11-07-2006, 10:39 PM | #1 |
Member#: 131460
Vehicle:2005 STI SR55'd w/ 44mm ewg! |
2005 STI, going fast=cruise control check engine light?
Yeah, I was at the track not too long ago doing maybe 95 mph and then all the sudden I felt a tug like feeling on the car. Almost felt like an electronic governor. Then, after that I had a check engine light and my cruise control button on my gauge cluster kept flashing. I reset my ECU and it wasn't there. I then purposely took the car up to around that speed and the same thing happened again. Any ideas guys?
Thanks!
11-07-2006, 10:53 PM | #2 |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
What mods have you done to the car?
11-07-2006, 10:56 PM | #3 |
Member#: 14311
Vehicle:2010 GTI White |
This has only happened to me when I got fuel starvation on a road course because I let the fuel level get too low. After a long long right hand sweeper the fuel pump couldn't get any fuel so the car freaked out.
11-07-2006, 11:03 PM | #4 |
Member#: 130897
Vehicle:2006 6 speed WRX 18G 330awhp 355ft/lbs |
Sounds like boost creep causing fuel cut. Do you have a catless downpipe w/ no engine management? If so this is pretty common. The wastegate can't release enough boost (boost creep) and the engine cuts fuel briefly which throws a CEL.
11-07-2006, 11:59 PM | #5 |
Member#: 130546
RMIC
Vehicle:2004 STi ~ Sold :( Silver |
I had the EXACT same problem on my 04 STI...
I could actually duplicate the prblem very easily, just cruise in 4th-6th gear at lowish rpms(60mph in 5th) then stomp the gas... Starts to accelerate, tehn feels like total loss of power, like hitting a wall, then it stuttered a sec, then came back to life with check engine light and cruise light flashing.. IIRC the code it threw was P0244-"Turbo WG Solenoid A Range/Performance" Took it to the dealer, duplicated prblem for them, they replaced the solenoid under warranty, fixed the problem What code were you throwing? |
11-08-2006, 10:43 AM | #6 |
Member#: 131460
I haven't ran the code, I reset the computer afterwards, I could duplicate the problem again. BUT yes, I'm running a catless downpipe with no EM yet. Common?
11-08-2006, 05:21 PM | #7 |
Member#: 130897
Yeah your definately getting boost creep. This happened to me with my catless turbo back exhaust before I got my accessport. Get some engine management (Cobb Accessport is good) and your problem will go away plus your car will go faster.
11-08-2006, 05:54 PM | #8 | |
Member#: 98867
SCIC
Vehicle:2013 WRX Dark Gray |
11-08-2006, 07:04 PM | #9 |
Member#: 125696
Vehicle:04 sti wrb |
same problem here. i hit 110 and my car just jerked and shut off then powered back on once i hit 100. catless downpipe with EM. doesnt sound like the same problem. what is my problem?
11-08-2006, 08:15 PM | #10 |
Member#: 46417
Vehicle:2008 evo X |
boost cut on the factory ecu ftl
11-08-2006, 08:43 PM | #11 |
Member#: 109349
SCIC
Vehicle:2006 Impreza WRX STi OBP stage 2 Harman Tuned! |
I also had the same problem in my catless 06. I got AP and it fixed the fuel cut but not the boost creep, the boost creep is a mechanical problem and should be fixed by porting the IWG (if your catless).
-Mark |
11-09-2006, 02:56 AM | #12 |
Member#: 130897
good point mizzy. getting some EM will stop the fuel cut which is giving you that sudden loss of power and a CEL. I'm not 100% on this, but the accessport should eliminate mechanical boost creep by changing wastegate cycles. If you still notice some boost creep with an accessport then the best way to get rid of it is to port your turbo.
11-09-2006, 08:48 AM | #13 | |
Member#: 131460
OK. Thanks! Well anwser me this question. Honestly, which is better Cobb AP or the TXS UTEC? Seems like I hear great things about both? Is the Cobb EM something you can fine tune yourself? |
11-09-2006, 09:04 AM | #14 |
Member#: 82524
Vehicle:2005 35R'd 4eat Flying Rhombus |
I recently started having a similiar problem with my 05 FXT 4EAT since the arrival of the cold weather... Although i pull the code: po244 "wastegate control solenoid valve malfunction (high input)". I've got a Catless downpipe with a cut-out and no EM yet... So far this has only happened to me on the highway with the cut-out open, so i've been going easy and keeping the cut-out closed till i start tuning my car over the next couple weeks.
11-09-2006, 09:47 AM | #15 |
Member#: 115174
SCIC
Vehicle:04 virgin STi JBP |
for those who have this problem in socal... i can fix this problem for you
PM for info |
11-09-2006, 02:36 PM | #16 |
Member#: 130897
AP and UTEC are some of the top EM systems out there. If you have experience with tuning and you want to tune your own car the UTEC might be a better choice. The AP mainly uses off the shelf maps that are OK or you can get a protune. Cobb recently released its street tuner software which lets you custom tune yourself. I think the price of an AP + Street tuner comes out to around the same price as the UTEC.
01-05-2007, 01:31 PM | #17 |
Member#: 133220
PRSIC
Vehicle:2006 STI Aspen White |
i got the same problem but the car send a error code P0103 Mass air flow sensor circuit high input?
can somebody tell me whats the problem? , i have turbo xs d/p , high flow cat, podrive oval exhaust, and perrin box filter, hyper grounds. Thanks for the help!!! |
Check engine light, VDC light is on, and cruise control light is flashing | grimace09 | Normally Aspirated Powertrain | 7 | 08-09-2012 03:42 PM |
Check engine light, VDC light is on, and cruise control and sport light is flashing | Legacymun2k6 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 01-30-2010 12:47 PM |
Check engin light and cruise control light | BooSTIn_StI | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 04-02-2007 11:18 PM |
HELP! Check Engine light on & Cruise Control Light Blinking | STiURBO | Southern California Impreza Club Forum -- SCIC | 21 | 03-15-2007 01:54 AM |
Check engine light on and cruise control light flashing | mpadovano | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 6 | 01-23-2005 02:04 PM |
