Brakes & Suspension Forum sponsored by The Tire Rack |
01-30-2006, 09:15 AM | #1 |
Member#: 106329
Is There A Difference In Suspensions With Different Models
Someone Told Me That The Bug Eye Wrx Has A Better Suspension That The New Model (bigger Light) Wrx. How Correct Is That? If There Is A Difference Can Someone Please Tell Me What That Difference Is?
01-30-2006, 10:48 AM | #2 |
Member#: 29355
NWIC
not exactly better, but the strut tops are different on the 04-on so the strut tops must be used for that particular year.
in terms of better... well i really don't think there's too much advantage one over the other. but people should feel free to chime in with more opinion or fact because i really don't know if one is better than the other or not. |
01-30-2006, 10:49 AM | #3 |
Member#: 11482
South East
Vehicle:02 WRX Acute Stickeritis |
Personally I think the valving is better on the newer WRXs; the struts feel a bit beefier. As for the bugeyes, I can't think of anything that is ever considered "better" on those years that wasn't completely subjective.
-Biggly |
01-30-2006, 11:06 AM | #4 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
... unless "Someone" was just referring to the larger (20mm) rear sway bar found on 02/early 03 WRX sedans
01-30-2006, 02:46 PM | #5 |
Member#: 38028
Vehicle:02 WRX Wagon Silver |
Struts were revalved when the top hats were changed in '04. The non-bugeyes supposedly feel better planted. The sedan rear sway was larger (20mm) on 02 and 03 sedans. The fronts have remained unchanged structurally but I am sure were revalved when the rears changed.
01-31-2006, 11:50 AM | #6 |
Visiting NASIOC Timeout
Member#: 105645
Vehicle:2002 WRX Sedan WRBP |
I believe the 06 WRX has aluminum control arms.
02-01-2006, 08:03 AM | #7 |
Member#: 106329
Thanks For The Info Guys
Thanks for the info guys. It seems to me that if the older impreza has a better suspension than the newer models, then Subaru has taken a backward step......something I doubt very much.
why such differences in drops on different springs? | VTSubieRS | Brakes, Steering & Suspension | 3 | 03-20-2007 11:12 PM |
Difference in power with 104 unleaded and C16? | Inprogress | Engine Management & Tuning | 4 | 08-08-2005 01:05 PM |
Differences in Suspensions? | vizwiz | Brakes, Steering & Suspension | 6 | 02-17-2004 04:40 PM |
Differences in engines with same displacement, but different # of cyl.? | NeoteriX | Newbies & FAQs | 7 | 09-11-2003 02:10 PM |
what is specifically different in suspension parts between gga/gda wrx? | Benjamin Tang | Brakes, Steering & Suspension | 19 | 01-17-2003 11:46 AM |
