04-25-2003, 02:46 PM | #1 |
Member#: 4811
Vehicle:2014 Focus ST NESIC track Ho #35 |
ECU needs to be re-programmed- a few questions about my CEL codes
ok, so I go to the dealership to have them clear a cel, inspection sticker, and re-simo the car (because of the accident- got to love warranties)
so it's in for about 40 min, they call me out- first got the inspection sticker no problem- with the straight pipe but here comes the fun, they say they called subaru and they have to re-prgram my ecu, or send it to be programmed. I'm throwing cel codes: P0340 Cam position sensor- no biggie I don't think po447- evaporation vent control circuit po1443- vent control solenoid vavle what the hell are those supposed to mean??! that and the second question- can they attribute these to the boost monkey? as some of us know, it's attached to both the boost solenoid AND the ecu. anyone? speed safely Brian
04-25-2003, 02:52 PM | #2 |
Member#: 8808
Vehicle:2011 WRX DGM 5D |
None of those would be caused by a monkey...
At least, the evap codes are unrelated to the monkey, and there are other evap codes that trigger a lot on older ECUs... particularly as the gas tank gets low. Not entirely sure about the cam position one. /Andrew |
04-25-2003, 03:06 PM | #3 |
Member#: 442
Vehicle:17 Imp Spurt 00 S2k |
Yup sounds right. I was one of the 1st in New England to have mine done. (Same codes).
--kC |
04-25-2003, 03:08 PM | #4 |
Member#: 23676
Vehicle:. |
evap codes are very often the result of filling your car up(gas) while the ignition is "on" running or just in the on position.
I cleared about 700,000,000,000,000,000,000 of them when I was a dealership tech |
04-25-2003, 03:50 PM | #5 |
Member#: 4811
ok, as long as it's "not too bad"- thanks KC
they say it'll take a couple of days probably, whatever, I don't run the car everyday anway ray said he's had his cam shaft sensor replaced because of the code- I've gotten it a couple of times now dave- nope- always off hell I even tighten the crap out of the gas cap andrew- that's what I thought. do you think I'll have to pull the monkey off so they can re-program? I can't remember if it's connected at a connection or not, I think so, so all they would have to do is pull off the connecter and there ya go, I think, oh hell I'm so confused speed safely Brian Last edited by Slvrblt; 04-25-2003 at 04:03 PM. |
04-25-2003, 04:04 PM | #6 |
Member#: 8221
Vehicle:2018 Tesla Model 3 Midnight Silver Metallic |
I got the same codes a long way back (except the cam position one). Just cleared them and they haven't returned.. although I now have a different ecu with ecutek reflash
04-26-2003, 03:12 AM | #7 |
Member#: 4811
eventually I'll probably have a utec,. but until then......
should be under my powertrain warranty right? speed safely Brian |
Similar Threads | ||||
question about certain CEL code | 3g-izzle | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 22 | 05-24-2010 01:18 PM |
Is the ECU required to be re-tuned if i only transplant gear box? | skyline31 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 58 | 05-08-2009 09:46 PM |
quick question about catless cel code | chibich | AccessPort | 1 | 08-10-2006 12:34 PM |
A few questions about my BE... | polski | Legacy Forum | 12 | 01-17-2004 08:43 AM |
Few questions About My front Lip and a Carbon fiber hood w/my TXS front mount??????? | BLUETURBOWRX | Interior & Exterior Modification | 0 | 06-02-2003 10:53 PM |
