10-08-2007, 08:39 PM | #1 |
Member#: 87327
South East
Vehicle:2017 Heron White SS OG Thread Killa |
Calculating the effects of larger wheels and tires, and loss in performance
I was wonder if there's a good formula out online that calculates the effects of increased wheel/tire mass, diameter and rolling resistance, in relation to performance, mainly acceleration.
I remember once stumbling across an Excel spreadsheet that someone had put together in an autocross forum that was pretty good at calculating values that were easy to assess power/performance loss. On my 06 WRX, going from stock 215/45s (24lbs IIRC) on the stock 17 wheels (aprx 21lbs IIRC), to a 245/40 on 17x8s (weighing 27 and 21 lbs respectively) with only a .10" increase in diameter and I noticed quite a noticeable degradation in acceleration and braking. My next tire upgrade was to a 225/45 (25lbs) on the same wheels and I was expecting a wash or even better performance, since the tire was only .25" taller but 2lbs lighter and (according to the tire manufacturer) .3" narrower. This set up felt even "heavier" and again,I felt the loss in acceleration. I understand that the "butt dyno" theories are all circumstantial and completely subjective but I do a fair bit of driving in various conditions and consider myself pretty attuned to my car's behavior, so I do actually feel the differences in performance. I bring all of this up mainly because I plan on switching to a 18x8 wheel with a 235/40, which will again add a 1lb or two plus an increase in diameter, and I plan on going from Stage II to a Protuned VF39. What I don't want is a only a partial net increase in performance with the turbo upgrade, due to the wheel/tire change.
10-08-2007, 08:56 PM | #2 |
Member#: 118209
Vehicle:2015 WRX Limitec |
calculating for the weight effect of the tire is going to be nearly impossible without the right test equipment... a heavier wheel isn't always bad for acceleration, what matters more is where the weight is. an ounce of extra weight at the very edge of the tire will have more effect then a pound in the very center.
10-08-2007, 08:59 PM | #3 |
Member#: 86356
Vehicle:2018 Aprilia Tuono v4 1100 |
wow 21 pound 17x8s. Where are you shopping?
10-08-2007, 09:05 PM | #4 |
Member#: 132038
South East
Vehicle:funk er chicks serious bidness |
This article discusses this and has some links to spreadsheets like you are talking about:
http://www.mazda6tech.com/index.php?...d=16&Itemid=32 |
10-08-2007, 09:08 PM | #5 |
Member#: 141633
Vehicle:2002 WRX Wagon Shiny new silver!!! |
10-08-2007, 09:42 PM | #6 |
Member#: 84636
South East
Vehicle:2005 WRX (automatic) Crystal Gray |
Double post
Double post
10-08-2007, 09:44 PM | #7 |
Member#: 84636
South East
Just get some lightweight wheels, 18" or less and you should be fine. As long as you have 225+mm tire width the performance in the turns will strongly outweigh any effects with acceleration. ESPECIALLY when replacing the RE92's.
10-08-2007, 09:57 PM | #8 |
Member#: 87169
Vehicle:2007 STI Limited SWP |
10-08-2007, 09:58 PM | #9 |
Member#: 130710
Vehicle:06 |
This is very simple; a lighter wheel and tire make a BIG difference in drag racing [also road and circle track; I have experence in all 3]. I asume you understand the concept of unsprung weight[ tire[tube], wheel, brake rotor[drum], axle, driveline, etc.
A simple, proven, repeatable example everyone can understand: I raced in NHRA, divison6, super/ street class; the object in this class is to run a 10.90 each time with a perfect light on a pro tree and cross the line befor the other car without breaking out[ going faster 10.89 ]sounds easy but a very competitive class[ also the lowest class in nhra racing] each winter you go thru your car and make changes to be more competitive; one time a life long drag racer asked me why I was running tube type slicks[13 inch]I said I really did not know: he said I would 60 foot faster with out tubes???how could 2 tubes make a difference to a 590 hp./ 445 tq./ 2800lb. car with driver] But he was right; faster 60', mph/ this in a car where every run 7-10 stat's are kept. I then went to lighter wheels and brakes[ big difference but big $'s]I think in a wrx because of the low hp/ weight ratio that light tires and wheels make a HUGE difference. |
10-09-2007, 07:49 AM | #10 |
Member#: 136314
Vehicle:2014 Grand Cherokee |
If the stock 17" wheels on our Subarus weigh about 21 lbs, I just don't get why people pay big bucks for wheels that weigh just a couple pounds less...moving to a wider wheel so you can run wider tires I can see though, but to buy expensive wheels to save a pound or two is just crazy.
IMO, an aftermarket wheel would have to weigh at least 5 lbs less each for me to even consider it. For the money I think the Enkei RS-M 17" x 8" 5-100, 45mm offset at $260 and 15.5 lbs each is the best wheel out there for the money on a WRX. |
10-09-2007, 08:38 AM | #11 |
Member#: 24038
South East
location location location
10-09-2007, 01:10 PM | #12 | |||
Member#: 87327
South East
21lbs = about any stock WRX or STI rim and 17x8 Rota. I have 17x8 Rotas. Bingo Quote:
10-09-2007, 02:06 PM | #13 |
Member#: 88501
BAIC
Vehicle:2011 WRX Hatch Dark Grey |
I don't think there is a calculator that can do what YooShin wants... because there is a critical piece of data that is NOT given by the manufacturers and most people don't have the equipment to measure it: inertia.
