09-13-2002, 01:54 AM | #1 |
Member#: 21911
Vehicle:2002 wrx rally blue |
how eliminat the check engine light due to a high flow exhaust or a catless exhaust
i just wanna how to eliminat the check engine light due to a high flow exhaust or a catless exhaust??
And is it high flow cat exhaust will make the check engine light on?? which one is better, high flow or catless?? check this out!! http://cgi.ebay.com/ebaymotors/ws/eB...tem=1857487198 is it going to work or hurt?? thank you
09-13-2002, 03:28 AM | #2 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
had you posted in the local forum, or even FFI for that matter someone would have told you there is a place that sells them around here....it's called an MIL elimniator.
jeremy |
Wastegate check engine light due to downpipe | k3rryb3rry | Newbies & FAQs | 21 | 06-18-2009 02:27 PM |
Is there a permanent way to turn off the check engine light? | JeffyLube | General Community | 7 | 02-17-2009 05:14 AM |
The oil light came on, then the check engine light, then it stopped... | rogue | Off-Topic | 36 | 10-13-2004 02:29 PM |
does the check engine light come on when u need to go in for maintenance? | garie | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 03-11-2004 07:14 AM |
replaced the T and the hose and the restrictor now the check engine light comes on | scoobydoo02 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 05-04-2002 10:21 PM |
