07-25-2007, 03:37 PM | #1 |
Member#: 89013
Vehicle:2012 370Z 6spd Sport Gunmetallic |
installed boost gauge, parking lights stuck on on after key removal
i just installed a boost gauge on a friends MY04 wrx, and i didnt notice whether or not it did this before hand, but the turn signal stays lit unblinking (which im guessing is the parking lights)
we tapped a line off the back of the cd player (it was a solid blue color, the previous owner did alot of crappy splicing and electrical work and i didnt take notice if the line leading out of the cd changer was a different color) any idea what would make these stay on? what can we do to get these to turn off once the key is removed from the ignition even when the lights are already turned off????? thanks a bunch
07-25-2007, 03:39 PM | #2 |
Member#: 89013
i should add that we tested that power source with one of those pen lights that has a ground running to it with an alligator clip.... the light shut off when the key was removed from the ignition
07-25-2007, 03:43 PM | #3 |
Member#: 59993
International
Vehicle:Ass, grass or cash no one rides for free!! |
have you checked if you accidentally pressed the parking light switch that's on top of the steering column?
07-25-2007, 07:12 PM | #4 |
Member#: 140712
SCIC
Vehicle:2008 WRX STI White |
yep, turn off that switch on top of the steering column.
Shane |
07-25-2007, 07:28 PM | #5 |
Member#: 116910
Refer to the FAQ of the Century, at the top of this section.
Hitting 9psi after installing boost gauge | Penguin150 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 04-10-2007 04:38 PM |
What should the factory installed boost gauge on an STi read? | SithSolo1 | Newbies & FAQs | 3 | 01-03-2005 02:54 PM |
HELP-installed dimmer mirror and boost gauge-running lights will not turn off | cjsalv63 | Electrical & Lighting | 3 | 10-09-2004 02:09 PM |
CEL after installing boost gauge | aznfoos | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 03-12-2004 12:19 PM |
Parking Lights stuck on | AllAWD | Newbies & FAQs | 23 | 08-21-2002 09:26 PM |
