10-12-2010, 12:41 PM | #1 |
Member#: 81497
Vehicle:2017 Ford Raptor 2016 Ford Explorer Sport |
Building motor, bigger than 100mm pistons? + where to get o-rings
My current stage 3 Raw/Axis block is being rebuilt due to oil consumption. Machine shop say the hone was far too aggressive and prematurely wore the pistons and rings. Problem is the bore was already 100mm.
Are there 100.5mm or 101mm pistons readily available? Ive already got head gaskets, and an oil pickup. I need to get intake mani gaskets. Any other gaskets I will need? Also, where should I get an o-ring kit? the dealer/subarugenuineparts?
10-12-2010, 12:58 PM | #2 |
Member#: 81497
I just found this full kit, but I dont need the headgaskets...
http://www.importimageracing.com/p/S...-seal-kit.html Also, do you need a different sice gasket for a 100mm or 101mm bore? or will stock gaskets work? |
10-12-2010, 01:01 PM | #3 |
Member#: 177913
South East
Vehicle:2018 WRX STi WRB |
Who's building your block? Ask them what gaskets you need as we don't know the condition of your motor. If you want to be safe just but a complete gasket kit from flatironstuning.com or at the dealership...it's up to you. Goodluck with the build.
10-12-2010, 01:21 PM | #4 |
Member#: 81497
A local machine shop is building the block. There were 30k miles on it
10-12-2010, 01:34 PM | #5 |
Member#: 177913
South East
Get the full gasket kit for the year of your block and the shop would use what they need. As far as bigger head gaskets, you can probably ask Josh at import image.
10-12-2010, 01:47 PM | #6 | |
Member#: 81497
But gasket-wise, I already have header gaskets, up-pipe gaskets, head gaskets, etc. I hate to buy a $279 kit when I need about half of it. and I am talking to Josh about what to do now. I was just looking for input. |
10-12-2010, 02:33 PM | #7 |
Member#: 9351
Vehicle:2006 trailblazer SS black |
Can you just hone the block again and get away with using the same pistons with new rings? I know Wisceo pistons makes some fairly large bore pistons. and if they dont have them on the shelf they will make whatever size you want. I had a customer that was in the same situation. Im fairly sure we ended up getting him 101mm pistons.
And also standard Cosworth Head Gaskets cover up to 101mm. |
10-12-2010, 02:47 PM | #8 | |
Member#: 81497
Josh said he can get custom CP pistons for more money, but 3-5 weeks wait I called the machine shop, and they said no, they would just stick with the 100mm bores, lightly machine it and re-hone it, so I guess I will stick with 100mm. I went with the OEM headgasket, anyone see any big issue with this? setups is 440 wheel hp, 26 psi, meth injection, garrett gt3076r. I wasn't aware that the gasket that was on the raw block was cosworth. |
10-13-2010, 12:45 AM | #9 | |
Member#: 73721
Honestly I wouldn't consider going any further than 100mm if you plan on making more power. The more you take out of the bore, the weaker the liners will be. |
10-13-2010, 08:45 AM | #10 |
Member#: 113924
Vehicle:2005 STI....SOLD! 93 RX7...Not Broken |
Pm max (remotehuman) he works in the parts dept. At planet Subaru in Hanover, I'm sure he can help you figure out exactly what you need. Or you could come out to the Boston meet tonight in Braintree at UNO, he will be there.
10-13-2010, 09:36 AM | #11 |
Member#: 9351
Raw Block probably didnt use Cosworth gaskets, just letting you know the gasket bore size of the cosworth ones if you wanted to use them. Stockers are probably the same I would think...
10-13-2010, 09:41 AM | #12 | |
Member#: 81497
We are sticking with 100mm now. i found a thread where someone tried boring out a block more and around 103mm they started breaking through the liner. I am suprised that the raw block started at 100mm. |
10-13-2010, 09:41 AM | #13 |
Member#: 81497
10-13-2010, 09:42 AM | #14 | |
Member#: 81497
I cant make it to the meet tonight, sucks i havent been in a while. id really like to get back into going, they are a lot of fun. |
10-13-2010, 10:27 AM | #15 |
Member#: 9351
10-13-2010, 10:42 AM | #16 |
Member#: 81497
10-13-2010, 11:03 AM | #17 | |
Member#: 113924
yea thats a bummer. who is going the machine work now? im sure i asked this before...but i forget. |
10-13-2010, 11:28 AM | #18 |
Member#: 9351
It really sucks that you dont have anyone to call and rag them out! Good luck, maybe this time around will be better then ever. Thats how you have to look at it.
10-13-2010, 11:46 AM | #19 |
Member#: 81497
10-13-2010, 11:46 AM | #20 |
Member#: 81497
Similar Threads | ||||
Bigger wheels or lowered suspension to get rid of wheel gap? | lavid2002 | Newbies & FAQs | 31 | 10-17-2010 02:28 PM |
EJ20G Piston Rings, where to get them? | MeanEditor | Built Motor Discussion | 7 | 04-11-2008 11:38 AM |
Where to get hubcentric rings? | wwiifanatic | Tire & Wheel | 3 | 04-30-2006 05:22 AM |
Building a All Motor drag car.. anybody know where to get a honda shell? | LargeOrangeFont | Southern California Impreza Club Forum -- SCIC | 46 | 12-04-2003 01:43 PM |
Need to get new piston rings, where to get? | Andrew | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 02-06-2002 02:00 PM |
