01-30-2005, 07:12 PM | #1 |
Member#: 80375
Vehicle:05 2.5rs sport white |
Newbie Q: Turbo on 2.5rs?
Hey as in the titled i mention that i'm a newbie so i don't know wut i need to do this
i'm thinking about putting the factory turbo on my 2005 2.5rs and wondering if this is possible and what i need to do this...? |
01-30-2005, 07:18 PM | #2 |
Member#: 72560
SCIC
Vehicle:04 WRX (stg. II) java black prl |
why didnt u buy a wrx?
ure gonna need.. well.. a turbocharger... an intercooler. probably some exhaust modifications and probably more stuff than that.. ie fuel lines and pump.. maybe new injectors as well. some internals that i am unsure of because i dont know what the rs has thats different from the wrx inside considering the lack of turbo. i am sure someone else will give you a much more detailed response. |
01-30-2005, 07:45 PM | #3 | |
Member#: 18987
NESIC
Vehicle:2014 Forester Dark Grey Metallic |
-Stock WRX exhaust manifold. -uppipe either a STi one or aftermarket would be best. -turbo, either a stock WRX TD05H, or maybe a New VF-22 since they can be had cheap or other used VF series turbo -turbo cross member, this is what the turbo mounts onto, if I am not mistaken -stock WRX intercooler, with all hoses, and stock recirc valve -stock WRX exhaust, or after market if you want. (At least an aftermarket downpipe) -Maybe a WRX fuel pump, not sure if it is different from a RS fuel pump, capacity wise. -I would go with STi injectors just for reliability and safety sake, screw the blue ones. Or go with modified blues or something like that, don't just use the stock blue injectors. -Induction pipe, from airbox to turbo -intake box, or short ram/cold-air for WRX -ECU, gotta have something to run the whole thing. Get stock WRX ECU out of a wreck or something. try these guys http://www.fsautoparts.com/ You could probably source a lot of little stuff from there, but I would try to get stuff here, from memebers. You'll probably pay a lot less here. If I am leaving anything out, someone please chime in. DP |
02-04-2005, 10:44 PM | #4 | |
Member#: 40337
BAIC
Vehicle:95 L Coupe Swapped |
The turbo crossmember dosn't hold the turbo, its holds the motor. They call it a "turbo crossmember" because there is a notch in it to give clearence for the header and up pipe. |
02-05-2005, 09:18 AM | #5 |
Member#: 18987
NESIC
Judging by your screen name, I am not going to argue, I was just unsure exactly what the part was, but I knew it was needed.
Thanks, DP |
01-30-2005, 07:58 PM | #6 |
Member#: 34931
Tri-State
Vehicle:. Super bowl LII Champions! |
save yourself the headache...buy a WRX
01-30-2005, 08:16 PM | #7 | |
Vehicle:OK buy Nates beans westcoastroasting.com |
Turboing an engine that was not designed from the start to be turbo'd usually ends up with a blown engine and a LOT of wasted $$$. A motor swap may be possible fairly easily....check the 'conversions' forum.... |
01-30-2005, 09:11 PM | #8 |
Member#: 80375
thx for the suggestion...it seems like i should probably do a wrx swap
01-30-2005, 09:44 PM | #9 |
Member#: 69010
Vehicle:2008 obxt |
but void your warrentee right off the bat?
01-30-2005, 09:46 PM | #10 |
Member#: 72560
SCIC
it just seems like you should have bought a wrx from the start instead of an rs..
01-30-2005, 09:49 PM | #11 |
Member#: 10852
MAIC
Vehicle:Then : JDM Ver 7 STi Now : E46 M3 / MKVI GTI |
yipes. brand new car and you're gonna do a swap?
I say bust out the suspension and brake and exterior mods until your warrantee runs out. |
02-01-2005, 10:47 PM | #12 | |
Member#: 57809
MWSOC
Zach |
01-30-2005, 09:52 PM | #13 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
sell it and buy a 2002 wrx
01-30-2005, 10:08 PM | #14 |
Member#: 69010
Vehicle:2008 obxt |
The only reason I wouldn't suggest trading in your 2.5 for a WRX is insureance, you might not wanna have to pay a high price for insureance, thats why you got a 2.5 in the first place.
If I were you, get an older 2.5 or L, swap in a WRX engine, then you don't have to worry about a warrentee, or insureance. |
01-30-2005, 10:50 PM | #15 | |
Member#: 3313
MWSOC
I never understand that. I can't imagine insuring a WRX over a 2.5RS would amount to more than a $1000/year difference. Besides, to get your insurance to cover the swap parts, you might possibly need to notify them of the changes ahead of time, which could result in a rate increase anyways. |
01-30-2005, 11:50 PM | #16 |
Member#: 69010
Vehicle:2008 obxt |
A WRX swap is a one time cost though, insurance is every month, eventually the insurance will cost more then the swap.... might take a while, but it will.
01-30-2005, 10:19 PM | #17 |
Member#: 43770
Vehicle:2013 Impreza WRX Lim 2001 Impreza WRX STi |
Remember the RS engine runs 10.5:1 compression.....the wrx stock has 8:1.....The stock wrx turbo runs a typical 13.5 PSI ....I can imagine 13.5 PSI and 10.5:1 compression would go toghether very well...
01-31-2005, 04:21 AM | #18 |
Member#: 80375
well i'm not planning to do a swap just now...just want to research about it
i got the 2.5rs b/c i couldn't afford a wrx just now and ya i probably get some coil over and other things before doing a swap the problem with a 2.5rs is there is almost nthing you can do to the engine (i'm a newb so there might be, just don't know about it...if someone knows pls make suggestions) but thx for the good info guys |
02-04-2005, 02:07 PM | #19 |
Member#: 69247
E. Canada
Vehicle:2005 2.5 RS Wagon Crystal Gray Metallic |
You can do some minor performance upgrades such as changing your exhaust and when a CAI comes out, swapping that in.
Apparently Injen has an 05 CAI but I haven't really seen anyone use it other than Caplin2.5 |
02-04-2005, 02:20 PM | #20 |
Member#: 66558
NESIC
Too bad subaru doesn't do what Saturn does ... If you don't like your car or want something different in the first month, you can trade ... No fuss no muss ...
02-04-2005, 02:36 PM | #21 | |
Member#: 59980
Vehicle:03 Forester |
02-13-2005, 08:37 PM | #22 |
Member#: 81255
Tri-State
Vehicle:98 05 LGT, silver 98 Trans AM, Red |
sounds like a real expensive way to blow that motor up if u ask me
02-14-2005, 01:33 AM | #23 |
Member#: 26067
SWIC
Vehicle:2012 Jetta Grey |
if you get the kit...use a 2.2L turbo it's really small has great boost response and will have less of a chance of poping your 10.5:1 compression
Similar Threads | ||||
Ball Bearing T25 Turbo on 2.5RS | bambams247 | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 12-05-2003 01:38 PM |
Scooby Newbie Q: Eyelids on 2002 RS | fukamoto | Vancouver Impreza Club Forum -- VIC | 13 | 01-30-2002 08:16 PM |
newbie with a question on turbos on 2.5rs...which ones...???? | QCK HNDA | Normally Aspirated with bolt-on Forced Induction Powertrain | 20 | 11-06-2001 02:51 PM |
newbie with a question...2.5rs turbo question...which ones???? | QCK HNDA | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 11-03-2001 08:10 PM |
Legacy Turbo on 2.5RS? | BongMan | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 17 | 03-22-2001 07:13 PM |
