07-08-2008, 03:08 AM | #1 |
Member#: 172069
Brian crower 2.71 stroker kit ??
Hey Guys
im from australia and looking for some opinions from you guys that have used this kit and have pushed big hp with it. im looking to push 500-550kw atw with this kit, will the pro rods be able to cope. as there my main concern, any advice and feedback would be great...
07-08-2008, 10:35 AM | #2 |
Member#: 11211
Vehicle:2004 STi Rally Blue |
1 KW is approx. 1.34 HP. So 670HP to 737HP. not bad expectations.
07-12-2008, 04:19 AM | #3 |
Member#: 172069
anyone have any feedback on this kit, im looking at buying very soon as my 2.5 has been sold...
07-12-2008, 02:57 PM | #4 |
Member#: 120641
Vehicle:05 HTA3586,BB 2.5L CGM |
I have one and its a great setup, just rather expensive to get fully going. The main reason is that not only is it a stroker setup but also a big bore. This requires the darton big sleeves for the 102mm bore. This alone adds about $1600 to the setup on top of the actual stroker kit.
07-12-2008, 03:04 PM | #5 |
Member#: 117980
Vehicle:2005 sti wr blue |
why not go with and axxis 2.65l stroker
07-12-2008, 04:50 PM | #6 |
Member#: 172069
why? reasons ?
07-12-2008, 05:04 PM | #7 | |
Member#: 172069
07-12-2008, 10:06 PM | #8 |
Member#: 168633
i think the problem with stroker kits this big is the piston speed. to me it seems that you are bound to break, i remember seeing titainium rods, cobb i believe,
07-13-2008, 12:55 AM | #9 | |
Member#: 120641
Stroker having piston speed issues? No, in fact they are actually slower. However the main debate is rod ratio not speed. Not to mention the amount of stroke increased is small compared to other applications (79mm - 83mm = 4mm = .157" roughly 5/32") A small block chev is 3.480" stroke vs a 383 is 3.750" = .270" a little over 1/4" big difference.... Last edited by Sinister redlines; 07-13-2008 at 01:21 AM. |
07-13-2008, 06:02 PM | #10 |
Member#: 17256
South East
Vehicle:18 Outback on the road.... |
Long rod kits would really help our subie boxers. Anybody make a long-rod kit? The short search I did came up wanting....
07-14-2008, 01:09 AM | #11 |
Member#: 120641
not in a stroker setup due to the assembly process on subies making the rods hang from the crank then after the case is together you install the piston and wrist pin. This makes the fact that the oil ring cannot cover the wristpin and theres no more room to push the pin higher on the skirt.
07-14-2008, 10:09 AM | #12 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
07-14-2008, 10:15 AM | #13 | |
Member#: 33782
My long rod setup is 1.8:1 and the 2.71 stroker is 1.57:1 You can also assemble the block quite easily with a long rod setup. There is also room to push the ring package up without much sacrifice to the ring lands... I KNOW this for a fact. I spent a few years designing and modeling my package. Last edited by Homemade WRX; 07-14-2008 at 11:52 AM. |
07-14-2008, 10:43 AM | #14 | |
Member#: 117780
South East
Vehicle:2004 WRX Aspen White |
07-14-2008, 07:25 PM | #15 | |
Member#: 120641
Yes you are correct the forces do climb with rpm, and yes sb can rev to 8500 with lots of work. What you failed to see what I was saying is that the BC stroker doesnt gain all of its displacement from stroke but rather bore/stroke combination. My relation was just to show that there wasnt a huge change in stroke and that was all. So on.... |
07-14-2008, 07:32 PM | #16 | |
Member#: 120641
Maybe I showed what I was getting at incorrectly, but I was totally agreeing with the stroker not having the best rod ratio. And yes the blocks can be assembled the other way as I have had to disassemble one this way also. Its just not as easy with setting the rod bolts otherwise it is a other method and yes theres nothing wrong with the wrist pin in the ring lands (I have had different platforms like this in the past). I have watched your build and you are playing with some neat ideas, but you are not the only one. I too have 12 years playing with built engines (that I have built not bought) so theres no reason to get defensive or agressive. I realize just about anything can be done but I was more getting at the norm as far as assembly and not the exotic. My next big build is going to be a short stroke, long rod, huge bore oddity. Last edited by Sinister redlines; 07-14-2008 at 07:39 PM. |
07-14-2008, 07:33 PM | #17 | |
Member#: 145145
Vehicle:2006 wrx STi |
In the end we are interested in forces applied to the various components in the system. A BC 2.71L stroker kit will yield higher forces than a standad 2.5L engine at any given RPM due primarily to three factors.
