05-13-2009, 09:35 AM | #1 |
Member#: 70074
Vehicle:2005 WRX CGM |
Reset CEL for free
I was passing by a Sunoco 2 weeks ago and got some 93 instead of the usual premium gas. Then I got the CEL on. I called STS, Pepboys and Somerset Subaru Dealer in central NJ. They all charge around $90 for the reset. Does anyone know anywhere in CNJ will do reset for free? Thank you.
05-13-2009, 09:50 AM | #2 |
Member#: 42549
Tri-State
Vehicle:E92 M3 B9 Audi SQ5 |
Detach negative battery terminal
Step on brakes till power is out Re-attach negative terminal |
05-13-2009, 09:57 AM | #3 |
Member#: 23934
MAIC
most autozones will scan it for free. might as well find out what's triggering it. they'll reset it too if they're not dickheads about it.
05-13-2009, 10:01 AM | #4 |
Member#: 175549
Tri-State
Vehicle:2007 Forester STi 1965 Shelby Cobra (F5) |
the CEL turns on to tell you something is wrong. Resetting the ECU doesn't fix whatever is wrong with the car
05-13-2009, 11:00 AM | #5 |
Member#: 70074
i don't feel anything wrong with my car, i think it was the 93 gas that triggered the CEL as i heard some people have similar situation.
05-13-2009, 03:49 PM | #6 |
Member#: 42549
Tri-State
05-13-2009, 11:46 AM | #7 |
Member#: 171688
Tri-State
Vehicle:2006 Saabaru 9-2x Aero Wagon Midnight Black |
shoot come over here.. ill reset yer CEL for half the price!
$45 =) |
05-13-2009, 01:08 PM | #8 |
Member#: 156723
Tri-State
Vehicle:17 2.5i foz dgm rip wrx/rs/2.5i/foz1 |
Yea dude I would go to autozone they'll pull the code for free then you can tell whether or not something really is wrong. I would right now check your oil level and filter, when was the last time you did that?
PS you should be using 93 gas unless you're tuned differently, so using 93 should NOT throw a cel. Good luck, get to AZ. |
05-13-2009, 01:29 PM | #9 |
Member#: 174549
Vehicle:2002 wrx black |
you should check your gas cap to see if its lose that throws a cel
05-13-2009, 02:11 PM | #10 |
Member#: 18314
Vehicle:02 BLUE SUBARU WRX 06 GG EVO9 MR |
where in CJ are you located
05-13-2009, 02:09 PM | #11 |
Member#: 129428
Vehicle:2002 Wrx |
You can reset your ecu by just disconnecting your battery and pumping the brakes for a few seconds. If there is something wrong with your car, the cel will just come back, its just a matter of time.
05-13-2009, 04:21 PM | #12 |
Member#: 127215
Tri-State
Vehicle:01 Fozz 2.0L |
Instead of paying ppl to check your CEL why dont you spend the money on one of those cheap scan tools and code book. It practically pays for itself in after two CEL's.
05-13-2009, 10:55 PM | #13 |
Member#: 209358
Tri-State
Vehicle:06 Sti WRB |
05-13-2009, 04:34 PM | #14 |
Member#: 23934
MAIC
http://www.autozone.com/autozone/sto...questid=275559
choose one...come back and post up what cel code you have. |
05-13-2009, 07:51 PM | #15 |
Member#: 63060
Tri-State
Vehicle:0005 RS, 92X silver, red |
Yeah, why would 93 octane trigger a cel???
05-13-2009, 08:12 PM | #16 |
Member#: 149887
Tri-State
Vehicle:07 Sti Stage2"OTS" Whale Tail OBP |
Probably a lose gas cap..
05-13-2009, 09:41 PM | #17 |
Member#: 171948
Tri-State
Vehicle:19 Sti Crystal white |
better gas is in no way gonna cause a check engine light. i second the loose gas cap.
05-14-2009, 02:11 PM | #18 |
Member#: 70074
I just came back from Autozone, the code is P0031:
-heater control circuit low probable cause BB1 - Open or short circuit condition BB2 - Poor electrical connection BB3 - Failed H02S11 any idea? |
05-14-2009, 02:53 PM | #19 |
Member#: 171688
Tri-State
P0031
HO2S Heater Control Circuit Low (Bank 1 Sensor 1) bank 1 O2 sensor? |
05-14-2009, 03:00 PM | #20 |
Member#: 102812
Tri-State
Vehicle:18 WRX Dark Grey Metallic |
looks like it might be time for a front 02 sensor
05-14-2009, 04:04 PM | #21 |
Member#: 23934
MAIC
^^^ this. had to replace mine so i could pass inspection. chances are if you reset it and didn't fix the problem, it's coming back. home many miles on the clock?
edit - just looked at your car info. hmmm...only an 05. are o2 sensors known to crap out that soon? |
05-14-2009, 05:02 PM | #22 |
Member#: 146328
Tri-State
Vehicle:07 sti username is now invalid |
maybe you didn't put your gas cap on right?
have an accessport? that thing was amazing for cel codes. but autozone ran my codes for free. and if its just a fluke, then you can pull the battey cable and reset it yourself. |
05-14-2009, 05:36 PM | #23 | |
Member#: 156723
Tri-State
+1 for front o2 sensor... How many miles on the clock? |
05-14-2009, 07:23 PM | #24 |
Member#: 209358
Tri-State
^^ Haha
05-14-2009, 07:31 PM | #25 |
Member#: 171688
Tri-State
hmm just came across this thread.. might be helpful to OP
http://forums.nasioc.com/forums/show....php?t=1660218 |
Similar Threads | ||||
Misfired, CEL, fixed misfire, reset CEL, failed smog... | mc2 | Normally Aspirated Powertrain | 1 | 03-19-2009 05:59 PM |
HELP: where can I borrow a CEL code reader or get the code pulled for free? | anonymous_wolf | Vancouver Impreza Club Forum -- VIC | 5 | 08-11-2005 01:40 AM |
What stores test OBDII CEL codes for free? | Sephro | New England Impreza Club Forum -- NESIC | 11 | 02-23-2005 04:21 PM |
Anywhere to get a CEL read for free? | Jesperss | North West Impreza Club Forum -- NWIC | 3 | 10-15-2004 04:58 PM |
reset cel... | janikphoto | Legacy Forum | 4 | 09-28-2001 07:20 PM |
