02-21-2002, 11:51 AM | #1 |
Member#: 10465
Vehicle:91 Syclone Only 1 color |
what would you guys recommend for 65K mileage maint.?
i have just hit 65,000 miles in my RS.
what would you guys recommend for manitenance. i have changed my oil every 3K but i dont really know what else to do. thanks....cvcsmkr
02-21-2002, 12:42 PM | #2 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
here is recommended list of what "should be" done at a 60K service:
FACTORY AND AREA CLIMATE RECOMMENDATIONS Change engine oil Change engine oil filter Check all fluids and fill as necessary Rotate tires and check tire pressures Flush and service cooling system Automatic transmission service - drain and fill Drain and fill gear oils Change brake fluid in reservoir Tune engine Change spark plugs (2.5 L and SVX at 60k, 120k) Perform induction & intake system service Clean throttle assembly and linkage Change air tiller and fuel filter Adjust Carb, change cap and rotor (if applicable) Compression check (2.5 L and SVX at 60k, 120k) Set timing and test emissions Check engine computer for fault codes Check for oil leaks Adjust clutch and hillholder (if applicable) Check brake linings and adjust parking brake Check C.V. joints Check exhaust system Test/service battery, install anti-corrosive battery pads Adjust ECVT switches (Just automatic) Adjust valves (if applicable) Adjust drive belts and inspect hoses Lube locks Check all exterior lights for proper function Check windshield washer and wiper operations Road test - check steering, heating & running condition ADDITIONAL RECOMMENDATIONS Timing belt replacement at 60,000 miles (most models) Replace drive belts at 60k hehehehe hope this helps! Jamie www.subiegal.com |
02-21-2002, 05:33 PM | #3 |
Member#: 10465
thats all
thanks subie gal |
02-21-2002, 06:51 PM | #4 |
Member#: 7624
Vehicle:BD5; family sedan that just wooped your ass |
The timing belt doesn't need to be changed untill 90-110k. Go to Subaru.com and it will tell you what needs to be done.
02-24-2002, 02:18 PM | #5 |
Member#: 4496
Vehicle:2009 Forester red |
cvcsmkr... please check your email regarding the intake. your pm is not taking any messages
ben |
What would you guys pay for this box? | iheartSTI | Car Audio, Video & Security | 12 | 12-17-2008 11:51 AM |
What Brand do you guys Recommend For the 750cc Injector? | Jimmy168 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 10-31-2008 05:16 AM |
Buying Perrin Pulley, what store would you guys recommend? | rukkie | Private 'Wanted' Classifieds | 8 | 09-20-2004 11:36 PM |
What brake pads do you guys recommend for stock wrx rotors? | SinhCredible | Brakes, Steering & Suspension | 14 | 09-17-2004 11:56 AM |
What kind of mods would you guys suggest for a Noobie? | finnRex | South East Region Forum | 7 | 07-09-2002 05:13 PM |
