11-01-2007, 02:41 AM | #1 |
Member#: 148290
03 WRX VF39 mapp
Any one out there have a Mapp for an 03 WRX with VF39, sti TMIC, sti pinks, and sti exhaust? if so could any one help having some problems with my mapp, latency values are off causeing misfires at idle due to lean idle, so if any one has a mapp that good please help out thanks alot
brandon |
11-01-2007, 03:04 AM | #2 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
sti exhaust, so just a stock downpipe?
11-01-2007, 03:26 AM | #3 |
Member#: 148290
yeah basically i guess its said that the sti DP flows a bit more than the wrx DP
11-01-2007, 03:29 AM | #4 |
Member#: 63955
Vehicle:2013 FR-S Asphalt Grey |
Don't Cobb AP's come with a couple vf39 maps?
11-01-2007, 03:38 AM | #5 |
Member#: 148290
yeah but the only thing is i dont use the cobb ap i use enginuity and i dont know any one with the cobb ap we all use enginuity but im just having a bunch of problems with my mapp. its leaning out at idle.
11-01-2007, 03:45 AM | #6 |
Member#: 63955
11-01-2007, 03:58 AM | #7 |
Member#: 148290
Wish there was a way to convert Cobb AP to Enginuity they have the mapp i need |
11-01-2007, 04:32 AM | #8 |
Member#: 108089
the sti's catback flows better than the wrx's catback, yes
as for downpipe, I dont think so Most maps are tuned for a hiflow cat/catless downpipe doesn't mean that it won't work, you'll just need a custom tune |
11-01-2007, 08:10 AM | #9 |
Member#: 44422
SWIC
Vehicle:2009 G8 GT Cammed, sprayed, stalled |
Brandon, you should call me if you are still having issues. I can't fix it through email.
11-01-2007, 10:09 AM | #10 |
Member#: 110304
Vehicle:2004 Volvo S60R No more Subie |
Every 2.0L WRX, map I've seen for pinks do not have different latency values, they are the same as stock. Even the '03 JDM 2.0L STi uses the same values. I usually see the scaler set around 520cc give or take depending on the map. I based my map off of ev8siv3's vf series 91 octane map and I'm rpetty happy with the results, only needed slight tweaking here and there because I use even bigger injectors. Latency is probably not your problem, use the stock values.
11-01-2007, 10:31 PM | #11 |
Member#: 148290
ok jeremy ill Call you when i get the chance im waiting on a new phone thats why i havent been able to call or anything to figure this out, thanks alot
11-02-2007, 11:20 AM | #12 |
Member#: 136384
SCIC
Vehicle:06 WRX Dipped with custom blend |
Have you tried using the injector latency spreadsheet @ the enginuity forums? It helped me get it pretty close to perfect and I use modded stockers for injectors.
11-02-2007, 12:17 PM | #13 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
Vehicle:98 2.5 RS 04 WRX |
There is a VF34/39 map on osecuroms.org, I believe it is for a 04 or 05 ecu so you'll just need to convert to a 02 or 03 map.
I have a VF34 tuned map for an 02 (I usually flash 02 maps onto 03s because the tables are bigger) if you want to PM me your email address. The VF34 is virtually identical to a 39 so it won't make a difference. |
11-03-2007, 11:11 AM | #14 |
Member#: 110304
^ That is for the most part what I am using right now... not bad for an OTS map. I think I might need to back off on the timing a little for safety. While my IAM has stayed solid at 16, I do encouter some occasional negative KC when it's warm out and the IC has heat soaked. When it's a cool night out I don't see any -KC, so it just needs some slight tweaking. The boost holds very steady and right on its 16psi target without any modification to the boost maps.
11-05-2007, 10:53 PM | #15 |
Member#: 148290
+ 1 for Master2192 Mapp fixed all my problems no, over heat at idle, no more misfires, runs nice just need a tweek with the WGDC and Target boost
11-06-2007, 12:19 AM | #16 | |
Similar Threads | ||||
02-03 WRX HOOD any color | Kyle_R | SCIC Private Classifieds | 4 | 06-28-2010 11:16 AM |
03 Wrx Vf39 For Sale 62k $14500 Obo | CAINWRX | Private Vehicle 'For Sale' Classifieds | 3 | 09-20-2008 01:06 PM |
03 Wrx Vf39 For Sale 62000k $14500obo | CAINWRX | SWIC Private Classifieds | 1 | 09-18-2008 10:08 PM |
03 wrx vf39 meth | stangen97 | Proven Power Bragging | 4 | 12-19-2007 06:24 PM |
03 wrx vf39 100 oct results | mitchwrx | Proven Power Bragging | 11 | 03-11-2005 05:26 PM |
