07-26-2000, 06:14 PM | #1 |
Member#: 1919
Vehicle:1994 Legacy Turbo Silver |
Canister Purge Control Solenoid
For the record, I've found the location of this device on the Legacy 2.2l Turbo engine (it's probably in the same place on the non-turbo). It's attached to the UNDERSIDE of the #1 cylinder intake manifold runner. If you look down between runners #1 and #3, you can see it. The bolt that attaches it to the runner is UNDERNEATH the solenoid. I was able to get a 12mm box wrench on the bolt and give it a turn, but that's as far as I went for now. I just wanted to see if I could find the solenoid and determine if it is possible to remove without removing the entire intake manifold! It looks like it is, so tomorrow I'm going to buy a new solenoid and install it this weekend. If I'm successful, I'll post instructions. If I'm not successful...
Nigel '73 Datsun 240Z '94 Legacy Turbo |
07-26-2000, 07:02 PM | #2 |
Member#: 132
Tri-State
Vehicle:GDA- D, GDA-A, VAG-A GDA-A - ShinjiTuned |
Told you it was a bitch
Similar Threads | ||||
WTB: Purge Control Solenoid | Computergeek24 | SCIC Private Classifieds | 2 | 02-05-2008 09:30 PM |
WTB: Purge Control Solenoid | Computergeek24 | Private 'Wanted' Classifieds | 4 | 02-05-2008 07:01 PM |
Purge Control Solenoid Valve?? | abosworth | Normally Aspirated Powertrain | 3 | 07-21-2005 04:20 PM |
Code 35 purge control solenoid valve troubles | theascen | Service & Maintenance | 2 | 04-02-2004 04:36 AM |
What does the purge control solenoid do? | MadMax | Normally Aspirated with bolt-on Forced Induction Powertrain | 7 | 09-27-2001 09:26 PM |
