Tire & Wheel Forum sponsored by The Tire Rack |
02-18-2005, 12:38 PM | #1 |
Member#: 48911
Yes or no 235 40 18 or 245 45 18 fit 2004 STI Help!!
guys you need to help me out. im looking to get the volk le28n (polished lip) and i want to fit a fat tire on it. ie 235 40 18 or 245 35 18 or 255 35 18. is there anyway i can do this. I need to know the right offset and all of that. Any help is appreciated
tony
02-18-2005, 12:45 PM | #2 |
Member#: 39462
Vehicle:04 STi Type R Spec Broken Wallet |
well, i have the Le-28N's (18x8.5 +44 offset). I put 245/35/18 T1-S on and I have no problems rubbing (coilovers w/ a lot of neg. camber). They rubbed a bit with the pink springs i had previously in the rear during hard corners. I originally had 235/40 pirelli's on them, and they didn't provide enough rim protection for my taste, nor looked right. IMHO 245/35 is perfect on these rims. For my next set, I want to try a 245 or 255 R-compound tire, but I'll need to roll the rear fenders most likely with the 255's, unless I raise the rear a bit or run even more neg. camber.
-Matt |
02-18-2005, 02:06 PM | #3 |
Member#: 8247
Vehicle:2016 Outback 2005 Lotus Elise |
235 you should be fine, above that and you'll night quite a bit of camber and a mildly rolled lip. I agree that they don't protect the rim all that much, but 245's just seemed like they would be way too tight
02-18-2005, 02:20 PM | #4 |
Member#: 39462
with 235's if you look down the side of the car, you can see the rim sticking out.....
but it's up to you if you want to protect your investment or not. I would never put 235's back these rims. -Matt |
02-18-2005, 03:52 PM | #5 |
Member#: 48911
so 18x8 with 235 40 18 wouldnt look right?? or 245 35 18??? 18x8.5 with 235 40 18 im thinking will be to little of a tire for the rim
02-19-2005, 01:15 PM | #6 |
Hoodbridge!
Moderator Member#: 560
Vehicle:2006 STi, 16 Outback Crystal Gray, Silver |
Both the sizes you mentioned will be bigger in diameter than the stock tires. Wider and bigger will increae your chances of rubbing. I believe that 225/40-18 is the closest to the stock diameter, as well as 245/35-18, but that's a pretty hard size to find.
02-19-2005, 04:54 PM | #7 |
Member#: 62514
Vehicle:04 sti blue |
02-19-2005, 07:30 PM | #8 |
Member#: 17397
BAIC
Vehicle:many '02 Rex,'13 FRS WRB, White |
aye mr. norcal sti...
i have an 18" set up and i went w/ the 235/40/18 Toyo Proxe4s. isn't it a wonderful shot by the garbage can sd |
02-21-2005, 08:51 PM | #9 | |
Member#: 39462
Let me clarify further....I'm not saying a 235 doesn't fit (it does), but dif. tire manufacturers vary with the true measurements of their tires (much like shoe manufacturers). One 235/40 may not be wide enough, and another might offer plenty of rim protection/fit well/etc...it all depends on the brand. The guy above with the SO-3's....those tend to run wide, so they fit well. The 235's I had on momentarily were P-zero M+S, which were put on by mistake when I ordered my wheels. But still, I'll take the width anyday if it fits under the fender. |
need to buy or trade tires 245/45/18 for 235/45/18 | knighter | MAIC Private Classifieds | 8 | 12-03-2008 03:16 PM |
245/40 or 245/45 on stock 05 STi wheels | millerni | Tire & Wheel | 53 | 03-15-2007 01:34 AM |
245/45/18 fit an 05 sti with gf210's? | Swine | Tire & Wheel | 2 | 08-07-2006 01:42 PM |
Need Tires 235/40/17 or 235/45/17's ! ASAP | TicketsForMePlease | Private 'Wanted' Classifieds | 5 | 05-05-2006 06:52 PM |
Advice: 235/45/17 or 245/45/17 on '05 STi | palpullero | Tire & Wheel | 22 | 03-08-2006 02:05 PM |