1. Extended stroke. A longer stroke means that the average piston speeds (and by definition average loading) will go up at any given RPM. 2. the extra stroke alters your rod stroke ratio, increasing the rate of acceleration the rod/piston see. 3. the 2.71L displacement is arrived at via an 83mm stroke and 102mm bore. Generally going from a 102mm piston from a 99.5mm piston will add some weight, further increasing rod/bearing etc loading at a given RPM. Quote:
07-14-2008, 08:34 PM | #18 | |
Member#: 33782
same reason it is easy to assembly my long rod setup...others it would depend on how they did things. Sounds like you are following in a similar path to mine |
07-14-2008, 08:38 PM | #19 |
Member#: 33782
also might add increased friction and decreased ring life
07-14-2008, 09:18 PM | #20 | |
Member#: 120641
Its all good, just wanted to be clear And I have been mistaken before and will be again for sure. LoL |
07-15-2008, 10:55 AM | #21 |
Member#: 117780
South East
Sinster, i was not flamin ya dude, just made that face to show what a chevy sbc would look like at 8500 LOL
07-15-2008, 10:04 PM | #22 |
Member#: 145145
Another thing to consider regarding high RPM stroker operation.
Harmonics. Considering the fact that the 83mm Stroker crank uses oem bearing journals, by definition you have 1.5mm less overlap of the rod journal/main journal cross section as compared to a standard 79mm ej25/7 crank, and 4mm less overlap than an ej20/7 based setup. Material choices aside, this would make a crank that is less torsionally rigid. Losing rigidity generally accompanies a reduction in resonant frequency. Theoretically this would lower the RPM at which potentially damaging torsional vibrations can manifest themselves. How much the above is really worth worrying about is still up in the air. I have a 2.71L crower kit now, and hope to get it running soon, i will let you guys know how it fares. Last edited by MartinSTi05; 07-16-2008 at 07:33 AM. Reason: Homemade WRX caught a screwup;-) |
07-15-2008, 11:40 PM | #23 |
Member#: 33782
also to add to the cons of the 2.7L is the clearancing of the block for the kit...so adding more loading on the block, increased harmonics and a weakened block...I'd say they start to run into issues at in the high-7k to low-8k rpm range
also you had a typo martin...the EJ25 is 79mm |
07-16-2008, 07:07 AM | #24 | |
Member#: 145145
08-25-2008, 02:18 AM | #25 |
Member#: 187550
Vehicle:2011 GR8 Obsidian Black Pearl |
con rod clearance
Is anyone else having clearance issues when they are putting this motor together?
Last week I got back the block and started the rebuild, but when I finished connecting the first 2 pistons I found there was “knock” and an obvious metal on metal drag when I turned the engine over. Aver some careful inspecting and the help of a sharpie I found one of my con rods was hitting the block at BDC. For this kind cash I thought it should be a no mod’in rebuild, Going at a re-sleeved sti block with the dremel, That just seems wrong |
Similar Threads | ||||
Brian Crower 83mm billet stroker crankshaft | mikeesingh | Engine/Power/Exhaust | 2 | 05-10-2019 01:27 PM |
injectors for a 2.71 stroker... help! | greekmafia | Built Motor Discussion | 3 | 09-05-2008 10:32 PM |
Brian Crower Cams, Springs, Stroker kits! WE GO THEM! | RallySport Direct | Engine/Power/Exhaust | 1 | 07-10-2008 03:57 PM |
Brian Crower 2.29L Stroker Kit : Subaru WRX EJ20 | ElCuRaNdEr | Built Motor Discussion | 9 | 10-13-2007 10:12 AM |
Brian Crower 2.29L Stroker Kit: Subaru WRX EJ20 | ElCuRaNdEr | Newbies & FAQs | 3 | 07-24-2007 11:39 AM |
