Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 11-04-2014, 03:52 PM   #1726
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Do Blouch and other companies still offer this 19t? I cant seem to find them anywhere.
4eat05 is offline   Reply With Quote
Old 11-04-2014, 04:46 PM   #1727
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Mid west turbo offers it and I think Bloush will do it if you ask
labcoat is offline   Reply With Quote
Old 11-05-2014, 01:22 AM   #1728
CalvinT
Member#: 329025
2002 WRX Wagon
Blouch doesn't list it on their website, but call Mike Blouch. They still do it.
CalvinT is offline   Reply With Quote
Old 12-09-2014, 02:27 AM   #1729
iSamPDX
Member#: 358766
2002 Wrx
Is there someone I can send my TD04 That can do 19t upgrade, pnp and rebuild?
iSamPDX is offline   Reply With Quote
Old 12-15-2014, 07:49 AM   #1730
Lochaves
Member#: 404446
You can do that at Midwest Turbo Connection
Lochaves is offline   Reply With Quote
Old 12-15-2014, 05:55 PM   #1731
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Starts @ $600 for a rebuild and upgrade to 19T. But if you're TD04's shaft is bad, you're looking @ min. $295 upcharge for their H or HL shaft.
For a new turbo = not bad $.
wtdash is offline   Reply With Quote
Old 02-15-2015, 06:35 PM   #1732
Burdinej
Member#: 413617
Default Td04 13t billet
Has anyone ever used the 13t billet wheel and if so what did you like didn't like is it worth it etc.
Burdinej is offline   Reply With Quote
Old 05-09-2015, 09:54 PM   #1733
ForesterWTi
Member#: 173892
2005 SpecB 1of1 BPE
grandma gold
Due to a page back where a member mentioned a lack of dyno plots postings lead me to break my YEARS of silence and re-post my dyno plot at only 17.5 psi and cf:1.28
MY95GF8 (complete 2.0L rex swap)
-stock L+R side headers
-Gimm x-pipe
-stock STi up pipe
-PT's "monstah" td04
-tbe
-hallman rx mbc
-HUGE tmic
-inlet w/ sri
-PE 650cc + walbro fp
ForesterWTi is offline   Reply With Quote
Old 05-09-2015, 09:54 PM   #1734
ForesterWTi
Member#: 173892
2005 SpecB 1of1 BPE
grandma gold
oops bare with me, like I previously stated... it's been years, literally lol
https://plus.google.com/109440092790...92790739054166
Old 05-10-2015, 10:21 AM   #1735
wrxhard
Member#: 108091
Wow. That is just terrible. That's like... 35r spool with 16g power... There's gotta be a pre turbo exhaust leak or something going on there. Thanks for sharing, but it doesn't look quite right.
wrxhard is offline   Reply With Quote
Old 05-10-2015, 01:06 PM   #1736
ForesterWTi
Member#: 173892
2005 SpecB 1of1 BPE
grandma gold
Oh it's very right I assure you, given the turbo and what it was set up to do. It was a two year R&D project, and was a blast for long pulls, especially highway passes
The td04 was ported on both sides for a 19t compress and HL hot side, iwg ported, and a welded divider inside the turbo separating the wheel from the iwg door with the downpipe venting this iwg atmospherically through it's own pipe separate from the downpipe itself (post turbo, not pre). So the hotside wheel had absolutely no impedance from the iwg opening and stopping all cross flowing problems that happen with normal bellmouth downpipe designs. I was able to beat 250awhp with a td04 and stock headers/up-pipe. Yes it does hit late in the rpm, but take notice the horsepower does not taper towards redline but rather continues to climb. I was able to get 16g cfm's out of such a tiny snail and that is while keeping it under 18psi. Yes, I could have cranked up the boost and switched to flexfuel, netting me easily over 300awhp. However, that was not the intent of this build. Rather, it was to produce over 250awhp on a "near stock" motor with minimal need of supporting mods/parts. The downside is that it does not hit early any longer, and in turn, shifts the graph to the right, as intended. Plus... pop the hood and I look completely bone dry stock. Also keep in mind this was on the stock internals of a usdm 2.0 motor not a jdm 2.0 or usdm 257.
Old 05-10-2015, 01:11 PM   #1737
wrxhard
Member#: 108091
As long as you like the way it feels, that's all that matters. Enjoy!!!
Old 05-10-2015, 01:40 PM   #1738
ForesterWTi
Member#: 173892
2005 SpecB 1of1 BPE
grandma gold
Thanks, and I very much enjoyed her. I actually drove to NorCal three months after that dyno tune and she was parked indefinitely because I would never have passed smog
A previous customer of mine, whom bought a 1.8/2.0 td04 impreza L project I had, sold it and flew from Denver to the closest airport... then took a $400 taxi one way to my house in NorCal, just to buy this one of one GF8 from me
Henceforth, I've had 17 Subaru builds in just shy of the past 11 years.
Old 05-11-2015, 10:26 AM   #1739
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
For reference when the pic dies:
262.5 HP
~241 Ft-Lbs.
