11-05-2014, 12:17 PM | #3426 |
Member#: 219100
Vehicle:2014 STI hatchback Satin White Pearl |
Shot I took yesterday...
Prosport Premium Series Boost Gauge w/ White Needle:
11-11-2014, 01:37 AM | #3427 |
Member#: 31952
Vehicle:2013 Murtaya R, S Model S Plaid |
My setup:
11-11-2014, 01:41 AM | #3428 |
Member#: 31952
Startup/shutdown sequences:
http://m.youtube.com/watch?feature=y...&v=DlIPhJh-R4s Last edited by Hiryu; 11-11-2014 at 01:53 AM. |
11-11-2014, 09:07 AM | #3429 |
Member#: 103108
Vehicle:2013 WRX Sedan |
11-11-2014, 08:43 PM | #3430 |
Member#: 31952
It's called a Murtaya. It's like an STi sports car. Same AWD, 6-speed, and turbo 2.5L as an STi, but just in a lightweight, roadster body.
11-15-2014, 01:58 AM | #3431 |
Member#: 244010
Vehicle:2006 WRX Wagon WRB |
11-20-2014, 02:04 PM | #3432 |
Member#: 405331
Vehicle:2002 WRX Aspen White |
Looks good, I just got my prosport's in the mail
11-21-2014, 09:33 AM | #3433 |
Member#: 284699
Vehicle:2013 Impreza WRX STi |
I'm having gauges done on the 1st. SMY cluster, Defi boost & oil, Innovate AFR. One of the gauges will be mounted using the Solid Vent mount.
Any thoughts on it before I do it? The vent is still functional but I'm worried about blasting the heat/cold air. Also, what would you guys recommend go in the cluster (two gauges) and which one in the vent? Im thinking AFR in the vent and the other two in the cluster. thankss |
03-21-2015, 10:00 PM | #3434 |
Member#: 32459
Vehicle:02 WRX VF34 (SOLD) Junior Tuned 301whp |
Which one do you think looks the best in 02 WRX? I personally like green, but I think 25 lumen might be too bright.
Warm white vs. Green vs. Cool white LED's. All 25 lumen. Purchased from here: https://www.superbrightleds.com/more...edge-base/228/ |
03-22-2015, 05:37 PM | #3435 |
Member#: 415039
E. Canada
Vehicle:2002 WRX World Rally Blue |
Since I got my AP I really don't pay attention to my boost gauge anymore thinking of taking it out soon. |
03-23-2015, 09:38 PM | #3436 |
Member#: 32459
12-01-2015, 04:31 AM | #3437 |
Member#: 434621
International
Vehicle:2006 S204 Victory Yellow |
Here's mine ..... HKS Gauges all round
12-01-2015, 09:07 AM | #3438 |
Member#: 168943
Vehicle:2004 STi Aspen White |
Got these installed a couple months ago: Auto Meter pod with digital boost and oil pressure. I'm very happy with the results, low key and OEM looking.
-Adam |
12-01-2015, 09:22 AM | #3439 |
Member#: 167544
NESIC
Vehicle:'12 DGM STi sedan '14 Audi S6, '16 XC90 |
12-17-2015, 01:52 PM | #3440 |
Member#: 251046
Vehicle:2004 WRX Wagon Stage 5.1.2a.2 |
I built this display using the Zeitronix ZT2 w/ LCD display. I de-cased the display and purchased the OEM clock pod hood and din. It's currently displaying Oil Pressure, EGT, Boost, & AFR.
12-17-2015, 02:16 PM | #3441 |
Member#: 319539
South East
Vehicle:2002 WRX,EJ20,VF30'd PSM,5MT DCCD,RPF1 18's |
Innovative programmable xd1 gauges and lma-3 with lc1 for a/f. With full data logging capabilities. |
12-17-2015, 04:51 PM | #3442 |
Member#: 183923
E. Canada
Vehicle:'08 EJ257 |
01-24-2016, 06:57 PM | #3443 |
Member#: 67004
SCIC
Vehicle:02 vf30 pnp wagon silver and cf |
Got a new pod modified and ready to install.
01-24-2016, 07:01 PM | #3444 |
Member#: 319539
South East
Looks good!
02-04-2016, 07:07 PM | #3445 |
Member#: 235475
PRSIC
Vehicle:2008 WRX Silver |
'08 Wrx
Before...
And after... |
05-20-2016, 09:45 AM | #3446 |
Member#: 441456
Blobeye WRX
Custom made maxigauges display mounted in the dash clock case. Displays boost(manifold relative pressure read from stock map sensor), afr(read from aem uego which is hidden behind glove box, sensor in downpipe), egt (maxigauges egt sensor mounted in stock uppipe egt bung with a custom made adapter) oil pressure (maxigauges oilp sensor mounted in rear galley plug) fuel pressure (maxigauges fp sensor mounted in boot before fuel inlet hard pipe) Eth content (maxigauges eth% sensor mounted in boot fuel return line) Records and displays peak boost, min-max fp, min-max oilp, max egt. Time and date. Lean alarm. Overboost alarm. Max egt alarm. Low oilp alarm. These are custom made gauges on order and there are lots of other options, lcds etc... I only have a short vid at the time. Enjoy https://youtu.be/wvJczKXvk7g Genco |
02-12-2017, 02:58 PM | #3447 |
Member#: 301179
BAIC
Vehicle:2013 WRX Limited SWP |
For those with a GR, where have you guys mounted a 60mm gauge?
I've mounted mine where the SPT factory gauge would go, but I'm planning to get a wideband and oil pressure gauge next, both of which will be 60mm and there aren't that many options for us to mount these gauges... Unless I get something too show-off-y, like the apillar, clock mount, and the passenger mount.. Here's mine so far... Defi BF Boost gauge. |
08-10-2019, 01:29 PM | #3448 |
Member#: 488200
Vehicle:2006 WRX TR World Rally Blue |
Picture of Gauge Install
Just felt like sharing. The setup is a Link G4 Knock Light (it's not a shift light, I swear!), AEM Boost and AFR gauges, with the AFR gauge reading off of a wideband positioned about 8-10 inches from the bell mouth of the down pipe (just above the transmission, pointed towards the bell housing), and an Innovate two-in-one (MTX-D) oil temperature and pressure gauge. The two gauges installed in the instrument cluster are installed in a SMY ClusterMaker Dual Gauge Pod (I bought it through RallySport Direct, no affiliation - https://www.rallysportdirect.com/par...xoCdToQAvD_BwE).
The only other gauge I'd like to add at some point is an EGT gauge. Will probably mount on the pillar above the oil temp/pressure gauge. |
08-12-2019, 01:43 AM | #3449 |
Member#: 461423
NICE Settup
04-04-2020, 06:08 AM | #3450 |
Member#: 456759
Zero sports cluster Defi STI genome boost gauge Defi oil pres. fuel pres. oil temp |
Post Pics Of Your Navigation Setup ( Eclipse , N1 ,N2 .... ) | minx1225 | Interior & Exterior Modification | 1 | 09-06-2005 01:43 AM |
Post pics of your FMIC setup | KitchenerWRX | Member's Car Gallery | 2 | 08-30-2005 01:27 PM |
Post pics of your gauges lit up... | MomoWRX | Electrical & Lighting | 22 | 12-11-2004 10:21 PM |
post pics of your gauge clusters/bezels 03wrx | 03twrx | South East Region Forum | 5 | 11-13-2004 09:28 PM |
Post Pics of your gauges and cluster shots! | Leo | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 21 | 02-19-2004 10:16 AM |
