06-13-2012, 12:58 PM | #1 |
Member#: 322044
JDM EJ20G Gates Timing belt.... which one?
I looked up on the website from Gates and I saw 2 different timing belts available for my engine...one was the T277 standard belt, the other was the T328RB racing belt... I would prefer the second choice but wanted to know which is the one that the emgine needs incase of some kind of issue(s).
Thanks. |
06-13-2012, 12:59 PM | #2 |
Member#: 322044
Oh and the year of my engine is 96-98 EJ20G
06-14-2012, 01:50 PM | #3 |
Member#: 164172
Vehicle:97 OBS EJ20G ZILLA 87 GL |
they both work. i have a 20g with the racing blue gates belt. i think its from a 02-03 wrx. prettyyy sure they are all the same dohc
06-14-2012, 03:04 PM | #4 |
Member#: 6886
Vehicle:MY01 EJ207 HTA35r AVCS ON! |
06-14-2012, 08:40 PM | #5 |
Member#: 76586
RMIC
Vehicle:2006 9-2x Aero |
277 and 328 are the same. 328 has the Gates Blue belt option (328RB) that is 1mm wider.
06-14-2012, 02:03 PM | #6 |
Member#: 169257
Vehicle:00 rsti & 04 fxt millenium jade |
I am pretty sure the belt is the same across all the dohc. I have been using one for the usdm sti for a couple years now with no problem.
06-14-2012, 09:10 PM | #7 |
Member#: 322044
great.... thanks for the help guys.
04-30-2013, 12:48 AM | #8 |
Member#: 254547
VIC
Semi-grave bump, but for clarification on the JDM EJ20's, are all the tensioners, idlers, water pump and seals the same across the board as well?
I'm trying to piece together a timing belt kit for my install, but I've been reading a bunch of different information. Last edited by iRomey; 05-02-2013 at 06:54 AM. |
04-30-2013, 01:01 AM | #9 |
Member#: 341540
I just bought the Gates TCK277 kit for the 1996 2.5L DOHC Legacy. It has the older style tensioner pulley (which mine has, 1993 WRX). All the pulleys are the same and the belt is the exact same size with the marks in all the correct places.
I also used a thermo/water pump from 02 WRX, it fit perfectly. Last edited by NewWRXMike; 04-30-2013 at 01:07 AM. |
04-30-2013, 01:00 AM | #10 |
Member#: 206851
Vehicle:56 Belair Pro Street |
you can use any timing belt and any tensioner. you can intermix whatever you'd like.
order the tensioner from a ej22e and the belt from a 02 wrx |
05-01-2013, 10:38 PM | #11 |
Member#: 31639
RMIC
Vehicle:99 Impreza White |
I used the blue 328RB on my ej20g and I used the old style tensioner as I heard it is more reliable.
05-02-2013, 01:44 AM | #12 |
Member#: 254547
VIC
Single piece or two piece, it's good to know I can use both
05-02-2013, 10:31 PM | #13 |
Member#: 31639
RMIC
Don't forget to do the waterpump, thermostat and crank seal at the same time. Get some clamps to hold the timing gears in place too, that's what took me the longest, the timing gears kept slipping after I set them.
05-12-2013, 06:59 PM | #14 |
Member#: 254547
VIC
So, I compiled my timing belt parts list for my early EJ20G.
x1 - Gates Racing Timing Belt- GATE-T328RB x1 - Older Tensioner, EJ22E/T, EJ18- 13068AA051 x2 - Smooth Idler Pulleys- 13073AA142 x1 - Toothed Idler Pulley- 13085AA010/80 x1 - Water Pump- 21111AA026 x1 - Water Pump Gasket- 21114AA030/51 x1 - Thermostat and Gasket- 21210AA030 x4 - Cam Seal 806732150 x1 - Crank seal - Front- 806733030 x1 - Crank seal - Rear- 806786040 I recall needing 4 pulleys, but I only listed 3. Can anybody tell me if I'm missing anything? |
Similar Threads | ||||
Gates timing belt kit, which for my needs? | Whoa!ShutItDown | Service & Maintenance | 1 | 11-06-2011 05:04 PM |
STI timing belt, or gates timing belt? | matt.nbg | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 06-03-2011 09:44 PM |
Time for timing belt / which one? | explosivo | South West Impreza Club Forum -- SWIC | 13 | 12-14-2010 02:48 AM |
'94 JDM EJ20G... What timing belt? | Subarutex | NWIC Private Classifieds | 5 | 10-25-2006 09:04 PM |
SOHC 2.5L (EJ25) Gates timing belt for sale | Atwood | Private 'For Sale' Classifieds | 0 | 09-03-2005 01:08 AM |
