12-09-2003, 06:38 PM | #1 |
Member#: 498
South East
Vehicle:1981 jdm swapped gc sniklfritz |
Well Well....the time has come Rs ti ZZZZZZZZZ
Ill start by saying thanks to Graham!, now, the question is how to tune after all of this stuff thats in my living room is in the car...
IhiRhb5 internal waste gate set at 4psi Misc. lines oil fitting etc etc gaskets etc top mount ralispec cartek rrfpr voltage clamp is in the mail wrx up pipe wrx downpipe walbro 255 pump autometer boost gauge autometer air/fuel gauge "this item is pointless correct?" wrx crossmember wrx waterpump wrx midpipe will be ordering a blitz nurspec axleback i need a front wrx stock swaybar..... clutch will come later......umm probably sooner than i expect hehe but anyways this stuff is here finally after the years of wanting a turbo impreza....some of you guys might have known me from back in the day member 405 on nasioc.com etc etc im a vet that started small, 98 4eat black rs, traded in at prestige subaru for a my00 rs and now im here, faced with a decision, i think the install isnt going to be the problem, its the tuning, i dont have the funds for a link, or any stand alone for that matter, a j&s would be nice but blah blah blah,,,,,,, i need some help what gauge or gauges egt, fuel pressure will those suffice for a 4psi tune with a rrfpr + walbro fuel pump? let me know, also if any of you guys will be in charleston sc, anytime soon any help would be nice ha, anyways thanks again to everyone who has helped answer any questions i may have thanks Greg
12-09-2003, 07:11 PM | #2 |
Member#: 23359
NESIC
Vehicle:2002 BMW M Coupe Steel Gray |
Definetly will need the EGT. The fuel pressure is probably a good idea, at the very minimum get the $15 inline guage you can put under the hood. (You can get them at summit racing.) The A/F guage isn't useless, its just not 100% accurate. It will help to see if you are rich or lean, it won't give you exact numbers like a wideband will, but it will give you a ballpark idea.
Also, I'm not sure about the WRX piping setup, but won't you need the WRX headers too? |
12-09-2003, 07:19 PM | #3 |
Member#: 498
South East
i knew i forgot something, yeah those are at the house too....hehe
12-09-2003, 08:23 PM | #4 |
Member#: 11931
Vehicle:2001 2.5 RS Turbo 257/FMIC/T3-T04S |
Greg, my advice is this: if you are going to stick with the Cartech RRFPR for over 6 months, then get fuel pressure gauge in the cabin. It will be to your benefit to know how much fuel pressure you have, especially since you won't be using a J&S. If you plan on going with a Link+ soon, then I would do the $15 inline gauge. Just attach it so it sticks out of the hood scoop, at least you will be able to read it, although I know it sounds kind of cheasy (put it under the hood once you have the fuel pressure set).
EGT gauge is a must, don't shy away from one of those. Put it a few inches away from cylinder #3. When I was running the kit with 4 psi and the Walbro pump, I had PLENTY of fuel. Going without knock protection is dangrous, but I never did hear any signs of detonation when I had the J&S/ITC installed. Graham |
12-09-2003, 08:41 PM | #5 |
Member#: 498
South East
also forgot, going to do the parallel fuel rail mod
also who wants to sell me a j&s cheap? hehe thanks Greg |
12-09-2003, 09:36 PM | #6 |
Member#: 4562
NWIC
Vehicle:2014 Electric Datsun 2005 Adventure van |
Yeah,
Grahams a bastard! He got me started in this **** too! Thanks man! |
12-09-2003, 11:15 PM | #7 |
Member#: 49087
RMIC
Vehicle:1998 RST V8 STi swap '05 R6 '95 BMW V8 hotness |
A fuel pressure guage is definately important if you are running a RRFPR. The diaphragms and springs in those can go soft over time leaving you with a fuel pressure that is way off of what you thought it was. An EGT gauge is also a pretty good indicator of something going wrong. But at 4lbs you should be pretty safe. The A/F meters are actually nice insurance to have too.... at 4lbs the only knock/detonation you will be running into is either on an extremely hot day. Or running lean, it's nice to be able to see a yellow/red light come up at WOT and back off before bad things happen.
12-10-2003, 03:53 AM | #8 |
Member#: 11931
"""Yeah,
Grahams a bastard! He got me started in this **** too! Thanks man! """" Hey, whatever I can do to help!!! Graham |
12-10-2003, 07:50 AM | #9 |
Member#: 4562
NWIC
12-10-2003, 12:40 PM | #10 |
Member#: 9861
RMIC
Vehicle:1999 2.35 RS-T w/NOS Hybrid Rally Blue Pearl |
I would do the clutch before installing the turbo kit. If you dont the whole turbo kit has to be removed to install the clutch. Sounds like you are putting in a new crossmember anyway, so you might as well do it while the engine is out. You'll need it anyway
12-10-2003, 11:36 PM | #11 |
Member#: 4562
NWIC
Yeah, clutch first. and do a flywheel while you are in there.
12-10-2003, 11:37 PM | #12 |
Member#: 4562
NWIC
BTW,
I will be selling my Link,RC injectors and harness soon. If you are interested let me know. |
12-11-2003, 11:28 AM | #13 |
Member#: 498
South East
pm me about the link and harness
01-03-2004, 05:51 PM | #14 |
Member#: 35868
NWIC
Vehicle:06 Impreza OBS GG6 Corolla GT-S Hachi Broku |
Excuse me for sounding like a noob but I'm a little confused...
Are you using stock wrx uppipe and downpipes? And all you had to do was get a the WRX crossmember? If that is the case, wow! If there is more you had to do, can you let me in on what's up? I was thinking of going the TD04L with Subachad pipes, but the possibility of running WRX aftermarket pieces is quite sexy (if it's possible). Thanks -ben |
01-03-2004, 07:03 PM | #15 |
Member#: 24956
Vehicle:1997 Impreza WRX Steel Blue Mica |
I think now was a good time to show these. I'm using all stock WRX pieces. You can see how everything fits, and also the tight fitting coolant lines.
Brent |
01-03-2004, 07:19 PM | #16 |
Member#: 43852
Vehicle:GC8 2.5RST Black |
Brent, are you running that motor yet? I had a ton of problems using the stock Y pipe. I eventually upgraded to the samco part and now it is just fine. I'll post my updated pics in a few minutes...
01-03-2004, 07:45 PM | #17 |
Member#: 43852
01-04-2004, 01:10 AM | #18 |
Member#: 24956
Dude, you know all too well. I'm currently looking for one for a good price. I wouldn't say that I have problems, but I know the car would run better with the other piping. Those blue pieces just connect the piping together, so you can imagine.
Brent |
01-04-2004, 01:16 AM | #19 |
Member#: 35868
NWIC
FJP - Is that a 2.5RS intake mani? Did you have to do anything to get the WRX top-mount to fit?
I'm looking to do something like this, also, so, any help would be appreciated. thanks -ben Last edited by Soon2BturbodRS; 01-04-2004 at 01:24 AM. |
The time has come for me to find the succesor to RE92s | Osgood30 | Brakes, Steering & Suspension | 46 | 03-13-2003 11:37 PM |
So the time has come.....local people first. The RS gets parted out in January. | Opie | South East Region Forum | 18 | 12-23-2002 10:56 PM |
Well, the time has come...im leaving Subaru. | munkis | General Community | 58 | 09-25-2002 05:57 PM |
Well the time has come | WhiteWRXBoy | South East Region Forum | 2 | 08-05-2002 12:54 PM |
Well, the time has come to sell | deadbolt | South East Region Forum | 1 | 01-29-2001 10:27 AM |
