05-28-2013, 04:32 AM | #1 |
Member#: 350801
BAIC
Vehicle:2012 Subaru Plasma Blue |
ChrisWRX - 2012 WRX 500awhp Build -
What's up guys!
Haven't posted much on here but I have done extensive modifications to the car so far. Hopefully you guys like it! Car: 2012 WRX Base Modifications: Engine: Blouch Dominator 3.0 XTR Full E85 AMS Front Mount Intercooler Injector Dynamics 2000cc Injectors Tomei Unequal Length Headers STI Intake Manifold Deatschwerks DW300 Fuel Pump Killer B Oil Pickup Gates Racing Timing Belt JE Forged Pistons ARP Headstuds Brian Crower Connecting Rods Brian Crower 272 Camshafts COBB up-pipe COBB intake COBB down-pipe Tial 44mm External Wastegate Tial MV-R BOV Invidia Q300 Cat-back System Interior: COBB shift knob Prova Wide-View Rear View Mirror Subaru Extended Arm-rest Pioneer APP Radio 2 JL 12" Subwoofer Engine Dress-up: Carbign Craft Carbon Fiber Alternator Cover ARP Radiator Cooling Plate AeroCatch Hood Pins COBB Tuning Blue Oil Cap Exterior: VIS Carbon Fiber Hood VIS Carbon Fiber Trunk Subaru OEM Vortex Generator 18" Rota Grid Bronze Rims Prova Blue Wide-View Door Mirrors Rally Armor Mudflaps JDM Rear Light Cusco Front Tow Hook Cusco Rear Tow Hook Subaru OEM Rain Guards Hella Supertone Kit Proto License Plate Camera Mount Drivetrain: 2007 STI 6 Speed Transmission ACT StreetLite Flywheel ACT 6 Puck Heavy-Duty Clutch Kartboy Short Throw Shifter Kartboy Shifter Front Bushings Kartboy Shifter Rear Bushings Electronics: GrimmSpeed Electronic Boost Control Solenoid HydraEMS Standalone ECU Suspension: Ksport Kontrol Pro Coilover Kit Whiteline Anti-lift Kit Cusco Front and Rear Strut Bars Eibach Sway Bar Kit Beatrush Forged Pitching Stopper Mount Parts For Sale: 2012 WRX Transmission Stock Cat-Back Exhaust Stock Headers Stock Down-pipe COBB tuning Accessport Plasma Blue Hood Plasma Blue Trunk Injen Cold-Air Intake 1000cc Injector Dynamics PM for More Parts! Last edited by 2012BayAreaWRX; 05-28-2013 at 03:37 PM. |
05-28-2013, 04:46 AM | #2 |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
How much hp you putting down?
05-28-2013, 04:49 AM | #3 |
Member#: 350801
BAIC
05-28-2013, 09:57 AM | #4 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
05-28-2013, 08:29 AM | #5 |
Member#: 261612
Vehicle:2002 WRX - 750WHP 9.5s @ 150mph |
Looks like a fun setup. I would like it much better with the CF paint matched.
And I can't believe you left the air pump in place! |
05-28-2013, 09:27 AM | #6 |
Member#: 58251
Vehicle:2004 Sti GT35R 530whp @ 27psi |
That has got to be the most inefficient charge pipe routing I have seen on a subaru... You're probably losing 20-30whp alone from your piping.
It would've been much better to run clockwise rotation, and go IC->TB from the passenger side. Every 90 degree bend you have to make hurts your flow quite a bit, and that design has like 4 of em Other than that, nice results - interested to see the curve. |
05-28-2013, 01:56 PM | #7 | |
Member#: 350801
BAIC
I'm sure there's a reason for everything he did on the build. |
05-28-2013, 01:58 PM | #8 |
Member#: 350801
BAIC
05-28-2013, 09:47 AM | #9 |
Member#: 261612
I'd much rather run this setup than the clockwise routing that puts the cold side pipe directly over the turbo. This adds two 90 deg bends but it prevents the air from going right over the (hot) turbo immediately before going into the intake manifold. The clockwise setup might perform well on the dyno for single pulls, but I wouldn't want it on the street or road course. I am blown away when I see people still running the clockwise piping.
05-28-2013, 09:56 AM | #10 |
Member#: 128760
RMIC
Vehicle:2017 STI Silver |
This is why I like a rotated set up better, you have the chance to run the piping under the intake manifold and still have room for the intake.
05-28-2013, 01:56 PM | #11 |
Member#: 350801
BAIC
05-28-2013, 10:28 AM | #12 |
Member#: 321211
South East
Just a single dw300??
05-28-2013, 02:00 PM | #13 |
Member#: 350801
BAIC
05-28-2013, 10:45 AM | #14 |
Member#: 279660
i really want to see an actual dyno sheet...
05-28-2013, 11:05 AM | #15 |
Member#: 318755
South East
Vehicle:2012 Phatbotti Tuned |
paint match the carbon itll look way better
05-28-2013, 12:52 PM | #16 |
Member#: 343485
what's the weight reduction from oem to carbon fiber hood & trunk ?
05-29-2013, 07:01 PM | #17 |
Member#: 293500
BAIC
Vehicle:2015 FXT Stage 2 CWP |
Nice! Where in norcal are you at? Ever go to any of the meets? Would love to see this car in person.
05-29-2013, 07:29 PM | #18 |
Member#: 350801
BAIC
05-29-2013, 08:39 PM | #19 |
Member#: 254718
How did you not max that fuel pump on corn? Thats insane!
05-30-2013, 04:45 AM | #20 |
Member#: 350801
BAIC
05-31-2013, 02:43 PM | #21 |
Member#: 32669
SCIC
What about that dyno chart?
05-31-2013, 03:24 PM | #22 |
Member#: 239945
What were the IDC's on the ID2000?
05-31-2013, 04:26 PM | #23 |
Member#: 350801
BAIC
05-31-2013, 04:25 PM | #24 |
Member#: 350801
BAIC
06-01-2013, 12:34 PM | #25 |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
Interesting setup. Definately curious to see the charts for this.
What's the reason for running the Hydra as apposed to Cobb Speed Density software with the stock ECU? Thanks -- Ed |
