04-16-2009, 01:01 AM | #351 |
Member#: 171688
Vehicle:2006 Saabaru 9-2x Aero Wagon Midnight Black |
omfg... i should really shut my mouth... i just posted earlier about not having a CEL
well... now i got one!! yay!! PO303 Cylinder 3 Misfire
04-17-2009, 09:55 AM | #352 |
Member#: 205524
Vehicle:2011 STI Asphen White |
would a 06 sti cluster fit in 02 wrx
04-18-2009, 05:15 AM | #353 |
Member#: 149526
NWIC
Vehicle:2002 aps dr65 hybrid 9.1x1 built block/heads |
04-18-2009, 05:18 AM | #354 |
Member#: 87542
SCIC
Vehicle:2002 Bugeye PSM |
04-18-2009, 06:56 PM | #355 |
Member#: 166777
Vehicle:2011 WRX Wagon SWP |
Another succsessful install. Thanks for all the useful info here it really helped.
For an 05 cluster into an 02 wrx: Clip the C9 (buzzer) and B28 (radio fuse wire) -C9 = orange wire with white trace -B28 = yellow wire with green trace Dremmel off the two right hand runners on the left connector so it will fit into the gauge cluster. Turn on the car. East as 1,2,3. One thing this thread didn't mention (at least that I saw and I read a lot of it) was that the connectors on the STi cluster are upside down as compared to the wrx one, or at least that was true for the 05 in my 02. Not a problem, just an oddity. Again, thank you for sharing the knowledge, I hope this post helps someone else who is too lazy to read the entire thread |
04-18-2009, 07:33 PM | #356 |
Member#: 159264
yea i noticed the connectors were upside down for me as well (04 sti into 04 wrx) but i didnt think much of it lol
04-19-2009, 11:36 PM | #357 |
Member#: 183192
South East
Vehicle:2019 STI World Rally Blue |
04 STI Cluster for my 02 WRX
Ok, I can spend DAYS reading all the responses on this thread, so I figured I would see what people have to say.
I am looking to put an STI cluster in my 02 WRX. I have heard from several places that the 04 STI cluster is the best way to go. are the connectors just plug and play or do they need modifying? Also, Ive been told that I will need to cut a wire..b29? Which one is this? Also, anybody with pix?! It would definitely be helpful! Thanx! |
04-19-2009, 11:48 PM | #358 | |
Member#: 87542
SCIC
04-20-2009, 12:20 AM | #359 |
Member#: 171688
theres 3 plugs into the cluster A, B, & C
looking at the cluster while sitting in the drivers seat.. the plugs are A,B,C from left to right so A is left.. B is middle.. and C is the right one as stated above C9 is the orange wire with white stripe on the right plug . B28 is the yellow wire with green stripe on the middle plug '04 STi cluster, you don't need to mod the A connector (female) on the cluster because it's a direct fit. any other year sti cluster '05-'07 you need to modify the 2 grooves in the A plug (female) on the cluster because they're too narrow to fit your OEM WRX male connector also.. if you dont get it by now.. when you say "C9" for example.. C refers to the plug location and the number 9 in this case is the number of the pin in that connector on the cluster. when you pull the cluster out i believe it has numbers listed on it. i forget |
04-20-2009, 02:40 PM | #360 |
Member#: 153318
South East
Vehicle:08 EVO X GSR |
Does anyone know what page the wire diagram for the STI cluster is on? I'll be searching this thread for days looking for it. I'm looking for the 04 STI cluster diagram actually.
04-21-2009, 04:51 PM | #361 |
Member#: 164022
NWIC
Vehicle:2002 Stage 2 wag. PSM |
If anybody wants to know how to change kph to mph on their v7 STi cluster with the resistor mod, I posted a How to in the electrical forum, I don't want to cross post the link but just a heads up!
Its very easy if you know how to solder! |
04-24-2009, 07:14 AM | #362 |
Member#: 79653
SCIC
Vehicle:2005 LGT Silver |
Finally recieved my OAT sensor and followed CoolRex's instructions on how to install the OAT sensor to the gauge and it worked for me. I have the 04 sti gauge cluster.. I taped up rear diff temp and dccd so it won't illuminate.
