11-25-2014, 08:49 AM | #23676 | |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
Pkl, i posted pics last december with mine
11-25-2014, 08:51 AM | #23677 |
Member#: 389497
Like every other time you post this crap, I said taking the snorkel type thing that the car comes with off does nothing. I never went back on that statement. Now would you stop commenting that every time I bring up the WAI?
11-25-2014, 08:57 AM | #23678 | |
Member#: 314216
11-25-2014, 09:00 AM | #23679 | |
Member#: 389497
did you lose your job or something fly? you're being more annoying than usual lately
looks like a homeless person did it, but it works just fine. and yes, it is quite safe from that belt and pulley. |
11-25-2014, 09:01 AM | #23680 |
Member#: 314216
Pkl,
http://forums.nasioc.com/forums/show...php?p=41170030 Has my picture of how i did it. It works great. |
11-25-2014, 11:15 AM | #23681 | |
Member#: 316869
Vehicle:2012 Impreza Sport Dark Gray |
Sent from my D6603 using NASIOC mobile app |
11-25-2014, 11:34 AM | #23682 |
Member#: 89967
NESIC
Vehicle:2020 Volvo S60 Gray |
So this is probably a noob/dumb question, but: When putting on my winter tires today, is it safe enough to jack up one side at a time with my floor jack (not the subie one), remove all season, put on winter tire? Or should I put the jack stand as a safety measure as well for each side? I plan on just doing 1 wheel at a time...
11-25-2014, 11:57 AM | #23683 |
Member#: 361912
E. Canada
Vehicle:2013 Imp GP Touring Satin White Pearl |
SubaruPartsWarehouse is having a Black Friday Sale 25% Off on orders $89 or more.
Use code: BF14 |
11-25-2014, 12:42 PM | #23684 |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
Angelus, that's fine since you're not getting under the car. Just make sure the handbrake is on.
11-25-2014, 01:12 PM | #23685 | |
Member#: 314216
Normally i use jack stands, and i did the day prior, then i realized i had put them on the same corner as last year. Took about 5 min per side with the 2 jacks |
11-25-2014, 02:43 PM | #23686 |
Member#: 89967
NESIC
^Thanks, I'll try to use the jack stands too just to be safe. My floor jack is such a pain in the ass (harbor freight), it doesn't go high enough to easily get the car on the stands to take the wheels off
11-25-2014, 02:50 PM | #23687 | |
Member#: 322264
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
http://www.harborfreight.com/2-ton-a...ump-68051.html |
11-25-2014, 03:06 PM | #23688 | |
Member#: 348055
Vehicle:2013 Impreza 5MT ISM |
Was going to return it, decided not to... THEN finally decided I would but realized I threw out the box already. Damn. |
11-25-2014, 03:16 PM | #23689 |
Member#: 89967
NESIC
I got this one: http://www.harborfreight.com/rapid-p...8053-7814.html
Maximum Lift Height (in.) Yours: 18-1/2 in. Mine: 14-3/4 in. That's it right there :/ |
11-25-2014, 03:19 PM | #23690 | |
Member#: 316869
11-25-2014, 04:21 PM | #23691 | |
Member#: 348055
11-25-2014, 10:04 PM | #23692 | |
Member#: 393302
Vehicle:2014 Impreza Sport |
You can also slide the summer wheel and tire under the frame of car as well, you may have to jack the car up a little higher to do it. |
11-25-2014, 10:47 PM | #23693 |
Member#: 389497
New subaru in the family, '14 XV limited. Nice to have a car with mostly the same build so I can transfer any knowledge pretty much directly.
11-26-2014, 06:43 AM | #23694 | |
Member#: 322264
If, however, I'm doing a job that requires getting all four tires off the ground at the same time (like a tire rotation, or flushing my brake fluid), or if I'm going to get under the car for any reason, then I absolutely use jack stands, and I lift the car higher into the air. |
11-26-2014, 08:35 AM | #23695 |
Member#: 89967
NESIC
Thats what I ended up doing last night, just the floor jack. I did have the stands underneath just in care somehow the jack gave, but overall it was pretty easy and safe. Luckily I have access to a garage now so that made it a lot easier. Bring on the snow today!
Also, I'm probably done on my stockers for next year, and there's a pretty big difference in the tread between the inner and outer portion of the tire. I've rotated them all at 7500 miles, I remember others talking about how bad the stock alignment was (camber etc). Hopefully I can get this corrected when I get new tires next spring. |
11-26-2014, 05:24 PM | #23696 |
Member#: 314216
The arcan jack i just picked up from costco is awesome. It's this one, http://costcocouple.com/arcan-2-5-to...m-hybrid-jack/
And for 100 how can you go wrong? |
11-26-2014, 05:30 PM | #23697 | |
Member#: 322264
11-26-2014, 06:28 PM | #23698 | |
Member#: 216040
NESIC
Vehicle:2013 Impreza 2.0i5dr dark metallic grey |
Sent from my SAMSUNG-SM-N910A using NASIOC mobile app |
11-26-2014, 09:11 PM | #23699 |
Member#: 314216
11-29-2014, 12:30 PM | #23700 |
Member#: 404917
Vehicle:12 Impreza Sport DGM |
Heads up to my fellow roof rack nerds, just got a new range of matte black crossbars in recently for ski season. Some prototype stuff. pix for the interested:
(may have to blow the pictures up, taken w/ my phone) Front bar is a brand called RockyMounts based out of colorado, rear bar is the new(!) Thule aeroblade black bar. front is thule standard square, rear is Yakima standard round (my preferred on obp cars-looks awesome with a wind deflector too) side view of thule black aeroblades. Glare makes the color a little bright, but it really is a pretty deep matte grey. Also gives a good idea of tower height with the thule tower (450r tower in this case) The rails on these cars taper towards the back, which kind of sucks for the thule faithful as this is the smallest bar you can fit on there (believe me, I tried). Next year thule is coming out with a black aeroblade "edge" bar, that looks a lot more like the OEM crossbars. bring the snow |
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 05:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 02:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 07:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 04:09 PM |
