10-05-2012, 07:43 PM | #1 |
Member#: 171586
Vehicle:2004 Wrx Blue |
Whining noise while driving?
Hello everyone new here. I have a quick question was driving home tonight without the radio on I could hear while I was in 5th gear a whining noise while accelerating it was to loud but would go away when I let off the gas. It doesn't do it at idle and haven't hear it in lower rpms or other gears. Any ideas thanks!
10-05-2012, 07:47 PM | #2 |
Member#: 261307
South East
Vehicle:04 wrx wagon WRB |
Maybe a boost leak. Check all vacuum hoses and hoses coming off the turbo. Also check the bpv is bolted snug if you've messed with that recently.
10-05-2012, 07:49 PM | #3 |
Member#: 171586
No haven't messed with anything it's all stock. Really only noticed it today while in 5th and noise stops when I take my foot off the pedal. Don't think this is trans diff related? Thanks for the quick response!
10-05-2012, 08:03 PM | #4 |
Member#: 276425
Vehicle:2003 BMW M3 Jet Black |
Turbo spooling up?
10-05-2012, 08:07 PM | #5 |
Member#: 171586
Ya I can hear the turbo spool different sound. It's not super Lou can only hear it without the radio on?
10-05-2012, 10:00 PM | #6 |
Member#: 171586
Anyone ideas?
10-05-2012, 10:07 PM | #7 |
Member#: 325356
Vehicle:2005 Impreza wrx sti Silver |
Haha I just had this problem if it's only 5th gear at speed your hearing likely 1 of 2 things wind noise over the mirrors try folding them in just to see
Or Front diff is whining I had this problem an found out for me it was the wind and mirrors others have said they tried that but no fix and found out it was the front dif but was not a problem and not damaging anything Google it and you can see tons of threads about it. Hope this helps you |
10-05-2012, 10:21 PM | #8 |
Member#: 171586
Can rule out the mirrors it only happens while I'm on the gas and immediately goes away when I let off the gas
10-05-2012, 10:31 PM | #9 |
Member#: 314841
Vehicle:2001 2.5 RS Black |
this happens to my car. fill out your profile so we can see what you drive. i have an 01 RS 5 speed and that happens to me in fourth gear. whines then goes away when i let off the gas. i believe its either differential related or possibly transmission
10-05-2012, 10:43 PM | #10 |
Member#: 171586
I drive an 04 wrx about 115k is this something to be worried about.
10-05-2012, 10:45 PM | #11 |
Add Lightness
Moderator Member#: 13699
Vehicle:2021 Building It Better |
I get whining like that sometimes. It only goes away when I give the evil eye to my kids in the back seat.
10-05-2012, 10:58 PM | #12 | |
Member#: 330460
SCIC
Vehicle:2012 WRX Hatch Satin White Pearl |
10-05-2012, 11:12 PM | #13 | |
Member#: 263954
Vehicle:2014 EVO X / 05 WRX Wicked White / Blue |
I tell you...good times...good times. |
10-05-2012, 11:22 PM | #14 |
Member#: 154579
Vehicle:2005 OBXT Old man blue |
First, which car/year do you have?
Does it sound like a supercharger whine? If so, check your AC idler pulley. |
10-05-2012, 11:24 PM | #15 |
Member#: 171586
2004 wrx. It does sound like a supercharger wind. Can't hear it with the radio on goes away when I take my foot off the pedal noticed more higher speeds
10-06-2012, 12:26 AM | #16 |
Member#: 154579
My guess is the AC idler pulley. Take the AC belt off and go for a drive.
10-06-2012, 12:34 AM | #17 |
Member#: 171586
Thanks I will try that never thought that would make that Kim if noise with the a/c not even on. Why does the pulley cause this noise ?
10-06-2012, 01:19 AM | #18 |
Member#: 154579
It's because the bearings on the pulley are going bad. Even with the AC off the belt/pulley still spins, the AC clutch just isn't engaged.
10-06-2012, 02:06 AM | #19 |
Member#: 292747
TXIC
Vehicle:2011 WRX WRB |
i noticed the same thing in my 11wrx. believe its the ac pully. next time it happens turn ur ac off. it sounds almost like alternator whine
10-06-2012, 09:29 AM | #20 |
Member#: 171586
Wouldn't I hear that all the time then. Even at idle. Or just under acceleration?
10-06-2012, 05:33 PM | #21 |
Member#: 280459
VIC
Vehicle:2015 WRX STi WRB |
its likely your rear differential, does the noise happen right around 58-65mph?
10-06-2012, 05:47 PM | #22 |
Member#: 295261
Vehicle:2008 WRX Stg II Pearl White |
I had the exact same thing happen in my 08 wrx in 5th gear. Happened to be the center diff, and 4,000$ of warranty work later.
10-06-2012, 07:48 PM | #23 |
Member#: 171586
ya i noticed it in 5th gear happens in all gears to be honest its very faint would go away when i took my foot off the pedal
10-06-2012, 10:20 PM | #24 |
Member#: 171586
if was a diff wouldn't it make a clunking noise while turning?
10-07-2012, 12:37 AM | #25 |
Member#: 280459
VIC
If it were the differential gears. The ring gear may be worn, or out of true.
