07-14-2003, 06:52 PM | #1 |
Member#: 24741
W. Canada
Vehicle:1997 Legacy GT black |
new deck installed but lights are gone!!!
I installed a new deck myself (prolly a bad idea) but now my lights for my dash and center floor console (where the shifter is) do not work!!
I have a 97 Legacy Somebody please help!!!!!!!! thanx
07-14-2003, 07:34 PM | #2 |
Member#: 8124
Vehicle:1998 Old Grey Mule Regacy Rype R |
you may have installed it wrong and blown a fuse.
try taking it out and re-verifying your connections are correct on the deck. Did you solder wires or use a wiring harness like the Crutchfield one? -S |
07-14-2003, 08:46 PM | #3 |
Member#: 24741
W. Canada
The connections should all be correct cause everything else is working but the lights.
I checked the fuses and they're ok.....unless I checked the wrong ones |
07-15-2003, 01:41 AM | #4 |
Member#: 12535
Vehicle:Low 06 5MT OBXT 92 EG33 Legacy Rally Car |
well SOMEthing is not correctly wired back there. there is that "illumi" connection that probally isnt hooked up or mabye it just came loose. Triple check your fuses. Good luck.
07-15-2003, 12:33 PM | #5 |
Member#: 24741
W. Canada
2 wires only 1 to connect to
I checked the radio wiring diagram and there are 2 wires for interior light but there is only 1 wire left on the aftermarket deck which is the illumination one
07-15-2003, 12:33 PM | #6 |
Member#: 24741
W. Canada
Similar Threads | ||||
new radio install gone bad (dash lights out) | Jamo06TR | Electrical & Lighting | 4 | 01-10-2008 06:21 PM |
Finally got my new exhaust installed, but it sounds wrong. | chrislehr | Off-Topic | 16 | 10-24-2004 08:14 PM |
cruise and fogs lights are gone!! | gelgel | Interior & Exterior Modification | 5 | 07-02-2004 01:25 AM |
('93-'01) need to set up a deal, but PMs are gone helpppp | Sin | Impreza Forum | 2 | 06-07-2001 10:58 AM |
('93-'01) So, I guess all the new 2001 2.5 RS's are gone now? | driver | Impreza Forum | 17 | 05-08-2001 12:47 AM |
