11-02-2011, 01:38 PM | #1 |
Member#: 289798
Vehicle:94 Ranger Truck world rusty blue |
a puff of white smoke on start up
I have a 05 sti with a 2010 shortblock with about 10k miles on it. It has Wiseco pistons and a GT52 setup.
I just changed the oil from AMS 5-40 to royal purple 5-30 and only sometimes after I drive it around for a while and shut it off, I go back to warm up my car it shoots out a white cloud of smoke from the exhuast. It smells like burnt oil. I did put 4.5 quarts in but thought nothing of it. I checked the oil level and its still a tad high and still purple. Car was on the west coast and now in the Midwest. are my rings going? My turbo shot? Am I just being stupid and over worrying? Or is something really messed up. Plus I am going to tune real soon but need to know if its okay to drive 3 hours to tune the car. It has been tune before but I just want it done due to elevation change(about 1200ft difference from where it came from and here) Thank you for your guys support!
11-02-2011, 05:01 PM | #2 |
Member#: 228784
Vehicle:2004 wrx black, stage 2+ |
my car will puff a little white smoke after sitting for a bit and i get into the gas alittle right after i start it. I figure its just bow-by burning away.
11-02-2011, 08:33 PM | #3 |
Member#: 136396
Vehicle:2020 STI, 2022 WRX |
You may want to do a compression and leakdown test to rule out any issues with the rings.. I just got done talking to a friend who had the same issue and took it to the dealer to find out the ringland on #4 was dead and had a cracked piston, But his was also consuming oil and you said yours is not. Never hurts to check though. Good luck
Chris |
06-28-2012, 06:49 AM | #4 |
Member#: 324540
these are also aftermarket pistons not known for ringlands failing, Ive heard of and seen a lot of scoobs that puff some smoke on start up. Oil level is pretty important, DO NOT RUN IT OVER FULL, not even just a little.
06-28-2012, 07:14 AM | #5 |
Member#: 298231
Vehicle:2011 WRX WRB |
do a compression and cylinder leak down test... if those end up being normal then start to look else where.
and +1 on the oil fill of the oil. have heard alot about that recently. so that would be something i would check after you do the 2 test i mentioned above. always better to be safe then sorry. |
02-15-2014, 02:53 AM | #6 |
Member#: 333497
that's what mine does on cold start... normal? or should I start looking for a new turbo? 2009 STI with cosworth pistons / 17 psi on stock turbo / decat... |
02-15-2014, 03:17 AM | #7 |
Member#: 368905
Nvm I. Not a professional. Seems to probabily be okay tho...
02-15-2014, 03:29 AM | #8 |
Member#: 287109
SCIC
Vehicle:2008 STI SSM |
positive it smells like burnt oil?
(I doubt this is it) but my sister's protege puffs white smoke once when it starts and it is the sweet smell of coolant. your engine seems too new for that but at least something to sniff and rule out... |
02-22-2014, 08:59 AM | #9 |
Member#: 333497
04-15-2015, 01:47 PM | #10 |
Member#: 333497
...welcome Kinugawa
Small amount of white smoke on start up | TA_GunSurgeon | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 06-07-2010 02:34 PM |
Small amount of white smoke on start up | TA_GunSurgeon | Mid Atlantic Impreza Club -- MAIC | 11 | 06-06-2010 07:14 PM |
What's with the white smoke on start up? | tayres | North West Impreza Club Forum -- NWIC | 3 | 03-11-2007 06:02 AM |
Puffs of white smoke on startup | David03WRX | Service & Maintenance | 4 | 04-25-2003 03:11 AM |
Puffs of white smoke on startup | David03WRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 04-20-2003 01:46 PM |
