Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 12-06-2008, 10:43 PM   #1
WR-eX (Honda)
Member#: 175141
2007 wrb wrx
Default vf48 swap into 07 wrx
Hi all! I was thinking of doing a vf48 swap into my 07 wrx.
I needed some opinions on what supporting mods would I need.
Sorry but I'm all so new to this. My current setup is a turboback exhaust and I'm running stage 2 with the accessport. The main reason I'm thinking of doing the swap is because I got mad boost creep/spiking issues. I figure, if I need to take out the turbo to port it - why not just upgrade it! One of my questions are also, do I need to port the vf48 so that I won't have any boost creep?
WR-eX (Honda) is offline   Reply With Quote
Old 12-06-2008, 11:14 PM   #2
07HaWkEyE
Member#: 139080
2006 Trailblazer SS
Summit White 6.0L V8
Take the car into a tuner. The whole boost creep issue was mainly with the vf series turbos. Your td04 should not have this problem, hopefully a tuner can fix this problem for you so that you aren't masking some other problem with the car. A vf48 requires the same mods as a vf39 or vf43.
07HaWkEyE is offline   Reply With Quote
Old 12-07-2008, 06:50 AM   #3
Unabomber
Big Ron
Super Moderator
Member#: 18062
on car parts so PM
me b4 j00 buy
You need to talk to your tuner, NOT us. You'll probably need injectors and fuel pump. It may or may not creep and for that we have a sticky thread that details all of that at the top of this forum, but I would HIGHLY SUGGEST you send that turbo to the Vendor Defiant Autospeed for porting. This would eliminate the creep posibility + he could finally measure the turbo to finally find out if it's the same/bigger/different than the VF39/43 and put that damn issue to bed. PM him and ask about pricing and maybe he'll cut you a special deal since it's a 48.
Old 12-07-2008, 09:11 AM   #4
RexTexWagon
Member#: 150987
2013 Ford Focus ST3
+1 for defiant
But why are you creeping on a cobb map? Have you done something else to the car?
RexTexWagon is offline   Reply With Quote
Old 12-07-2008, 10:20 AM   #5
07HaWkEyE
Member#: 139080
2006 Trailblazer SS
it may not be boost creep, read some of the ops threads/posts. hes had problems with his TGVs in the past and is modding out of order from what i can tell. OP list ALL of your mods please.
Old 12-07-2008, 11:15 AM   #6
All4bSpinnin
Member#: 99102
17 BMW M2
Long Beach Blue 6MT
any internal wastegate IHI tends to get boost creep...
for the turbo upgrade
you need:
VF48
walbro 255... your injectors are the same size as the sti's and they need not be upgraded
All4bSpinnin is offline   Reply With Quote
Old 12-07-2008, 11:44 AM   #7
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
not all ihi boost creep..
come on dave...how many ihi turbos have you had?
Old 12-07-2008, 01:27 PM   #8
07HaWkEyE
Member#: 139080
2006 Trailblazer SS
The OP is not running an IHI turbo. The TD04 is Mitsubishi made. If you read original post the OP is "thinking" about upgrading to the vf48 and currently has "boost creep" on the stock wrx turbo.
Old 12-08-2008, 11:40 AM   #9
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
He said he was doing the swap because of boost creep, which is common with the 07 with a catless TBE. ^ He was saying that by upgrading to the VF48 may not remedy the problem. By him saying "tends to creep" he is saying they have tendencies of creeping, not all will definately creep, though I don't nessecerily agree or disagree with that statement.
Like All4BSpinning said, all you HAVE to have is your turbo and 255lph fuel pump. <- Bare minimum. Or you can be different and get the JDM STi FPR and keep your stock FP. Some say you can "dent" your stock FPR to have better flow. You can also get injectors, larger IC, new turbo inlet, etc. Just read and get your different options.
