02-19-2006, 05:35 PM | #1 |
Member#: 104566
Tire Pressure for 18s
Quick question...what should the tire pressure (psi) be at on an STi with 18s? Thanks
Ryan
02-19-2006, 05:40 PM | #2 |
Member#: 80474
South East
Vehicle:2002 Z06 1200whp |
what does the tire say? or when you bought the tires they will say reccomended psi right?
02-19-2006, 06:19 PM | #3 | |
Member#: 82378
South East
Vehicle:<--- Hot Donuts Now |
12345 |
02-19-2006, 06:34 PM | #4 |
Member#: 82455
HIIC
Vehicle:2006 Saab 9-3 2.0T SportCombi |
Doesn't the tire just say a maximum rated PSI? The PSI of the tires depends on the weight and weight distribution of the vehicle as well as the surface area of the tires desired to be in contact with the ground. In other words, I have no idea and I don't think anyone will be able to give you a truly good answer without knowing the dimensions of the tires (i.e. 225/40/18).
02-19-2006, 06:50 PM | #5 |
Member#: 82378
South East
max minus 4/5 psi. thats what i do.
02-19-2006, 07:05 PM | #6 |
Member#: 37617
Vehicle:2007 |
I'm speechless. Speechless. I am without speech. I have no speech.
02-19-2006, 07:07 PM | #7 | |
Member#: 82455
HIIC
btw, I think max minus 4-5 psi could be pretty dangerous assuming you are taking the pressure readings on cold tires like the readings are supposed to be because the expansion of the air molecules caused by heating up with easily increase your cold tire pressure by at least 4-5 psi. |
02-19-2006, 07:17 PM | #8 | |
Member#: 82378
South East
could be. never been a problem... |
02-19-2006, 07:31 PM | #9 | |
Member#: 104591
Vehicle:06 STi WRB |
yup, since most tires under normal operating temps increase about 8 psi or more. My dads real time tire pressure monitoring in his vette shows a 10psi increase one they get hot. How about just going with whats on the sticker on the driver side door. I dont see why the diameter would effect what subaru recommends. |
02-19-2006, 07:45 PM | #10 | |
Member#: 82378
South East
you know people do have tires other than stock right? |
02-19-2006, 07:54 PM | #11 | |
Member#: 104591
right and if you dont have a clue and you have to ask in here and people recommend things like the max the tire says, which i believe the max on the tires on my sti right now is like 52 psi. Anyway then isnt it best to go with something close. Or i dont know asking the tire manufacturer or whoe ever sold them to you. Instead of getting 3000 opinions from people are are pulling numbers out of their ass. Whats on the door is the least "i pulled it out of my butt" number you could go with and the safest choice to make if you dont have a clue. |
02-19-2006, 07:59 PM | #12 | |
Member#: 82378
South East
you know im not the OP right? |
02-19-2006, 08:09 PM | #13 |
Member#: 82455
HIIC
I think it may have been a general "you" though this thread looks like it's taking the fast track to OT.
02-19-2006, 08:16 PM | #14 |
Member#: 74453
SCIC
Vehicle:04 WRX-PSM |
I run 225/40/18 and I always keep my psi around 30 (+/- 3psi). I would not run anything under 25 and nothing over 40 psi. Hope this helps.
02-19-2006, 11:31 PM | #15 |
Member#: 22779
Vehicle:2002 WRX 4EAT WRB VF34 Kit w/AP |
I have 225/40/18 AVS100s and its max psi is 44psi. I run mine at 40psi. Just read the side wall and make an educated decision.
02-20-2006, 01:07 AM | #16 |
Member#: 85786
BAIC
Vehicle:2004 WRX wagon WRB |
Here's what subaru thinks the tire pressure of the WRX should be. Sti's probbaly wouldn't be different. It's only for 16 & 17's but you could see what changes from 16 to 17, and then do that again to get 18'' pressures.
forgot to mention this is out of a 2004 wrx service manual. Last edited by tkarabian; 02-20-2006 at 05:43 AM. |
02-20-2006, 01:08 AM | #17 |
Member#: 79493
SCIC
Vehicle:2003 WRB WRX Wagon 5 doors > 4 doors |
Check the tire sidewall, I usually start off with 5 psi below the max.
02-20-2006, 01:57 AM | #18 |
Member#: 82455
HIIC
Kind of weird how they have a higher rear psi on the 215/45/17's than the 225/45/17's given the other trends, anyone know why that is? Seems that a narrow tire on the same sized rim and thus a slightly smaller sidewall will require a higher pressure on the rears. I wish they had data on two different 16" wheels rather than the 15's. It would be interesting to plot the data and find the curve or linear progression.
02-20-2006, 02:16 AM | #19 |
Member#: 67387
Vehicle:04 WRX - STX 05 LGT Limited Wagon |
I usually say 35 PSI for street driving.
if it's a really low profile tire (below 40) i'd go a little higher to 38-40 just to help keep from banging up the rim. |
02-20-2006, 08:58 AM | #20 |
Member#: 82078
SCIC
Vehicle:2021 Crosstrek Cool Khaki Grey |
In my 215/40-18 I run 38 lbs in the front and 36 lbs in the rear.
02-20-2006, 09:02 AM | #21 | |
Member#: 24038
South East
Tire size for 18s | WRX06 | Tire & Wheel | 3 | 08-14-2005 03:39 PM |
tire pressure for 18s | thrdeye | Tire & Wheel | 2 | 04-21-2004 08:09 PM |
Tire pressures for stock tires on WRX | SnortWagon | Brakes, Steering & Suspension | 5 | 02-07-2002 12:15 PM |
Tire pressures for snow tires? | TimStevens | Brakes, Steering & Suspension | 10 | 12-22-2001 05:00 AM |
Tire Pressure for snow tires??? | 99 RS 2.5 | New England Impreza Club Forum -- NESIC | 4 | 10-12-2000 09:17 PM |
