07-21-2002, 11:19 AM | #1 |
Member#: 21710
Vehicle:1999 Impreza wagon black |
When to change the timing belt?
I have a 1999 Impreza wagon with 63,000 miles. I just had the 60k service a month ago and was told by four different dealers that the timing belt needed to be changed at 60k. After the service the dealer who did the work said it was 105k when it needed to be changed.
My question is a.) Has anyone else experienced this ambiguity? and b.) which is it; 60 or 105.? Any recommendations? Thanks! Songlady
07-21-2002, 03:28 PM | #2 |
Member#: 437
NESIC
If you have your owners manual it should tell you on there. If you don't have that, I think you can go to www.mysubaru.com ,put in your VIN number, etc.. and get your home page going. I think they have an on-line owners manual that would give you service intervals for this type of stuff. I know the '99 2.5RS was 100K, but I am not sure about the 2.2L.
Paul G. |
07-21-2002, 06:47 PM | #3 |
Member#: 4083
NESIC
Vehicle:2018 OB 3.6R Limited magentite gray |
2.2 - 60k. Make sure you get the right belt (california vs federal)
Roger |
07-22-2002, 05:03 AM | #4 |
Member#: 4021
NESIC
Vehicle:1999 Legacy GT Ltd Quick Silver Metallic |
The factory recomended change interval for the 2.5 liter EJ25 engine is 60K. Off the record most dealerships will tell you that you are fine changing the belt at 90K. Personally, I would stick with the factory recomendation.
07-22-2002, 06:40 AM | #5 |
Member#: 4083
NESIC
2.2 had solid lifters at the end of their production run. Adjustment is at 105k miles.
changing the timing belt, change bearings or whole idler wheels/pulleys? | NicEJ25 | Service & Maintenance | 15 | 12-28-2010 06:46 PM |
Do you have to remove the timing belt to change water pump? | elsuicida | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 02-27-2009 03:24 AM |
When to change the timing belt? | jsbush | Legacy Forum | 3 | 08-08-2007 03:48 PM |
Time to change my Timing Belt | kastkc | Normally Aspirated Powertrain | 27 | 07-11-2006 02:49 PM |
What is a good mileage to change the Timing belt? | 4-Wheel Drift | Service & Maintenance | 23 | 08-13-2005 12:25 AM |
