08-28-2007, 01:18 PM | #1 |
Member#: 9401
Vehicle:. Truth is a pathless land... |
02 WRX Radiator issue...have a couple of ???
Car = 2002 WRX / Sedan
So apparently my radiator is leaking...a lot. The garage I was at said that when he called Subaru to quote the parts, the guy at the Subaru shop said the 02's WRX's had a TSB on the radiators and to install a new radiator you need to purchase a new set of hoses and some other parts as well as the new radiator. My questions are, is their a TSB on the 02 WRX's ? Where can I get a copy of it. Also, will a stock 2003 or 2004 radiator fit in my WRX ? Lastly, besides the OEM part, is their another alternative that is close to the same price range ? EDIT : One other question. If I buy a Koyo Radiator, will it also need to be re-routed in accordance with the TSB, or can the same old stock hoses be used in it's place ? Also, is this something that can be done on your own without a lift, or do you need a 'garage' to replace the radiator ? TIA - JZ Last edited by ZMANNH25rs; 08-28-2007 at 01:43 PM. |
08-28-2007, 03:27 PM | #2 |
Member#: 28632
Vehicle:2011 Legacy 3.6R Dark grey metallic |
Everything can be done from the top. There is a difference between an 02 and an 03. However the mounting is the same. If changing to an aluminum be prepared for some minor (?) mods.
08-28-2007, 03:42 PM | #3 |
Member#: 85140
Vehicle:2005 Legacy GT wagon topazzzzz |
I went through the same ordeal a couple years ago. My 02 radiator basically busted at the stamped seams. I replaced the unit with the Koyo one, as it's about the same price as the dealer quoted factory piece, but way better. You can use the same stock hoses, however it is a tighter fit with the larger Koyo core. Make sure the upper radiator hose is not hitting the belts. I have two complaints with the Koyo. 1) The drain plug on the bottom is a plastic screw 2) You have to remove the subframe to gain access to the screw if you want to drain your coolant. Hope this helps.
08-28-2007, 10:03 PM | #4 | |
Member#: 85035
Vehicle:2017 Forester XT KTM 690 Duke |
I had no problem reaching the drainplug on the radiator from the top, in fact it was even easier than w/ oem rad (just remove airintake). Oh, I left out the right side fan, figured with extra volume I dont need it. Most drainplugs on oem rads ARE plastic. |
08-28-2007, 03:42 PM | #5 |
Member#: 46407
South East
Vehicle:2002 WRX blew |
I had the same problem. Mine left me stranded on the side of the road though. Instead of buying a used radiator or another one from Subaru (which is too much $$$) I bought a koyo off of ebay, got some samco hoses, a crucial racing thermostat and cap, and called it a day.
08-28-2007, 03:50 PM | #6 | |
Member#: 25187
Vehicle:2020 Forester 2010 Challenger R/T |
.....in a nutshell, the radiators on '02's and early '03's didn't have a radiator cap on the radiator itself (only on the resevoir). The newer units have caps on them but will require a metal tube and two overflow hoses when replacing the old set up. I believe this is the TSB you were looking for (courtesy of ScoobyMods & DrD):
08-28-2007, 05:02 PM | #7 | |||
Member#: 9401
My questions with this, is the new Koyo radiators for the 02's have these changes made to it, to accomodate the change in where the radiator cap is ? Or does the newer Koyo models not need this change because they are not prone to leaking ? This part is confusing... |
08-29-2007, 01:33 PM | #8 | |
Member#: 6030
Vehicle:04 Gold FXT 07 WRB FXT Sport |
good luck dm ps. my stock radiator cracked in similar locations to others... here's a pic |
08-29-2007, 01:44 PM | #9 |
Member#: 46407
South East
Yeh, Koyo makes both designs '02 and '03. I went with the '02 design as well.
08-29-2007, 03:41 PM | #10 |
Member#: 9401
thanks guys...now I need to find a place that sells stock hoses. Any ideas ? Either that or I guess I could buy some Samco hoses if I had to...
08-29-2007, 05:02 PM | #11 | |
Member#: 6030
dm |
08-29-2007, 04:06 PM | #12 |
Member#: 157862
samco should work
08-30-2007, 01:35 AM | #13 |
Member#: 71184
HIIC
Vehicle:2002 ewg'd vf-34'd GDA AMS Tuned ! |
^^ i 2nd the motion on trimming of the samco hoses w/ the install of a koyo radiator.i trimmed the top hose on just end that bolts into the block,the hose is a little cockeyed but no clearance problems.maybe a slight trim of both ends will yield a better result than just trimming only one end.
oh btw my stocker popped in the same area as everyone stocker! |
08-30-2007, 08:37 PM | #14 |
Member#: 46407
South East
I didn't have to trim the top or bottom samco hose, although I probably should have trimmed the bottom one. It was tight, but I made it fit.
10-10-2007, 11:57 PM | #15 |
Member#: 138915
SWIC
Vehicle:2003 WRB WRX Vf48 Tuned @ FAT by Snail Perf |
Just came accross this thread because my radiator recently cracked as well on the upper tank like the pic above. Does anyone know of where I can get a print out of the TSB? And are the newer radiator models any better? Any feedback is appreciated, I don't want to go through another cracked radiator, if so I'll buy a Koyo later on.
10-11-2007, 12:48 AM | #16 |
Member#: 32493
South East
Vehicle:2002 Impreza WRX rock chipped blue |
i replaced my leaking 02's radiator with a speedmonkee/ron davis. installed a crucial t-stat at the same time. used new factory hoses with new clamps.
Similar Threads | ||||
stock L radiator or 02 wrx radiator for ej20k swap? | 2slofouru | Subaru Conversions | 1 | 04-16-2009 09:54 AM |
im new here just got a wrx and have a couple of ???'s | WrXtaCy2003 | Newbies & FAQs | 20 | 04-26-2005 06:06 AM |
Broke 1st gear have a couple of quick questions | fastlane | Transmission (AT/MT) & Driveline | 13 | 05-08-2003 01:32 AM |
('93-'01) I just bought a 01 RS and I have a couple of questions | MulletSlayer | Impreza Forum | 6 | 04-21-2003 04:14 PM |
I'll have a couple of these at the meet... | kid22 | Texas Impreza Club Forum -- TXIC | 26 | 03-14-2002 10:48 PM |
