Tire & Wheel Forum sponsored by The Tire Rack |
02-02-2003, 07:49 AM | #1 |
Member#: 6220
Vehicle:99 ej25sett/TEC II -:GaraGe ChimEra:- |
will lower wheel offset push wheels out giving wider stance?
I was wondering if I got a wheel offset smaller then the recommended 48+ if it woudl actually set the whees farther apart safely making the tire track wider? I do understand that the fenders would have to be modified. are there are others ways to widen track width other then wheel spacers? thanks
John |
02-02-2003, 09:48 AM | #2 |
Member#: 18148
Vehicle:'08 WRX Dark Gray |
John,
A lower offset will, indeed move the tires further out. As you mention, wheel spacers do the same thing. There are some practical limits how far you can go with this: 1) fender clearance. 2) increased wear & tear on the drivetrain. Not sure there's an absolute limit on 2, but as you push the wheels out, your wheel bearings will suffer. FYI - If you want to run really wide wheels/tires, you need to run a lower offset, just to gain clearance on the inside of the wheels. Here's a good description of offset. http://www.tirerack.com/wheels/tech/offset.htm -Steve Last edited by MNbiker; 02-02-2003 at 02:08 PM. |
02-02-2003, 09:55 AM | #3 |
Member#: 4229
Vehicle:2003 S2000 Did someone say track day |
also the problem is that when if you push the offset out to far and don't have wider wheels to keep the centers in roughly the same place as stock, you don't get as much car yaw per angle of steering wheel turn.
So really, it's best to keep the center of the wheel in roughly the same location if possible |
02-02-2003, 04:39 PM | #5 | |
Member#: 2184
Vehicle:2005 Legacy GT wagon Platinum Silver Metallic |
Kevin |
02-02-2003, 05:17 PM | #6 |
Member#: 31002
Vehicle:2002 WRX Blue |
You basically want to keep the king pin axis centeded in then contact patch of the tire or slightly ahead of it for better tracking.
02-02-2003, 06:57 PM | #7 | |
Member#: 4229
02-02-2003, 08:29 PM | #8 |
Member#: 31002
exactly.
02-03-2003, 02:20 AM | #9 |
Member#: 6220
thanks
I was just thikning getting a 7.5" tire with a very small offset maybe +40 or so, so I can fit a wider wheel in the fronts and not neccessarily the back so I have better (supposedly) traction for sterring. thanks for all the help and the links.
John |
Similar Threads | ||||
What Offset and Wheel Size gives me more room? | Kaymin | Tire & Wheel | 0 | 05-26-2006 10:54 PM |
Will UD pullies offset the affect of heavier wheels? | fueledbymetal | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 07-01-2002 09:43 PM |
lowering and wheel offset?? | ANW | Brakes, Steering & Suspension | 1 | 10-01-2001 06:37 PM |
What Wheel Offset is right for a lowered Legacy? | MY99 2.5GT | Legacy Forum | 15 | 04-14-2001 12:17 AM |
will a +45 offset work on an 18X7.5 wheel? | scootr | Brakes, Steering & Suspension | 13 | 03-17-2001 07:37 AM |
