05-30-2008, 06:09 PM | #1 |
Member#: 118017
BAIC
Vehicle:2004 WRX Waggin' Blue |
DIY Front Lip - Version II
Version II Garage Door Lip Hahaha!
(Work in progress, still tweaking and updating...) *FYI, all pictures were taken after driving ~500 miles over the last week. The lip scrapes coming into and out of my driveway, as well as many other places, and is holding up very well so far. Cleans up easy with Simple Green and a cloth. I just got done doing this to my '04 WRX Wagon, and I thought I'd share. It's a different enough take on the DIY lip that others have done, that I thought it could use its own thread. I love how it came out. This design covers most of the unsightly scrapes on the bottom of the bumper, and evens out the bottom of front bumper. *This is for a stock '04 bumper without side splitters. I'm sure the method will be similar for other models, years, but I don't know for sure. Materials: EPDM foam rubber garage door sealer (same as in other threads. got mine from Lowe's for $16) Double sided sticky tape (normal scotch tape style, not foam tape) Small foam blocks or something similar. (should be stiff/hard material that can be cut with a sharp knife to specific shape. I had some foam blocks left by Stanley Steemer that are used to put under furniture after carpet cleaning.) Self tapping screws ~3/4" (15-20pcs.) ~1.5" (5-10 pcs.) Washers ~1/2"-1" wide (20-30pcs.) Step 1: Cut the garage door sealer in half, into two sections that should be more than 90" long. Step 2: Lay out both sections flat, and run strip or two of double sided tape along the top of one section. Carefully stick second section to first section so the cross section looks like the picture. Step 3: Cut some foam blocks into sections with a trapezoidal cross sections about 25mm wide, 17mm tall on one side, and 20mm tall on opposite side. These pieces go between lip and bumper to even out the raised center section when mounting the lip. Step 4: Fit lip around bottom of bumper, secure with screws and washers. Step 5: (More details to come...) Garage Door Material Lip Cross Section Prepped Lip Before (Lots of ugly scrapes) After Close-Up Finished Product For more reference, check these threads: http://www.clubwrx.net/forums/exteri...p-wrx-8-a.html http://forums.nasioc.com/forums/show...hreadid=395394 http://forums.nasioc.com/forums/showthread.php?t=583184 http://forums.nasioc.com/forums/show....php?t=1275327 http://forums.nasioc.com/forums/show....php?t=1389639 http://dirtyimpreza.com/forums/showthread.php?t=3032
05-30-2008, 06:13 PM | #2 |
Member#: 96944
Vehicle:2005 SAAB 9-2X AERO 4eat Stage 2 Protuned |
I like it, good job.
05-30-2008, 06:15 PM | #3 |
Member#: 140712
SCIC
Vehicle:2008 WRX STI White |
nice job. looks very clean
05-30-2008, 06:19 PM | #4 |
Member#: 151928
South East
Vehicle:09 Triumph S3 |
good write-up. nicely done. good work, man.
05-30-2008, 06:20 PM | #5 |
Member#: 102812
Vehicle:18 WRX Dark Grey Metallic |
very nice!! looks better then the single piece one that everyone (myself included) does
05-30-2008, 07:19 PM | #6 |
Member#: 174672
South East
Vehicle:02 AW WRX 02wrxX2,06sti,94wgn,04sti |
very nice....i like it alot more than my single layer
but will it work on the best imprezas of all... the bugeyes? im going to attempt this tommorow and see if it works on my car, nice idea sir |
05-30-2008, 07:35 PM | #7 |
Member#: 118017
BAIC
Thanks guys. ^^^ Be sure to post some pics.
05-30-2008, 08:04 PM | #8 |
Top Scoob 008
Member#: 77299
Vehicle:'05 2.5RS #78 ST, MAXIMUM ATTACK! |
very very nice job!
05-31-2008, 12:46 AM | #9 |
Member#: 65864
Vehicle:Back in a 2019 WRX |
that actually does look good. as a bugeye wagon owner, i'm going to try this.
05-31-2008, 12:48 AM | #10 |
Member#: 32459
Vehicle:02 WRX VF34 (SOLD) Junior Tuned 301whp |
I don't normally like DIY front lip, but I gotta say good job.
05-31-2008, 12:53 AM | #11 |
Member#: 71490
SCIC
Vehicle:05 cgm wrx rubbing axles haha |
damn it does look pretty good...
05-31-2008, 12:58 AM | #12 |
Member#: 3782
South East
Vehicle:02 WRX WFC#040 Clean on 19's |
Wow v2 DIY lip rocks!
05-31-2008, 01:30 AM | #13 |
Member#: 104896
wow! props to you!
05-31-2008, 01:30 AM | #14 |
Member#: 140978
SCIC
Vehicle:02 WRX WRB i-Nertia Dynamics |
V2 Ftw!!!!!!!
05-31-2008, 02:15 AM | #15 |
Member#: 20492
Vehicle:4 -valve Derper Let's JDM styling! |
Version 2 doesn't look DIY - looks like a real lip like V-limited hotness
awesome job |
05-31-2008, 02:26 AM | #16 |
Member#: 165055
TXIC
Vehicle:09 335i ..tuned wrx 18g ewg fmic meth |
very nice thinking!
05-31-2008, 02:43 AM | #17 |
Member#: 116714
Wow that looks great. Hmm Bugeye anyone??
05-31-2008, 02:53 AM | #18 |
Member#: 118017
BAIC
^^^I am very curious to see if this works on other years too. Anyone who makes this work, be sure to post pictures.
05-31-2008, 03:00 AM | #19 |
Member#: 120152
The double layer makes it look really smooth and even. Nice work!
05-31-2008, 03:47 AM | #20 |
Member#: 83638
SCIC
def looks better than og version on 04.
05-31-2008, 06:16 AM | #21 |
Member#: 40579
Vehicle:2002 WRX Stage 2+ Tuned by IA Performance |
That looks really good, but I don't think it will work as well on the bugeyes because of the shape of the bumper bottom, and the fact that the brake ducts are so close to the bottom edge. I'm sure with some custom fabrication, it could be made to work though. I'm sure NASIOC will find a way...
J |
05-31-2008, 06:51 AM | #22 |
Member#: 104200
TXIC
Vehicle:000 WHP BUGEYE Street Proven Performance |
nice work!
05-31-2008, 08:57 AM | #23 |
Member#: 162812
Vehicle:2004 STI WRB |
awesome work, good thing about the double layer is that it covers up the scuffs and gashes in the bumper cover
05-31-2008, 09:49 AM | #24 |
Member#: 159853
Vehicle:2005 Impreza wrb |
THAT rocks. I love my diy diffuser. dare i say, but it looks expensive. like the rally type lips
05-31-2008, 10:13 AM | #25 |
Member#: 169053
Vehicle:2000 Impreza SCCS NASA Autox Driver |
wow nice, that is a lot easier than most the other DIY lips...most others require fiberglassing and such...good job on finding something simple that works great! I'll have to try this later this week.
Similar Threads | ||||
Finally did my DIY Front Lip.... | JoeSUBARU | Member's Car Gallery | 154 | 03-03-2013 07:57 PM |
Can you say DIY front lip? | J-Chow | Vancouver Impreza Club Forum -- VIC | 52 | 07-26-2009 07:34 PM |
DIY Front Lip!! | turbowagon02 | Member's Car Gallery | 116 | 07-18-2009 09:30 AM |
Another DIY front lip | txl146 | Interior & Exterior Modification | 5 | 04-30-2007 09:53 AM |
post your STI front lip. Version I or II please ! | trustz | Member's Car Gallery | 24 | 09-18-2002 03:53 PM |
