Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 12-20-2001, 11:48 AM   #1
TimStevens
Member#: 4817
Default Tire pressures for snow tires?
Wanted to get some folks opinions on what pressures I should run on my Kumho snow tires, 205/55/16 size. I did a search, and the concensus said to use the stock suggested pressures (32/30), but the tires look awfully low with that amount of air...
Should I stick with this pressure?
Thanks,
-tim
TimStevens is offline   Reply With Quote
Old 12-20-2001, 12:53 PM   #2
Mike Kress
Member#: 9291
almost yellow
Tim, I run 35 psi in everything, stock and snows. Seems like door-jam pressures just isn't enough.
Mike Kress is offline   Reply With Quote
Old 12-20-2001, 01:20 PM   #3
TimStevens
Member#: 4817
Thanks Mike... I think I'll bump it up a few PSI all-round.
My neighbors will think I'm crazy... I'm always fiddling with tire pressures
-tim
Old 12-21-2001, 02:59 AM   #4
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
WR Blue. Cobb Stage 2
Default Snow Tire Pressure
If it is reasonable to assume that the same pressure that works for "summer" tires will be optimum for winter tires then I would recommend 35 psi front/30 psi rear.
I run Bridgestone RE730's in the stock size. The WRX and most vehicles are set up to understeer. In order to encourage more "neutral" handling, it is necessary to increase the difference in pressure between front and rear. Thus the 35/30 instead of the factory recommended 32/29.
It hasn't snowed here in MD yet but I will start with 35/30 and experiment if that doesn't seem optimum.
sajohnson is offline   Reply With Quote
Old 12-21-2001, 07:46 AM   #5
TimStevens
Member#: 4817
I'm not worried about oversteer or understeer... hell, oversteer with snow tires on dry pavement would be pretty scary. I'm just looking to optimize tire wear. I want to get plenty of winters out of these things.
Also, with higher pressure in the front, in the snow, you'll be getting more grip from your rear wheels then your front, giving you more understeer. Lower pressures = better if you're looking for max grip in snow/mud/etc.
-tim
Old 12-21-2001, 10:05 AM   #6
stevekny
Member#: 13496
I use 40psi on my Legacy GT with Dunlop Winter Sport M2's
stevekny is offline   Reply With Quote
Old 12-21-2001, 01:47 PM   #7
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
Default TimStevens
I admit that I have no factual data to back up my position, but it seems logical that the tire pressures that work well in wet/dry conditions would also work well in the snow. My thinking is that as long as the available traction is substantially equal under all four tires (dry, wet, or snow) the handling would remain neutral (although the ultimate limits would obviously be less. In fact, I'm not aware of ANY mfr. that specifies different tire pressures for winter tires, although most of them recommend 4 snow tires. If it were true that lower pressure is better in the winter I'm sure those same mfr.'s would say so.
That said, if you feel uncomfortable with neutral handling in the winter (I admit understeer is easier to deal with) then by all means, start with the SOA recommended 32/29 psi and adjust accordingly. I have the same concerns with wear that you do, but any mfr.'s recommended pressures are a compromise between ride/handling/mileage/noise/wear etc. They are at best a good starting point.
Old 12-21-2001, 01:51 PM   #8
TimStevens
Member#: 4817
I think I'll bump them up to around 35 and go from there. Lower pressures are better for winter or mud traction, in general. It allows the tire to shape around the snow/mud/rocks/whatever, rather than just maintain its shape and have a limited contact patch with the road.
Snow tires have softer sidewalls, which help the tire to do just that... that's why I'm not sure if I should up the pressure because they look like they're sagging or stick with the way they are now... *shrug*
-tim
Old 12-22-2001, 12:46 AM   #9
zemmo
Member#: 5416
2002 Wrx wagon
I'm running 36-36 psi in my Toyo snowtires. That feels about right to me. Just got back from a fast trip to town on ice, gravelly ice, snow, and a little almost bare pavement and they felt really good. If I run much less than that they just feel too soft cornering.
zemmo is offline   Reply With Quote
Old 12-22-2001, 01:38 AM   #10
Scoobie Newbie
Member#: 4184
2004 WRX
World Rally Blue,Moonroof
Default Attn: sajohnson
I would have PM's you but you don't have that option. I was considering the Bridgestone RE730's next year and was wondering what you thought of them.
Scoobie Newbie is offline   Reply With Quote
Old 12-22-2001, 05:00 AM   #11
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
Default RE730's
Most excellent dude! Seriously, I'm used to running B/S SP8000's on my previous vehicle, a NX2000. The RE730's are better in every way. You will not be disappointed, especially considering the price and treadwear rating (300). They also have the latest 'AA' traction rating.
Anything better will cost a lot more and wear out very fast.
Lower tire pressure for snow? HAL1 Tire & Wheel 7 11-15-2005 10:11 AM
Proper Tire pressure for stock tires JDMTEG98 STi Forum Archive 21 07-23-2003 05:14 PM
Tire Pressure for snows Fast Wagon New England Impreza Club Forum -- NESIC 26 12-11-2002 06:28 PM
Tire pressures for stock tires on WRX SnortWagon Brakes, Steering & Suspension 5 02-07-2002 12:15 PM
Tire Pressure for snow tires??? 99 RS 2.5 New England Impreza Club Forum -- NESIC 4 10-12-2000 09:17 PM