An "18 lb wheel" will not have the same inertia as another "18 lbs wheel", and it's the inertia that matters. Either you measure inertia (no one has the equipment) or you must know that radius of the CG "hoop" (ie the "moment" of the wheel. We have only to go on anecdotal data. I'm going to use the term "sluggish" to refer to rotational acceleration of the wheel/tire, as opposed to static weight, because I believe that takes into account the inertia. (And since I can't measure inertia) In my case, I had: (A) 23 lb 17x7 2006 OEM WRX wheels + 25 215/45/17 RE92 (B) 14 lb 17x7 Kosei K1TS wheels + 215/45/17 F1GSD3 It was obviously plain as day A more sluggish than B. Then I got: (C) 18 lb 2004 17x7.5 STi BBS wheels + 225/45/17 F1GSD3 C was noticeably more sluggish (and grippier) than B, but not as much as A. But I was considering: (D) 16 2001 16x7 RS wheels + 205/55/16 BFG traction T/A's. Static weight of D is more than B, BUT I theorize that inertia of D might actually be closer to B than I'd expect because of the radial difference of the wheels. I'm guessing that the radius of the moment of the 16" wheel and tire are smaller than the 17" ones. Anyone have data to prove this? (Note: it appears summer tires generally tend to be lighter than all-season/winter/offroads) Last edited by chimchimm5; 10-09-2007 at 03:33 PM. |
10-09-2007, 02:09 PM | #14 |
Member#: 143114
Vehicle:2007 Impreza 2.5i CGM |
sounds like you'd need a physics degree to accurately figure it out. Rotating mass and balancing is a real science.
10-09-2007, 02:17 PM | #15 | ||
Member#: 88501
BAIC
This is the approximation CG "hoop" (moment) that I was talking about. We know M as the static weight but we don't know R. I/k is combined for use in acceleration calculations. So, the only way to find out, is to measure I (and who has a machine that can do that?) or get R from the manufacturer. AND THEY WILL NEVER GIVE YOU R. |
10-09-2007, 02:25 PM | #16 | |
Member#: 133597
SCIC
10-09-2007, 02:35 PM | #17 | |
Member#: 87327
South East
This has been good help though guys. I have a feeling I'm going to end up doing some elaborate experiement that'll be non value added and pointless but maybe fun. |
10-09-2007, 02:44 PM | #18 |
Member#: 141590
TXIC
Vehicle:2010 Silverado 2007 CRF250R |
^^^I want in on said experiment Beers !
10-09-2007, 02:49 PM | #19 |
Member#: 88501
BAIC
I've read that "most" of the wheels weight is at the outer rim. So if we rough estimate the moment radius to be the rim radius, then for comparison sake I did this rough calc:
Code:
WHEEL DIAM ST WT I % 2006 OEM WRX wheel 17 23 1661 0% Kosei 17x7 17 14 1011 -64% savings 2001 RS 16x7 16 16 1024 -62% savings 2004 Sti BBS 17x7.5 17 18 1300 -28% savings 18's 18 25 2025 18% penalty DUB-buhdub bling blang 19 33 2978 44% penalty Last edited by chimchimm5; 10-09-2007 at 02:55 PM. |
10-09-2007, 02:52 PM | #20 | |
Member#: 88501
BAIC
That shows how significant the R is. Oh... and multiply the saving/penalty by 4 because there are 4 wheels on the car Last edited by chimchimm5; 10-09-2007 at 02:59 PM. |
10-09-2007, 03:04 PM | #21 |
Member#: 110236
Vehicle:04 STi WRB |
One thing is that if the overall tire diameter stays the same, you still can reduce the polar moment of inertia by picking a smaller wheel. Since more mass will be closers to the centroid(center axis), this is due to the fact that inertia increase substantially with increasing distance from the centroid.
For example the polar moment of inertia of a disk is I = ( pi * radius^4 )/2. A small change in radius can effect the overall inertia substantially. IF you want I can try to simplify calculating the polar moment of inertia of a wheel + tire. It would just take a while. |
10-09-2007, 03:05 PM | #22 |
Member#: 111641
Vehicle:2020 CWP STi RIP - 06' WRX w/ 6spd |
can we say 17x8 Enkei RPF1's??? 15.5lbs...wider(check)+lighter(check)
I would hazard a guess this a great reason why people like the RPF1's. I for one will be getting a set of them for this reason. I can say from personal experience that wheels in the 15-16.5lb range make a noticeable difference. |
10-09-2007, 03:07 PM | #23 |
Member#: 140163
Vehicle:03 STi hellaflunctional |
according to some, the 17x7.5 bbs wheel weighs anywhere from 15-17lbs. the 17x8 for the 05+ are 19lbs.
10-09-2007, 03:23 PM | #24 | |
Member#: 87327
South East
10-10-2007, 09:15 AM | #25 |
Member#: 130710
Vehicle:06 |
The tire is farther from the center axis so it has a bigger percent of effect on performance.why do some bicycle wheels cost 2000; when working with .5-.7 hp. wheel / tire weight are huge.
Similar Threads | ||||
Wheels & tires weight/size and the effects of performance in 1/4th of mile (PART II) | juanmedina | Proven Power Bragging | 24 | 05-06-2010 01:29 PM |
Wheels & tires weight/size and the effects of performance in 1/4th of mile | juanmedina | Proven Power Bragging | 124 | 12-15-2009 04:30 PM |
the effects of larger wheels... | 1DOWNCLOWN | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 19 | 05-13-2004 03:33 AM |
Effect of wider wheel? (same diameter and weight) | pdlindor | Tire & Wheel | 3 | 08-01-2003 10:03 AM |
"Dyno testing the effects of a high-flow exhaust and aftermarket filter insert." | windfactory | Car Part Reviews | 4 | 09-08-2002 12:10 PM |