Old 05-18-2015, 08:07 PM   #1740
ImprezaLover94
Member#: 265684
2003 WRX Wagon
Has anyone seen these?
http://www.ardideas.com/Billet-Alumi...ion_p_121.html
They are made for Volvo's, but I was told the conversion 19T wheel with a 56mm exducer diameter will fit our stock 13T CHRA so no machining is necessary. The only other thing it would need would be a 19T compressor housing, like this:
http://shopping.kinugawaturbo.com/tu...d04l13t-1.aspx
How would that run with the stock TD04L hotside? I noticed through my research that a lot of people try to upgrade the turbine to the H or the HL. What would be the downside of using the standard L? Is it just slower to spool or falls off sooner at top end? Does it make it inherently weaker/less reliable?
ImprezaLover94 is offline   Reply With Quote
Old 05-26-2015, 04:40 PM   #1741
ForesterWTi
Member#: 173892
2005 SpecB 1of1 BPE
grandma gold
You are right. It will spool up faster than stock and then fall flat on it's face because of the stock hotside L wheel. It's a great mod for a DD, and autoX/rallyX.
Old 06-05-2015, 12:16 PM   #1742
mazdaboi
Member#: 281797
EVO Graphite Gray
Wow, very interesting thread, I came across this after looking up a local tuner and parts shop in the DC area. http://6starspeed.com/sutdtuperese.html
They do the 19T upgrade. I may be visiting them and getting some more info.
mazdaboi is offline   Reply With Quote
Old 06-18-2015, 09:43 PM   #1743
Philscordato
Member#: 397001
2004 Forester XT
Cayenne Red Pearl (22w)
I have a 2004 subaru forester xt (ej255) with a td05-20g-8cm^2 (8cm^2=hotside a/r of .57). I was wondering if i could replace the 20g wheel with an 18g wheel. Would it be a direct swap with no other modification needed ? I would probably need a re-balance after correct ? Could you recommend a good 18g wheel for me to purchase ? I also have a td05-18g-7cm^2 (7cm^2=hotside a/r of .49) would swapping the hotsides be an easier solution to get the end result of td05-18g-8cm^2 (8cm^2=hotside a/r of .57) .
Thanks,
Phil
Philscordato is offline   Reply With Quote
Old 07-14-2015, 12:05 AM   #1744
CRX7
Member#: 31639
99 Impreza
Just swapped in a billet 19t with a TD04L hotside. I've finally worked out the wastegate kinks and I think I like it. Spool is a little better than the 16g TD05 I had on before, but I'm not sure it's worth the top end loss. Good for around town driving, but on the freeway and in the moutains, it's just not as powerful of course.
CRX7 is offline   Reply With Quote
Old 07-14-2015, 12:10 AM   #1745
CRX7
Member#: 31639
99 Impreza
Might be worth it to upgrade on the cheap side. I had a lot of trouble getting anyone to modify my CHRA housing for a reasonable price. I ended up just buying a 19t CHRA, along with the billet 19t wheel and compressor housing.
Old 05-26-2018, 09:56 PM   #1746
viper1982
Member#: 468807
1999 IMPREZA GT WRX
BLUE
Default tTD04 HL 19T vs TD04 13T
Measurments:
TD04L-13T - 6
390 CFM @ 1 BAR / 14,7 PSI
COMPRESSOR WHEELL 6 Blades Inches mm
INDUCER 1,85 47,0
EXDUCER 1,61 41,0
TURBINE WHELL 12 blades Inches mm
INDUCER 1,85 47,0
EXDUCER 1,63 41,3
TD04HL-19T - 6
500 CFM @ 1 BAR / 14,7 PSI
COMPRESSOR WHEEL 6 Blades Inches mm
INDUCER 2,28 58,0
EXDUCER 1,81 46,0
TURBINE WHELL 12 Blades Inches mm
INDUCER 1,85 47,0
EXDUCER 1,63 41,3
viper1982 is offline   Reply With Quote
Old 06-21-2018, 10:51 AM   #1747
konmann
Member#: 125466
2006 WRX TR
SGM
Default TD04 19T Upgrade Discussion
Just wanted to say that I have been this route. It has a cool factor to it, but you can easily make more hp with a vf39 or equivalent.
Basic mods were larger injectors
Walboro fuel pump
Sti equivalent intercooler and shrouding
Turbo back exh.
I don’t know what you’ll get by just replacing the turbo, however it will most likely be close to an STI or equivalent.
Please check out my EFI Logics dyno plots concerning this turbo and my upgrades afterwards.
Look under the name Konrad Mann on their website.
Regards
konmann is offline   Reply With Quote
Old 06-21-2018, 05:18 PM   #1748
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Better yet, just start with the Tomei 7760 single scroll.
Fierysun is offline   Reply With Quote
td04 19t blouch upgrade. WhiteBgeye02 Private 'Wanted' Classifieds 1 06-23-2010 08:35 PM
WTB td04 for 19t upgrade tanner127 Private 'Wanted' Classifieds 3 04-13-2010 08:04 PM
Blouch TD04 19T upgrade on 4EAT. Opinions Brock31 Transmission (AT/MT) & Driveline 6 12-17-2009 10:35 AM
Blouch TD04 19T Upgrade lackofhp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-31-2008 01:57 PM
TD04-19T questions. ringe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-07-2008 07:19 PM
