07-12-2012, 08:09 PM | #301 |
Member#: 312613
SCIC
Vehicle:2012 WRX Prem. Stg 2 SWP |
time to bring this thread back.
if i were to add an amp and aftermarket speakers, which harness would i have to buy to work with everything? i would also have to buy the parking bypass and ASWC?
07-12-2012, 09:34 PM | #302 |
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
Amp plugs in directly to HU. Speakers plug into amp. So no difference.
07-17-2012, 04:09 PM | #303 |
Member#: 224097
Vehicle:2012 WRX Hatch - DGM Stage 1 - Tuned by Bren |
^^ no difference in the harness, the amp gets its audio signal from the back of the HU like stated above from the RCA cables. but you will need to run a remote turn on from the harness (blue wire). but any harness you get should have it.
or you can gheto it and bridge the batt cable with a smaller guage wire and kill your battery every 8 hours lol. |
07-17-2012, 10:37 PM | #304 |
Member#: 55447
W. Canada
Vehicle:2002 WRX wgn/'10 STI WRB/grey |
Just did this install based on the OP's instructions. So easy! Thanks!
I haven't had a chance to drive around, but in the confines of my garage it kicks ass. I even called my wife from the car using the built-in Bluetooth. This is easily one of the easiest installs of anything I have ever done. |
07-22-2012, 07:32 PM | #305 |
Member#: 277043
Vehicle:2015 WRX WR Blue |
God dammit I got rid of my iphone and got the new samsung galaxy s3 and its not compatible via usb but only through blue tooth. Horse poop I say, anyone know if theres a way around this?
07-22-2012, 08:28 PM | #306 | |
Member#: 316928
Vehicle:2012 STI limited |
However I am pretty familiar with most things android. Make sure USB debugging is enabled in the phone settings. Also on my skyrocket I have to turn USB storage on manually when the phone detects a USB connection. Make sure you try both of those. Also grats on trading up from the iPhone. |
07-22-2012, 10:49 PM | #307 | |
Member#: 277043
07-22-2012, 10:59 PM | #308 | |
Member#: 297312
Vehicle:2011 WRX Hatch Dark Gray Metallic |
Grats on your new phone. |
07-23-2012, 03:54 AM | #309 |
Member#: 277043
07-23-2012, 07:01 AM | #310 | ||
Member#: 297312
Just some food for thought. Fulfilling your personal preference is the name of the game |
07-23-2012, 11:53 AM | #311 |
Member#: 297312
I know you're leaning towards the USB route, but since this is related to what I posted early this morning I figured I'd link it here for you.
http://www.droid-life.com/2012/07/23...ons-galaxy-s3/ It looks like both CM and AOKP are definitely making their way to your new Galaxy S3. |
07-23-2012, 11:52 PM | #312 | |
Member#: 277043
07-24-2012, 12:00 AM | #313 |
Member#: 277043
I think the worst thing of all of this is that I had bought the special plug for the head unit too,not even opened yet.
08-15-2012, 11:10 AM | #314 |
Member#: 166490
Vehicle:2011 WRX WRB |
This is probably a dumb question guys, but is there any possible way to play phone navigation via Bluetooth from any mode except the Bluetooth Audio mode? I'm guessing no since they probably want you to either upgrade to a Nav unit or spend tons of money on the AVIC-U220 Nav adapter. Just figured I'd ask.
08-15-2012, 11:15 AM | #315 | |
Member#: 304175
Vehicle:2012 WRX Limited PBP |
08-15-2012, 11:57 AM | #316 |
Member#: 166490
08-15-2012, 12:04 PM | #317 |
Member#: 304175
08-15-2012, 01:48 PM | #318 |
Member#: 166490
Yeah that's what I figured. I do have some music on my phone but I'd have to keep changing it out. Maybe I'll actually sign up for Spotify or something. Thanks slowhat. I figured you'd know the answer.
08-15-2012, 01:55 PM | #319 |
Member#: 304175
upload everything to Google Music. I've got all 18000 of my songs following me around in the cloud at all times.
08-15-2012, 02:03 PM | #320 |
Member#: 166490
08-15-2012, 06:41 PM | #321 | ||
Member#: 297312
You can then access your music without it being locally stored (I'm assuming you have an android device?). Also if you you have a phone that is supported by either AOKP or CyanogenMod, they have actually enabled metadata over bluetooth, so when listening to your google music songs all the info gets properly sent to your Pioneer's display |
08-16-2012, 08:55 AM | #322 | |
Member#: 166490
09-12-2012, 02:57 PM | #323 |
Member#: 330096
Thats one clean install. Well done.
09-29-2012, 12:21 PM | #324 |
Member#: 332894
I recently put an AVH-P4400BH in my 2012 Impreza Limited. It was a painless install. Get in touch with David Carter for the correct 20-pin harness and ASWC. The hardest part of the install was fishing the remote mic cable. If anyone wants to know which flash drive to use with the Pioneer, I had to try many. The OCZ Diesel and the PNY Attache (the oldest version your can find) work flawlessly.
10-02-2012, 10:14 PM | #325 |
Member#: 302939
Vehicle:2008 Outback XT VF52'd |
16.2 mpg.. lol
Thanks for the writeup! |
Similar Threads | ||||
Clutch "clicking" in 2012 wrx | STIDAWG | Transmission (AT/MT) & Driveline | 7 | 03-16-2013 11:22 PM |
Where to ground in 2012 wrx hatch? | slowhat | Car Audio, Video & Security | 3 | 02-24-2012 11:35 PM |
pioneer avh-p4000 install in 06sti | nation1979 | Car Audio, Video & Security | 25 | 02-26-2009 01:47 AM |
Pictures of Hid's installed in '02 WRX :) | paultg | New England Impreza Club Forum -- NESIC | 7 | 12-16-2001 04:22 PM |
Found out a short throw shifter wasn't installed in my WRX.. | cout | Bay Area Impreza Club Forum -- BAIC | 5 | 05-03-2001 05:59 PM |
