06-23-2009, 04:45 PM | #1 |
Member#: 103320
Vehicle:1998 swapped Forester L |
anyone using the WB02 on the Tuna to simulate a narrowband signal?
Like the title states, I have a UTEC and Tuna that I am preparing to install now that I have some time.
Conveniently, my rear O2 went out. Does the Tuna WB02 have a wire to simulate narrowband output? Car is an 05 STI and is fully tuned on the stock ECU as well, so I must have the rear O2 for fuel trim purposes. Thanks!
06-24-2009, 09:50 AM | #2 |
Member#: 74321
Vehicle:2004 wrx wag black UTEC stg 4 |
I'm not really sure what you are asking. the rear O2 is used basically to check if the cat is working. it's not used for fuel trim at all. the turbo XS tuner uses it's own dedicated "wide band" O2 sensor, and is not used for anything other than AFR's for logging. There is no wire that will do what I think you are trying to do.
06-24-2009, 09:58 AM | #3 | |
Member#: 51684
On the STI, it is.
I have a Zeitronix in my car and I use the narrowband output to signal the rear O2 and it works great. Quote:
06-24-2009, 01:02 PM | #4 | |
Member#: 103320
Many wideband sensors feature a narrowband output so you can install them in place of a rear O2 and have both wideband logging and narrowband output so that the factory O2 logic remains intact. Are you saying that the O2 sensor for the Tuna doesn't have a wire like this? If so I appreciate the feedback. |
06-24-2009, 05:53 PM | #5 |
Member#: 74321
I'm using the tuner pro (it's about 5 yrs old) and I'm positive mine does not have this wire. you might want to give turboxs a call.
anyone using o-rings on the block?? | hectowrx | Built Motor Discussion | 5 | 05-05-2008 09:39 PM |
Gauging the interest on my Tuna! | mixup52 | Rocky Mountains Impreza Club Forum -- RMIC | 10 | 08-12-2004 12:22 AM |
Anyone use Geico insurace on the car(s)? | Whiplash | Tri-State Area Forum | 16 | 01-20-2004 10:01 PM |
Had to use my key on the door lock for the first time | JasonCSU | General Community | 9 | 01-07-2004 11:02 AM |
Anyone using E-Manage on the 1.8? | Blugin | Engine Management & Tuning | 3 | 11-18-2002 09:57 AM |
