not 40"s. It was kind of comical looking.
shikataganai is offline   Reply With Quote
Old 10-16-2015, 02:24 PM   #7044
Rattler
Member#: 6351
2004 Tacoma 2xCab
\m/ \m/
I find fullsize axles under Jeeps kinda hideous too.
I was out running some errands today and happened by my Toyota dealer. They had a couple '16 Tacomas out front so I stopped to check them out. A sales-vulture came out to see what I was up to. He said they had one of the Desert Sand Mica doublecabs getting prepped. I have to say, I really am starting to like that color. I got to see the interior up close too. I live that a lot better than the last gens by far. It was pretty much like this one.
Rattler is offline   Reply With Quote
Old 10-16-2015, 02:55 PM   #7045
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Full Width is function over form, deal with it. I plan on 42's on 2-3" of lift on full width 1 tons. It's for people who are want the maximum crawling ability and durability.
Old 10-16-2015, 03:36 PM   #7046
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
My favorite comical Jeep, Rango (aka the Clown Car)-
http://www.pirate4x4.com/forum/jeep-...willys-mb.html
Old 10-18-2015, 04:07 PM   #7047
ParkedWRX
Member#: 286101
'11 WRX
Just joined you jeep owners. Picked this puppy up yesterday. Soon to be a mall crawler.
ParkedWRX is offline   Reply With Quote
Old 10-18-2015, 07:53 PM   #7048
Furiousd1983
Member#: 295099
2017 Wind-up car
Gray
Default The Jeep and Off-Road Thread
Was in Boone NC today and had to stop by Rubitrux to look at the eye candy.
Tank Brute Double Cab 6.4 Hemi... $119k
That ****'s Bananas B-A-N-A-N-A-S
Furiousd1983 is online now   Reply With Quote
Old 10-18-2015, 11:31 PM   #7049
PARANOID56
Member#: 22035
2014 Brocoma DCab
well got a little more done on the fj40.
up/downgraded to 3/4 ton brakes then used wilwood sliders on it. super bling
also got my new rear driveshaft. 1410 ujoints and cv setup. should hold up well
Old 10-21-2015, 01:05 PM   #7050
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Beefy!
with all the gay and straight threads [27] Off-Topic 27 05-08-2013 06:31 PM
the Official Rally/Off-Road thread? Longitude Member's Car Gallery 178 09-05-2006 05:39 PM
Why all the bestiality and dehydration threads today??? Grap Off-Topic 15 01-11-2006 03:55 PM
this site is dwindling (aka: The piss and moan thread v.2) stevedood Bay Area Impreza Club Forum -- BAIC 59 04-01-2004 12:38 AM
A lazy monday thread...A continuation of the saturday and sunday thread DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 9 09-10-2002 08:17 AM