You need to have the balls to splice, solder and mess with the wiring harness to install the OAT sensor. Be very careful and look @ the schematics and read instructions very carefully. I'm also getting a sticker from the dealership to state that I have my gauge cluster replaced and with it is the mileage. Its only a $1 from the dealership. Last edited by scooby_wooby; 04-24-2009 at 06:25 PM. |
04-25-2009, 03:52 PM | #363 |
Member#: 166777
Hi I just swapped an 05 STi cluster into my bigeye and the temp readout is being odd. I knew it was not going to work, but the number is not stating at 43 as expected. It actually seems to be changing according to the outside temp. On cold mornings it reads 30-40 degrees and today, being by far the hottest day since the install, it's 47. No big deal, just wondering if anyone else has seen this or knows what's up.
04-28-2009, 11:06 PM | #364 |
Member#: 180535
Vehicle:2004 wrx JBP |
hey guys i am putting a 05 cluster into my 04 wrx. i know i have to "trim" the C one. but i was wondering what ways to trim it? what have you guys done to trim it? i also was curious i was looking at the C female side and it doesnt look as wide as the side attached to the cluster. is that normal?
04-28-2009, 11:17 PM | #365 |
Member#: 171688
^ trim the A side not the C side
as i explained earlier... the A side is the left most plug . basically the STi cluster has 2 more pins than the WRX cluster so the male portion doesnt fit onto those 2 pins.. but the 2 grooves on the STi cluster are meant to fit the STi male connector. So to compensate.. you have to extend those 2 grooves in the STi cluster to avoid connecting the extra 2 pins and so that the WRX male connector fits into the STi female plug. it sounds more complicated than it is.. ill have to see if i still have the pics for reference and to extend the groove.. i just went at it with a soldering iron.. just be VERY CAREFUL.. bc it melts the plastic really fast. |
04-28-2009, 11:20 PM | #366 |
Member#: 183813
South East
Vehicle:2006 WRX TR OBP WRX STi SGM |
Can't the dealership reflash the mileage provided you bring them the old one too?
04-28-2009, 11:30 PM | #367 |
Member#: 171688
if they did.. i bet it wouldn't be cheaper than Tacoma Speedometer for $80+ shipping
04-29-2009, 12:28 AM | #368 | |
Member#: 180535
04-29-2009, 12:32 AM | #369 |
Member#: 171688
u have to like extend them so that the male wrx clip slides into them.. they're too far to the left .. i didnt get it at first.. but when u take out the WRX cluster and compare it to the STi cluster.. you'll see what im talking about
pic i found from when i modded it. dont mind the shabby job. it worked and thats all that matters =p |
04-29-2009, 03:52 PM | #370 |
Member#: 187052
Vehicle:2006 Wrxtr 6-spd DOM3backoff i'mascientist |
anyone figure out how to get the temperature to work if you have a 06wrxtr and putting in a 06sti cluster?
04-29-2009, 05:38 PM | #371 |
Member#: 193267
04 sti cluster in 03 wrx
hey guys and gals, have a 04 sti cluster going in an 03 wrx,what wires do i need to cut and move around?and what will and wont work on the 04 cluster?last of all is there any way to get the air temp to work?
04-30-2009, 04:17 PM | #372 |
Member#: 180535
alright i got my 2005 sti cluster in my 04 wrx and got the loud continous beeping/buzzing sound. i know you have to clip wire c9 for that, but in a couple posts people have said they clipped it and grounded it and others just say clip c9. my question is do you have to ground it or is clipping it good enough?
04-30-2009, 04:23 PM | #373 |
Member#: 171688
clipping worked for me
04-30-2009, 04:40 PM | #374 |
Member#: 180535
alright man thanks
04-30-2009, 04:53 PM | #375 | |
Member#: 166777
I trimmed the runners off of the WRX connector and it slid right in. The little clip in the center holds it firm, so it has no issue holding its position. I used a dremmel to trim them up. Melting out the runners on the cluster seems a bit sketchier to me... |
can we get some mods to start deleting duplicate threads? | [27] | Political Playground - Chaotic Neutral Edition | 2 | 11-05-2008 02:01 AM |
STi hare emblem? where can i get one... | evoeater8 | Interior & Exterior Modification | 13 | 07-12-2006 08:53 PM |
can we get something started in RDU???(nc) | imprezivSTi04 | Mid Atlantic Impreza Club -- MAIC | 3 | 04-04-2006 06:47 PM |
02 sti hood scoop?? where can i get one? | slaterdrew | Private 'Wanted' Classifieds | 2 | 02-06-2004 11:37 AM |
lighted keyhole ring, can we get one? | makanouchi | Interior & Exterior Modification | 12 | 11-22-2002 08:38 PM |
