11-07-2009, 02:10 PM | #1 |
Member#: 213043
Tri-State
Vehicle:2003 WRX White |
How do I datalog to sd card using tactrix 2.0?
I'm trying to datalog onto my sd card using a tactrix 2.0 cable but its not working right. I found instructions that say to setup a log file on the sd card, remove just the tactrix adapter that plugs into the obd port, and plug it into the car. I will start the car, hit the defogger button to start logging, and than turn everything off and connect to my laptop. So far the only thing that appears on the sd card are the log.xml file and a logcnf.out file. Shouldn't I be getting a csv file??
What am I doing wrong?? |
11-07-2009, 06:34 PM | #2 |
Member#: 68448
NWIC
Vehicle:2008 WRX STi Cobb tunned by Surgeline |
There is a specific thread on the tactrix website in regards to this.
Lets just say there is more to it and it is not plug and play ready yet |
11-07-2009, 08:54 PM | #3 |
Member#: 39086
NWIC
Vehicle:2004 STi White |
Not quite ready for prime time:
http://forums.nasioc.com/forums/show....php?t=1868026 If you want to be guinea pig... |
11-07-2009, 10:36 PM | #4 |
Member#: 68448
NWIC
I wish it was ready for PNP!!
11-08-2009, 03:43 PM | #5 |
Member#: 134565
HIIC
Vehicle:2006 STi Black |
me too
11-09-2009, 11:38 AM | #6 |
Member#: 219696
Tri-State
Vehicle:2004 STi PSM |
I have the cable and wanna do this too how big a card did you get? Is there such thing as too big?
11-13-2009, 09:32 PM | #7 |
Member#: 120355
SWIC
Vehicle:2004 wrx wagon 2.5 20g-xt, super slow |
write speeds can slow down on larger cards, i doubt you would ever need anything bigger than a 2gig card though, 2gig should be way more than enough
11-16-2009, 03:29 PM | #8 |
Member#: 207229
NWIC
Vehicle:2006 WRX wagon Graphite |
Use this link to download the config tool for setting up a config file for your sd tactrix. Once downloaded just pick your ecu from the dropdown and then check off the parameters you wish to log, then save the file to the main directory of your SD card.
http://forums.openecu.org/viewforum....e11a45c31f7470 |
06-10-2011, 02:51 PM | #9 |
Member#: 149262
MWSOC
Vehicle:03WR rallycarFXTleg PrimerGrey |
So it works now?
06-22-2014, 03:25 AM | #10 |
Member#: 394245
Hi guys,
I'm new here and have a 2012 ausdm wrx I know it's an old thread but I need help.. I have done heaps of reading and plan on doing one of Eric's tunes but am datalogging stock first.. I have done all the below but still nothing gets logged, no files except for the logcfg file: -tactrix 2.0 -2gb micro sd card -used sample logging txt file found in openecu folder for can system and renamed logcfg (Made sure it's not logcfg.txt.txt -uncommented and commented defogger trigger as instructed in file -went for a drive and tried to log using rear defogger I have tried so many times am I missing something ?? |
06-23-2014, 11:19 AM | #11 | |
Member#: 323379
Vehicle:1992 Trans Am |
http://verticaltier.net/configtool/logger.php |
06-24-2014, 12:03 AM | #12 | |
Member#: 394245
Will try this on the weekend and let you know thanks !
06-23-2014, 02:38 PM | #13 |
Member#: 231700
MAIC
Vehicle:2004 WRX Wagon WRB |
A log file should be created once you plug the tactrix into the OBD2, regardless of if you press the defogger switch or not. If it's not being created, either the Tactrix isn't getting power (does it light up when you plug it in), or there is an issue in the logcfg.txt file.
06-24-2014, 12:04 AM | #14 | |
Member#: 394245
Hey I haven't tried this but the lights are definitely on and I'm sure it's getting power
06-24-2014, 04:36 AM | #15 |
Member#: 394245
06-25-2014, 06:50 AM | #16 |
Member#: 394245
hi guys thanks for your help..my ecu wasn't supported on the logcfg creator page but I tried a new logcfg.txt file and just used the standard rpm>0 trigger and it worked..so maybe the defogger one doesn't work ? im assuming its the rear defogger button ?? I triple checked the trigger and I uncommented/commented the old/new trigger correctly.
anyways thanks for your help I will just have to log via laptop for now I think Last edited by wrxb12; 06-25-2014 at 06:51 AM. Reason: add comment |
06-25-2014, 06:53 AM | #17 |
Member#: 394245
I'm thinking maybe my ecu has a different paraname for defogger maybe ?
my ecu is AZ1G900C |
06-25-2014, 12:05 PM | #18 |
Member#: 323379
06-27-2014, 06:39 AM | #19 |
Member#: 394245
Ok guys Logging through laptop all ok but annoying when I'm by myself..I have an idea is it possible to log to sd card and make a trigger for it to start when throttle is say 90 or 100% ?
It sucks my defogger doesn't work for sd card so if anyone can write Me up a trigger for throttle it would be appreciated |
06-27-2014, 11:24 AM | #20 | |
Member#: 236475
BAIC
Vehicle:2002 WRX Black |
C:\Program Files (x86)\OpenECU\EcuFlash\samples\logging The sample file "subaru k-line adc lc1" in particular has a good selection of samples, including: conditionrpn = RPM,0,> action = start conditionrpn = RPM,0,== action = stop which you could change to some other RPM value |
06-27-2014, 02:30 PM | #21 | |
Member#: 323379
Log tps, whatever it's exact name is copy/paste it where rpm is and change it to desired rpm numbers instead of the zeros. |
06-27-2014, 08:32 AM | #22 |
Member#: 231700
MAIC
With romraider logging to your laptop you can use the defroster to start/stop logging.
Similar Threads | ||||
Unable to connect with Tactrix 2.0 and ECUFLASH | DeathKing | Open Source Reflashes | 1 | 01-25-2010 02:20 PM |
Tactrix 2.0 Cable New used once $150 shipped | macker01 | Engine/Power/Exhaust | 3 | 10-31-2009 08:33 AM |
FS: Tactrix 2.0, barely used | JasonLI25T | Engine/Power/Exhaust | 7 | 02-03-2009 07:05 PM |
When are they going to make Micro-SD cards bigger than 2 gigs? | jargon | Off-Topic | 7 | 10-21-2008 08:18 AM |
How do I use AccessPort 2.0 for 2006 WRX? | wonsin83 | Newbies & FAQs | 10 | 05-08-2007 08:36 AM |