ThreeEleven is offline   Reply With Quote
Old 12-08-2008, 12:20 PM   #10
WR-eX (Honda)
Member#: 175141
2007 wrb wrx
WOW! Thanks for all the replies guys... But what I was thinking was since I would have to take out the turbo to fix the creep, I might as well put in a turbo with a little more power since the removal of the turbo has to be done. Just so that one day I take out the turbo today to fix the creep and then later down the road decide to upgrade the turbo. At least right now I can save time and money on labor. But since creeping is an issue with ihi's or internal wastegates, I'm not sure what to do. Should I get the 48 ported or it doesn't need to like it's specs claims that it's prone to creep? Also, I already have in hand an 04 sti IC. So all I need is the fuel pump and am I good to go?
Old 12-08-2008, 12:31 PM   #11
WR-eX (Honda)
Member#: 175141
2007 wrb wrx
My tgv problem was because of a faulty tgv. Subaru replaced it already.
My mods in order since day one was - catback, spt intake ( later removed and back to just catback now), cobb ap stg 1 w/ just catback, invidia catted downpipe ( now flashed to stg 2), 04 sti IC (removed because loss of mpg and CEL, took car into subaru and they replaced the tgv), back to full turboback stg 2 without the sti IC.
Old 12-08-2008, 05:51 PM   #12
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
Porting and polishing will remedy boost creep but might not completely eliminate it, though it's possible it could. Are you really have THAT BIG of a problem with this?
Check this out: http://www.cobbtuning.com/info/?ID=3476
Old 12-11-2008, 12:02 AM   #13
All4bSpinnin
Member#: 99102
17 BMW M2
Long Beach Blue 6MT
VF 30, 39, and driven the 43 & 48
the VF48 should be the best performing model to date since things are typically made better over time... if the hotside is ported, have them do the wastegate hole and that will help a bit...
Old 12-11-2008, 11:13 AM   #14
eatus ravenous
Member#: 26068
forget the VF anything unless its a too good to pass up deal ( $$ ) and do it right off the bat . keep in mind that any VF cant be rebuilt ( easily ) and the ones that can are not cost effective to do so . go with a basic TD05 18 G and all will be well
eatus ravenous is offline   Reply With Quote
Old 12-15-2008, 06:07 PM   #15
wrxman420
Member#: 120007
2003 PPG, STG 3+
Am I in Reverse?
The VF48 is a poor mans 18g. It can be had for less $ and puts out similar #'s.
wrxman420 is offline   Reply With Quote
Old 12-15-2008, 06:26 PM   #16
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
+16g > vf48
tux121 is offline   Reply With Quote
Old 12-16-2008, 01:45 AM   #17
WR-eX (Honda)
Member#: 175141
2007 wrb wrx
You sure right about that! I got this thing for $400 brand new! I couldn't pass it up. First thing is - I'm broke as hell but want a lil more kick, second - again, I'm broke as hell. No money to upgrade to fmic or injectors. I gotta settle for the minimum for now.
Old 12-16-2008, 09:44 AM   #18
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
No. Prove it.
Old 12-16-2008, 10:59 PM   #19
wrxman420
Member#: 120007
2003 PPG, STG 3+
Am I in Reverse?
http://forums.nasioc.com/forums/show....php?t=1478419
http://forums.nasioc.com/forums/show....php?t=1514781
These turbos can be had for 700 Brand new. Even cheaper if you find an 08 sti owner looking to upgrade.
swapped older 5 speed into 07 WRX - cruise not functioning Trevor723 Transmission (AT/MT) & Driveline 11 08-31-2009 07:42 AM
Reputable source for jdm transmission? Swapping into 07 wrx q's.. Trevor723 Subaru Conversions 0 02-15-2009 09:13 AM
04 6 speed swap into 02 Wrx with Sti swap drftwell Transmission (AT/MT) & Driveline 28 09-10-2008 09:22 PM
Finished my 07 sti tranny swap into 06 wrx renosubby Transmission (AT/MT) & Driveline 17 12-14-2007 10:04 PM
Need Help!! 07 Sti cluster into 07 WRX JEFFZZ Vancouver Impreza Club Forum -- VIC 0 08-21-2007 01:24 PM
