12-11-2005, 08:39 PM | #1 |
Member#: 71339
International
Vehicle:1995 WRX STi RA 1995 WRX STi LS1 |
Version 5 STi 5 speed swap
Anyone know if a V5 (1999) Sti (444) close ratio 5 speeder will boly up to a 2002 WRX? Can't seem to find anything on the suitability of this box in this forum.
12-11-2005, 08:51 PM | #2 |
Member#: 68602
Vehicle:02 STi Wagon |
yep. I've got one in my car. Great acceleration at any speed and highway cruising revs are high enough that you dont really need to downshift to pass people.
12-11-2005, 09:00 PM | #3 |
Member#: 67229
Vehicle:9295 BC/gm6 winestone/funky blue |
did it affect your gas mileage
12-11-2005, 09:06 PM | #4 | |
Member#: 68602
I've got the usual boltons, bigger turbo, big top mount, ecutek, and I get anywhere between 260 and 300 miles per tank. Not far off from a typical stage 4 car. |
12-12-2005, 12:42 AM | #5 |
Member#: 71339
International
WOW. That sounds encouraging. Did you need to change anything like diff ratio or did you do just a straight bolt up job?
12-12-2005, 09:35 AM | #6 |
Member#: 16100
Vehicle:GD |
What is the strength of that transmission compared to stock?
12-12-2005, 09:54 AM | #7 |
Member#: 1581
Vehicle:MY00 RS/STi7 MY01 RS Both Silverthorne |
You need a 4.44 rear diff. I think my second goes up to 72mph at 8k rpm's. My theoretical topspeed is about 185ish at 8k.
12-12-2005, 12:51 PM | #8 | |
Member#: 68602
There is a gear ratio/speed calculator in the sticky at the top of this forum, plug in the gear ratios and see what kinda speeds it will get. I really feel like I need a higher rev limit with these gears since 2nd doesnt even get to 60mph (8K redline would haul). |
ppg 5 speed v.s. sti 6 speed swap. | Jonx1218 | Transmission (AT/MT) & Driveline | 8 | 05-21-2008 04:47 PM |
FS: JDM Version 7 STi 6 Speed Transmission | subenick | Drivetrain | 1 | 12-23-2006 12:53 PM |
Sti 6 speed swap in 03 wrx? | 03scubaru | Transmission (AT/MT) & Driveline | 0 | 04-08-2005 12:39 PM |
STi 6 Speed Swap | spoolinsuby | Transmission (AT/MT) & Driveline | 2 | 02-18-2005 05:23 AM |
sti 6 speed swap help? | shadymilkman129 | Transmission (AT/MT) & Driveline | 7 | 04-21-2004 08:00 AM |
