11-05-2002, 01:34 PM | #1 |
Member#: 25194
RMIC
Vehicle:2008 Forester XT 5mt Dark Gray |
NEED HID looking fog and high beam bulbs to match
my Hella H7 purple (whitish/blue) HIDs. The other lights including the parking side markers (perfect clears) look like junk IMO. I need the following:
amber side marker bulbs whitish/blue fog bulbs in 55w to match headlights (close as possible color match wise) And hopefully high beams in a whitish/blue to also match. Is it even possible to replace my DRLS with blueish bulbs as well????? I have the WRC headlights pictured in the link below. http://www.vividracing.com/prod_extlight.php Many many thanks in advance. the car looks odd with multiple color lights.
11-05-2002, 02:22 PM | #2 |
Member#: 23463
Vehicle:I am carless now :o( |
Good luck its hard as hell trying to match the high and fogs to real HID.
As far as the amber bulbs Walmart Autozone Shucks Pep Boys are your friend they sell amber bulbs for 2-5 dollars |
11-05-2002, 02:29 PM | #3 |
Member#: 25194
RMIC
ok, so I have the sides taken care of
the fogs and highs are up next on the list. What wattage are they? I believe fogs are 55 but I don't know what the high beams are.
There are a ton of blue/white bulbs on teh market for direct drop in but I don't have easy access to try out a bunch to see which color matches. I guess I could buy a bunch and then return the other ones and neglect to mention that they are used there must be another way though. Anyone out there find some fogs that match anywhere close? |
11-05-2002, 03:20 PM | #4 |
Member#: 4597
TXIC
Vehicle:2011 Mitsu Outlander Sport (Ex-Suby owner X3) |
without HID fogs, you wont match them, no matter what you try....try doing a search, people have asked about this before....the fog housing is to large to focus the "color" of the bulb, the light dispersed is to great, therefore, no matter the color of the bulb, you wont get the right output...even my hella yellowstars look blueish instead of yellow.....but that is what i did, just give up on color matching and go for contrast, ie YELLOW bulbs...good luck though...if you want hid fogs, i think TaiChi used to be able to get them...
11-05-2002, 03:29 PM | #5 |
Member#: 25519
Vehicle:2002 WRX Steel Grey |
PIAA Plasma H3's look similar to the purplish hid's. hope that helps
11-05-2002, 03:44 PM | #6 |
Member#: 8305
BAIC
Vehicle:2001 2.5RS Gunmetal |
You should definetely get only PIAAs for you fogs. I've tried two different hyperwhite bulbs in my fogs and it always comes out yellow...i've heard it has something to do with how our lights reflect the bulb.....
....but with PIAAs it'll turn out hyperwhitish..depending on which type you get..my friend had some and it was nice. |
11-05-2002, 06:01 PM | #7 |
Member#: 21146
I think sylvania bulbs are better then the PIAA's according to most places. There was even a thread about that recently....
11-05-2002, 08:59 PM | #8 | |
Member#: 8305
BAIC
11-07-2002, 05:14 PM | #9 |
Member#: 25194
RMIC
Thank you guys for the input.....
I'm going to track down some PIAA lights locally and give them a try in the fog housing.
My other question is this: When I turn on my headlights there is a tiny littly white blub in my high beam housing that turns on. Kind of like the size of the side marker bulbs. They don't come on as DRLS though, just my HIDs do (I'm going to pull the relay tonight). Any thoughts on what they are, or if I should pull them out. Maybe replacing them with a red bulb would be fun to give a bit of the BMW hallow effect. |
09 Impreza - park lights and fogs/fogs and high beams | ST3 | Electrical & Lighting | 2 | 07-24-2009 12:40 PM |
High Beam Bulbs for BUGEYE JDM HIDS PROJECTORS? | ultraspdWRX | Interior & Exterior Modification | 11 | 06-16-2008 08:00 PM |
hid morette, fog and high beam problem | chadt02 | Electrical & Lighting | 2 | 12-22-2007 10:15 PM |
STI HID Bulb, High Beam Bulb, Blinker Bulbs and Harness | PIGGY | Private 'For Sale' Classifieds | 39 | 07-09-2006 08:39 AM |
