07-12-2003, 06:48 PM | #1 |
Member#: 39258
Vehicle:1993 Impreza White |
Anyone know where the test connectors are.....
on my 93 Impreza 1.8L? I can't find them. Please help. I need to run the tests on my car.
07-12-2003, 10:07 PM | #2 |
Member#: 33067
Vehicle:1998 Legacy Wagon Spruce Pearl |
well, since nobody replied yet, I'll give you a guess. Look to the left of the steering wheel on the lower part of the dash. If it isn't there, just keep looking around at the underside of the dash.
07-13-2003, 01:21 AM | #3 |
Member#: 19332
Test connector? You mean the OBDI access port? If so it should be around the dash board.
07-13-2003, 02:02 AM | #4 |
Member#: 33067
Oh... I should've mentioned, I also assumed that was what you were looking for
07-13-2003, 11:00 AM | #5 |
Member#: 39258
I need to run the self diagnostic test on my car through the Check Engine Light. Someone told me that the test connectors and everything were on the Passenger side of the car behind the dash. When I went to look I coudn't find anything but the ECU. I would like to run the diagnostic test to see why my Check Engine Light is on. When it comes on, my cooling fans run all the time.
07-13-2003, 11:11 AM | #6 |
Member#: 33067
Okay... it should be on the driver's side then
Anyone know where my JDM Parts are? | ProjektPhoto | Mid Atlantic Impreza Club -- MAIC | 25 | 11-18-2009 12:43 PM |
Anyone know where tokico d-spec are in stock | Imprez04 | Brakes, Steering & Suspension | 5 | 07-25-2008 04:14 PM |
Does anyone know where the sideskirt painting instructions are? | Padge | Mid Atlantic Impreza Club -- MAIC | 3 | 02-10-2008 11:46 AM |
does anyone know where the vaccum line to the Driver's TGV go? | brazymstrp | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 10-19-2004 10:48 AM |
Anyone know where the test connectors are..... | 93Scoobster | Normally Aspirated Powertrain | 1 | 07-13-2003 01:56 PM |
